Guide to running multiple GPU work units
manofthem
WCG-TPU Team All-Star!
10,960 (2.12/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
830 (0.18/day)
Sydney, Australia
System Name The White Breeze||Medion Akoya Ultrabook
Processor i7-3770k||Core i5-3317U
Motherboard MSI Z77 MPOWER||Laptop?
Cooling Custom TEC waterloop||Laptop?
Memory 16GB Kingston HyperX @ 2133MHz||8GB SDRAM
Video Card(s) 2X SLI MSI GeForce GTX 680 Lightning||Intel 4000
Storage Corsair GT 120GB, WD Caviar Black 1TB||500GB HDD with 32gb MSATA cache
Display(s) Samsung U28D590D 4k||14" LED
Case NZXT Switch 810||Laptop shell?
Audio Device(s) Creative Sound Blaster X-Fi surround pro 5.1||Dolby Home Theatre V4
Power Supply Seasonic XP-860 Platinum||Laptop Power Brick
Software Windows 7||Windows 8
manofthem
10,960 (2.12/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
Hmm, they must just use the same database. I don't think this is a BOINC issue, may just be a WCG issue. But then again, I could be wrong.
Well, i have no idea. i'm reinstalling it now just because Maybe it'll start working :confused:
edit: Ok, maybe some progress. I've seen that it does better to install normally and actually let it start. Then shut it down and throw in the app_info file. It seems to be doing alright now. Atleast I no longer have the errors in the Event Log that I was getting, likely thanks to the help of KieX! :respect:
I'll post back with more info later, hopefully it works :)
manofthem
10,960 (2.12/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
So the good news: I finally got it up and running in a decent manner. Each card is running 4 WU's and finishing in about 2 minutes (+/- a little). I had an issue earlier about not receiving work and getting errors, as seen a few posts back, but after a reinstall or 2, as well as some other little fiddles, the errors are gone.
But, my only thing now is that the work is slow coming in, in that it doesn't stack up ahead like it used to. Usually as soon as it's ready for work, the old get reported and new ones come, but there has been at least once where it took a few seconds.
So does anyone know why this is happening and what I can do to stop it? I'd like to have a bunch lined up ahead, so that's what I'm looking for.
Also thanks to all for the help that you've given me :toast: and :respect:
830 (0.18/day)
Sydney, Australia
http://img.techpowerup.org/121103/wcg5877.png
Adjust your work buffer higher.
manofthem
10,960 (2.12/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
830 (0.18/day)
Sydney, Australia
Thanks, What should I put in for my minimum work buffer and max additional work buffer?
Ion reccomends somewhere between 2-5 days.
Work Buffer:
By default, BOINC has a work buffer (stored tasks) set to .25 days. This means that your computer has at least enough work to keep running for .25 days without downloading more WUs. It is recommended to set this to anywhere from 2-5 days so that in case there is a network outage the computer will still have work to do. If the computer is not on much, setting the work buffer to anything higher than 2 days is not advised because the system may not be able to finish the tasks by the deadlines. My personal preference is three days, that way there is generally enough work to last the computer through any project outage, but if something happens to the system, you can still usually complete all of the tasks by their deadlines
Found in this thread:
http://www.techpowerup.com/forums/showthread.php?p=1603277
manofthem
10,960 (2.12/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
Norton
Moderator - Returning from the Darkness
14,104 (2.93/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
To run the gpu wu's you may want to keep your buffer low (<0.5 days). The wu's have a limit/quota.... once you reach the limit, you only get a new one when you report a finished one.
I'm not sure how it works with gpu only setups but on single setups like mine, I get loaded with other non-gpu wu's if I set the buffer too high.
manofthem
10,960 (2.12/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
Ok, thank you sir. Obviously i'm not too familiar either, so I'm going to be monitoring it tonight and tomorrow, and then I should get a better idea of how the buffer should be set :)
[Ion]
WCG Team Assistant
13,391 (2.37/day)
Raleigh, North Carolina, United States
System Name Niedersachsen / Ribe / Minsk
Processor i3 3240 / i7-3520M / 4x Opteron 6376 @ 2.86GHz
Motherboard BIOSTAR H61M / HP Q77 / Supermicro H8QG7
Cooling Stock / Stock / 4x 1U G34
Memory 1x8GB / 2x4GB / 4x4GB
Video Card(s) GTX260 / Intel HD 4000 / nVidia GT310
Storage 80GB Intel SSD / 256GB Intel SSD / 2x 60GB SSD (RAID1)
Display(s) Dell 3007 + HP 2245w / 12.1" 1366x768 / None
Case Antec NSK3480 / HP / Supermicro 1U
Power Supply Enermax 500W / HP 130W / Supermicro Gold 1400W
Keyboard IBM Model M
Software Windows 7 (Niedersachsen/Ribe) / Linux Mint 17.2 (Minsk)
Thanks that's exactly what i needed :toast:
Sorry for all the noob questions the last few days and all the help requested, but I really appreciate it big time!
The way to learn is to ask questions. As I've stressed, we're here to help :toast:
Ahh, that's a good point for GPU-only systems. Certainly something to think about!
manofthem
10,960 (2.12/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
I know and thanks Ion. I just want everyone to know that I do appreciate the assistance I've been receiving here! It's not wasted either, as I'm going to be a permanent member of the team (as long as I can that is) even after the challenge ends; you don't just abandon your team! :toast: I'm glad I'm getting all the hi-jinks ironed out now :) And I'll update later with what buffer works well, as soon as I'm sure about it.
