HBM Supply Leader SK Hynix's Market Share to Exceed 50% in 2023 Due to Demand for AI Servers
18,521 (2.47/day)
A strong growth in AI server shipments has driven demand for high bandwidth memory (HBM). TrendForce reports that the top three HBM suppliers in 2022 were SK hynix, Samsung, and Micron, with 50%, 40%, and 10% market share, respectively. Furthermore, the specifications of high-end AI GPUs designed for deep learning have led to HBM product iteration. To prepare for the launch of NVIDIA H100 and AMD MI300 in 2H23, all three major suppliers are planning for the mass production of HBM3 products. At present, SK hynix is the only supplier that mass produces HBM3 products, and as a result, is projected to increase its market share to 53% as more customers adopt HBM3. Samsung and Micron are expected to start mass production sometime towards the end of this year or early 2024, with HBM market shares of 38% and 9%, respectively.
AI server shipment volume expected to increase by 15.4% in 2023
NVIDIA's DM/ML AI servers are equipped with an average of four or eight high-end graphics cards and two mainstream x86 server CPUs. These servers are primarily used by top US cloud services providers such as Google, AWS, Meta, and Microsoft. TrendForce analysis indicates that the shipment volume of servers with high-end GPGPUs is expected to increase by around 9% in 2022, with approximately 80% of these shipments concentrated in eight major cloud service providers in China and the US. Looking ahead to 2023, Microsoft, Meta, Baidu, and ByteDance will launch generative AI products and services, further boosting AI server shipments. It is estimated that the shipment volume of AI servers will increase by 15.4% this year, and a 12.2% CAGR for AI server shipments is projected from 2023 to 2027.
AI servers stimulate a simultaneous increase in demand for server DRAM, SSD, and HBM
TrendForce points out that the rise of AI servers is likely to increase demand for memory usage. While general servers have 500-600 GB of server DRAM, AI servers require significantly more—averaging between 1.2-1.7 TB with 64-128 GB per module. For enterprise SSDs, priority is given to DRAM or HBM due to the high-speed requirements of AI servers, but there has yet to be a noticeable push to expand SSD capacity. However, in terms of interface, PCIe 5.0 is more favored when it comes to addressing high-speed computing needs. Additionally, AI servers tend to use GPGPUs, and with NVIDIA A100 80 GB configurations of four or eight, HBM usage would be around 320-640 GB. As AI models grow increasingly complex, demand for server DRAM, SSDs, and HBM will grow simultaneously.
How is "AI" (Machine learning) being monetized ?
Chat bots are free ? Or they'll replace customer service and other roles that are script based is large companies anyway?
Dotcom 3 ?
Dotcom 3 ?
Machine learning is popular to profile users for better targeted advertising for example.
Then on top of that we the pure internal use cases where companies can use machine learning to optimise and replace parts of their workforce. It is only a matter of time before call centers will be gone for example.
It's used everywhere including the always greedy AF "investment" banks!
Used for what?
Say I invest $10bn in fancy "AI" hardware, what's it going to do to make me more money than I could do with pre existing technology for 1/1000th of the cost ?
Used for what?
If you are Google or somesuch, can you risk not doing lots of AI research and let the competitors gets ahead?
Doesn't have to make money yet.
Hey, why not, right? We're apparently going through another gilded age of capitalism with severe concentration, defacto monopolies, and cartelism. There's only a handful of NAND/memory manufacturers and they already manipulate the market, so why not include HBM in that, right?
Dotcom 3 ?
Well, it depends a lot on what the specific 'AI' even is. As it is actually a bunch of techniques that can be used for a lot of purposes, the thing about it is that it's an 'easy' solution, specially when you don't have much mathematical knowledge on the specific problem.
As an example of what it can be used for is to replace PIDs controller in industrial settings, but instead of having humans manually adjusting the PID parameters, the 'AI' is conditioned(trained) to match the desired output that the factory operators desire.
So basically the 'AI' is just a mathematical model that has it's parameters modified in order to match the desired data distribution. But just that alone has a shit ton of application, just stuff that you won't see at all because it's not front-facing application.
Dotcom 3 ?
It's token based for gpt at least. The chatbots are basically just the trial version / proof of concept. The model is to sell access to businesses that think they can make a cool product using gpt in "something".
Lists:
ModelPromptCompletion
8K context$0.03 / 1K tokens$0.06 / 1K tokens
32K context$0.06 / 1K tokens$0.12 / 1K tokens
