That looks like the fan fix bios which has the clockspeed limit removed, also notice the step in the core clock as it clocks up or down, I cant work that one out but its the same with any bios with 300mhz 2D clock. I have tested that one & its a definite improvement over the the stock bios. This Powerplay issue is far more complex than just clocks & voltages, theres other things being adjusted that we don't know about. Heres an example, the tests are the same game with an identical test but different bios. The big question is why should GPU load be different? Performance with the Fan fix bios is better. I would have thought that the first test which is like a 300mhz gfx card should have a higher GPU load, its delivering an awful framerate & just cant get the job done fast enough. I'm no GFX card expert by a very long way but this seems to indicate that theres a general performance drop throughout the card with lower Powerplay states.. like theres a bottleneck before the GPU core.
This is the stock clocks/bios test (this was done using the Omega drivers but official Cats produce identical results)
This is the Fanfix bios test, notice how theres an increase in GPU load which probably triggers the higher core clock, unfortunately performance is still a long way below my X1800XT.
This is the Powerplay states shown in bios by the Riva Tuner
$0a00030000 PowerPlay state 0 : 777MHz/1126MHz/1.33V/boot
$0a00030100 Performance level 1 : 777MHz/1126MHz/1.33V
$0a00030200 Performance level 2 : 777MHz/1126MHz/1.33V
$0a00030001 PowerPlay state 1 : 777MHz/1126MHz/1.24V/Overdrive
$0a00030101 Performance level 1 : 777MHz/1126MHz/1.24V
$0a00030201 Performance level 2 : 777MHz/1126MHz/1.33V
$0a00030002 PowerPlay state 2 : 777MHz/1126MHz/1.24V
$0a00030102 Performance level 1 : 777MHz/1126MHz/1.24V
$0a00030202 Performance level 2 : 777MHz/1126MHz/1.33V
$0a00030003 PowerPlay state 3 : 700MHz/1126MHz/1.33V/UVD
$0a00030103 Performance level 1 : 700MHz/1126MHz/1.33V
$0a00030203 Performance level 2 : 700MHz/1126MHz/1.33V
Watching a few threads around the forums on this topic & ATI are getting support tickets raised about this issue along with card manufacturers but I don't think we will here anything until a fix has been done, ATI are not going to own up to a problem at this stage its not good for marketing.