358 (0.07/day)
Maine
You can increase the buffer like others said. Another thing is if you return to many wu's that have been aborted or errored out, they will cut down how many wu's you recieve until you have returned more valid results than the invalid ones.
manofthem
10,960 (2.12/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
Just an update here: everything is going well. Currently I have set the work buffer to 0.5, and it seems to be maintaining a nice flow of incoming/outgoing work. Any higher work buffer, and work seemed to stack up, and any lower it was diminishing. I'm guessing perfect is somewhere right around there.
The WU's are getting done between 1:30-2:00, with gpu usage up at 98% almost always. I haven't had any dreaded errors or aborts, so I think it's smooth sailing from here on out.
Edit: update on buffer - I had it at 0.5, but I noticed that I'm catching up so I'm going to increase it to 0.6 :)
[Ion]
WCG Team Assistant
13,391 (2.37/day)
http://img.techpowerup.org/121105/wcg1.png
Wow---8 WUs finishing every 2 minutes. That's very close to 200k PPD you're getting there :eek: :toast:
Glad to hear it's been going well for you!
Is this making the computer laggy at all?
manofthem
10,960 (2.12/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
Well, I haven't hit 200k yet, that's t_ski territory. :p
My PC isn't too sluggish really, just once in a while with some graphical stuff. But with Internet stuff, music, regular hoopla: not too bad at all.
Next step it to get it going well in Windows 8 :banghead:
t_ski
Former Staff
11,941 (1.73/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
I now have 12 WU's completing every 2:07-2:28. That's about one every 12.5 Seconds :D
The only thing I've noticed is that it makes pr0n videos slow and jerky...
470 (0.10/day)
Toronto, Ontario, Canada
System Name Dell Studio XPS 8100 / Current PC
Processor Intel Core i5-750 @ 2.66 GHz / i5-3570K @ 3.4 GHz
Motherboard Dell Stock H55 / ASUS P8Z77-VLK
Cooling Stock
Memory Hynix 8GB DDR3-1333 / Kingston HyperX Blu Black 8 GB DDR3-1600
Video Card(s) MSI Radeon HD 7770 / EVGA GTX 560 Superclocked
Storage 1TB Western Digital Caviar Black / 128 GB Crucial m4 + 2TB Seagate Barracuda
Display(s) Samsung 19'' LCD / Dell 24'' LCD
Case Dell Studio XPS 8100 / Bitfenix Merc Alpha
Audio Device(s) Realtek Integrated
Power Supply Dell Stock 350W / OCZ ModXStream 700W
Benchmark Scores Dell Keyboard + Dell Mouse / Azio Levetron Clicker + Razer Lachesis
ONLY every 12.5 seconds...
Pick it up! :roll:
But on a serious note, mad props to you! :toast:
manofthem
10,960 (2.12/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
That's pretty insane, "props to you" as the dude says! Is that your max, as you're rocking the 12 threads? I think I read in one of these threads about running more WUs than you have threads, but I think that it'll be too much work.
[Ion]
WCG Team Assistant
13,391 (2.37/day)
Well, your theoretical output should be ~185-190k. Obviously actual output will be a tad slower ;)
Oh, only one every 12.5 seconds :p
I get one ever ~minute (not counting the CPUs) and I consider that good :p
Norton
14,104 (2.93/day)
Northeast USA
Mouse G300s
VR HMD N/A
[Ion]
WCG Team Assistant
13,391 (2.37/day)
t_ski is now #3 in the world with manofthem following pretty close at #13 :eek:
http://boincstats.com/en/stats/15/host/list/12/0/0
I'll bet that T hits #1 within the next 2-3 days...
You guys are rocking the WCG world!!! :toast:
Wow---someone on our Team with a host that's #3 in the world by PPD. That sure beats the ~#130 in the world that my 2700k does@
I'm dubious that he can hit #1 unless he gets another card--but still, #3 is amazing.
Although, given what he's done, I guess we shouldn't be too surprised :toast:
t_ski
Former Staff
11,941 (1.73/day)
Well, that number was with three WU's per GPU, and I just bumped it up to four. I did have to stop my WHS through, but that wasn't very many points. And I am having some trouble getting my P4 rig to boot now :( Never got that one up and running.
28,883 (4.58/day)
Miami, Florida
Motherboard ASUS ROG Crosshair X670E Hero
Cooling ARCTIC Liquid Freezer III 360 A-RGB // X12 Phanteks D30-120 D-RGB Fans
Memory G.SKILL Trident Z5 Neo RGB Series (AMD Expo) DDR5 RAM 32GB (2x16GB) 6000MT/s CL30
Video Card(s) ZOTAC Gaming GeForce RTX 4090 AMP Extreme AIRO
Storage Samsung Pro 980 2TB NVMe (OS and Games) // WD Black 10TB HDD (Storage)
Display(s) SAMSUNG 34-Inch Ultrawide 75Hz (Desk Games) // SAMSUNG 49-Inch Ultrawide 144Hz (Sim Racing Rig)
Case Phanteks NV7
Power Supply Seasonic Vertex GX-1200, 1200W 80+ Gold, ATX 3.0
manofthem
10,960 (2.12/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
