guys plz Help me My GPU Frozen in 100% Fan all time when pc turn on and icant do anything anyone here speak arabic cuz i dont speak eng Help
kareemayman
8 (0.01/day)
guys plz Help me My GPU Frozen in 100% all time and icant do anything anyone here speak arabic cuz i dont speak eng Help
Mussels
Freshwater Moderator
58,413 (7.87/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
This forum is english only, we cant help you with arabic here
If GPU usage is at 100% you likely have a virus, install an antivirus like kasperky and malwarebytes
Kaspersky
Malwarebytes
qubit
Overclocked quantum bit
17,865 (2.85/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Are there no Arabic tech forums around?
kareemayman
8 (0.01/day)
Kaspersky
Malwarebytes
man Socket fan is Broken and im fix it and nothing happen sorry for english when pc turn on gpu Fan stop at 100% speed and soo nouse
Try Google translate if you're that desperate.
ineed help bro ok im do it but need help im Tired and no fix
Toothless
Tech, Games, and TPU!
9,728 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Go rest, clear your mind, and try translating and we'll help as much as we can
Mussels
58,413 (7.87/day)
Oystralia
You'll have to take your time with translations or we wont be able to help at all.
Photos may help us understand the issue better
Oh - are you saying your GPU fan is broken and no longer spins, so the graphics card overheats?
kareemayman
8 (0.01/day)
no I'm saying the fans are spinning at full capacity and haven't stopped Fan speed 100%
When the computer is turned on, the fans rotate fully
Mussels
58,413 (7.87/day)
Oystralia
To help with the language barrier, tell us
1. What it should be doing
2. What it is doing instead
Like "my GPU should be at 0% usage, but it is at 100%"
Or "the fans should spin, but they dont"
Or "the fans are spinning so my GPU should be cold, but its at 100C"
So far all i understand is that your GPU fan is at 100% - is the GPU usage high as well? Is it overheating? Is this only in games, or when you are idle at the desktop?
553 (0.21/day)
Here
Processor Intel i9 11900K
Motherboard Z590 MSI ACE
Cooling Corsair H80i v2
Memory Ballistix Elite 4000 32GB 18-19-19-39
Video Card(s) EVGA 3090 XC3 ULTRA HYBRID
Storage 2x Seagate Barracuda 120 SSD 1 TB, XPG SX8200 PRO 1 TB
Display(s) Acer Predator Z321QU
Case Fractal Design Meshify C
Power Supply Asus ROG Strix 1000W
Maybe you've got an app like Afterburner that has manual fan control on at 100%
kareemayman
8 (0.01/day)
fan all Time at 100% no stopinng
Try updating graphics driver for your graphics card
Some times a driver bug might cause this
I did everything and the problem was not solved update driver and Bios when pc turn on fan spinning at 100%
I couldn't change the speed of the fans just spinning at full speed
Mussels
58,413 (7.87/day)
Oystralia
What temperature is the GPU running at, with no games or 3D programs active?
Use TechPowerUp GPU-Z
go to sensors tab, click the camera icon (blue circle)
paste the screenshot it took here
14,223 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Broken sensor on the card?
Mussels
58,413 (7.87/day)
Oystralia
we'll know from the screenshots, if he says its at 100% but we see 0RPM that'll be the case
I'm wondering if theres no thermal paste and its idling hot, or a mining virus
kareemayman
8 (0.01/day)
socket (Fan)
bro The Card is new
when The pc Turn on the fan spinnig at 100% 3900Rpm No Stoping And I could not scale down the fan speed
Mussels
58,413 (7.87/day)
Oystralia
The problem here is we have to ask every question, you are not providing any information. We didnt even know it was an RX570 until just now
That screenshot shows the GPU is under 100% load despite running at 30C, and at 500MHz something is very strange there
What is using the GPU in windows task manager? Why is it at 100%?
What card did you buy? Was it new in box or second hand?
kareemayman
8 (0.01/day)
the card is new in box
what can ido with fan ?
Mussels
58,413 (7.87/day)
Oystralia
Mussels
58,413 (7.87/day)
Oystralia
The problem is in the fan, not usage
always at 100% 3900rpm
no, your own screenshot showed your GPU was at 100% usage
Something is using the GPU, that usage is making the fan speed up
14,223 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Seems similar to the bug that causes Nvidia cards to get stuck at idle speed as his is under 100% load at idle. As the card is new I suggest return it.
Mussels
58,413 (7.87/day)
Oystralia
Somethings weird about it for sure, our only info is from that one screenshot
1. GPU is at 100% usage, but low temps (30c? thats idle temps!)
2. GPU fan is at 100% speed (why? broken fan, or software controlled?)
3. VRAM usage is low at 591MB, so its not likely eth mining
I'm wondering if its a card that was used for mining with a mining BIOS (low GPU clocks and high RAM clocks is normal there, and high fan speed could be done by some miners), but he insists its new in box
14,223 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Just thinking out loud, the fan speed seems linked to core load, not temp.
Increase the core clock to where it should be and load will drop relative as well as fan speed at idle.
Mussels
58,413 (7.87/day)
Oystralia
Aftger 3 days you havent sent photos of the card or given us any real information so we cant help you - return it to the seller
