Help: Force flash vBIOS with nvflash - win/DOS (Solved-ish)
Status
Not open for further replies.
1,919 (0.56/day)
Seattle, WA
I don't normally end up in a situation where I appear to have exhausted all options, but here I am.
I've got a GTX Titan Z that's running some pre-production firmware and won't cooperate with any drivers, modified or not. I would like to get the card running with production firmware via flashing both ASICs vBIOS with the retail versions. This is where I hit a snag, board ID Mismatch. nvflash does not appear to allow force flashing like ATIWinFlash does, so this simple error stops the whole process in its tracks.
Quick breakdown of different commands tried just from google searching previous threads:
nvflash -i# -4 -5 -6 romname.rom (replace pound with number of device to be flashed)
nvflash -i# -f -6 romname.rom
nvflash -index=# -f -6 romname.rom
nvflash -index=# -4 -5 -6 romname.rom
I understand that those are basically the same commands spelled differently, but I was just covering all bases. I did disable write protect on all available devices as well to clear that up.
My question really is, can I get around this roadblock and force the firmware in any way? While the board ID is a mismatch the device ID is the same and should work perfectly fine in the event that the retail firmware is applied.
Any help is appreciated, and I'm hoping it's a simple issue I've overlooked.
18,585 (2.71/day)
System Name AlderLake
@Law-II might be able to chime in.
He knows a lot about flashing graphics cards.
Tatty_Two
Gone Fishing
25,896 (3.79/day)
Worcestershire, UK
Processor Intel Core i9 11900KF @ -075mV PL max @225w
Software Win 11 Home x64
Straightforward nvflash -f bios.rom got me out of trouble a couple of times but that was a while back, not sure if it still plays.
1,919 (0.56/day)
Seattle, WA
Issue prevails, "Board ID mismatch"
Tatty_Two
Gone Fishing
25,896 (3.79/day)
Worcestershire, UK
nvflash -f -5 -6 yourbios.rom
nvflash -4 -5 -6 yourbios.rom
The last one is a slight deviation from one you have already tried, these are confirmed to have worked in the past but again not sure if current, had to check an old USB drive where I keep any flashing files and details I have done in the past.
1,919 (0.56/day)
Seattle, WA
Neither works. Board ID mismatch continues to win.
There has to be a workaround to the errors. ATIWinFlash has a command to ignore any and all errors and continue the flash regardless, and nvflash appears to have one as well but it just doesn't work.
985 (0.22/day)
Ireland
Have you tried adding --protectoff parameter?
985 (0.22/day)
Ireland
Sorry, i missed that part. And your graphics card is disabled in device manager, right?
985 (0.22/day)
Ireland
I just noticed your Nvflash says it's "Simplified version for OEM only", have you tried other versions? For me v. 5.206.0.1 works every time. Also, I'd try leaving only Titan Z in PC and then flashing.
1,919 (0.56/day)
Seattle, WA
Gave 5.206 a try and it has the same problem.
No dice. :(
Still saying simplified version as well. I don't know why.
1,919 (0.56/day)
Seattle, WA
I'm starting to think I should try the DOS version in hopes that it has a bit more functionality, or can possibly navigate around this error. If that's not going to work, can I change the board ID by editing straps with nvflash? (Assuming I can get the straps off the vBIOS to edit with.)
Toothless
Tech, Games, and TPU!
9,538 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
How did you get your hands on a Titan Z?
1,919 (0.56/day)
Seattle, WA
Back into DOS with a different BIOS, run the commands and it just locks into a blinking cursor. No progress made toward the flash besides wiping the BIOS from the card.
Is there something I'm missing here? This seems like an awful lot of problems for something that is supposed to be straight forward.
1,919 (0.56/day)
Seattle, WA
Finally got as far as getting nvflash in DOS to work, problem is that it too shows "Board ID mismatch"
Is there seriously no way around this bullshit error? Do I need to start soldering caps to bypass this shit or something?
2,100 (0.49/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
You can override all the checks/protection by using nvflash -j -4 -5 -6 bios.rom
2,100 (0.49/day)
Spencerport NY
System Name Master
Interesting. It's always worked for me.
13,905 (3.82/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
.... can I change the board ID by editing straps with nvflash? (Assuming I can get the straps off the vBIOS to edit with.)
Or edit the BIOS Rom to suit the board I.D.?
Thinking along the same lines, you need a BIOS editor to mod it.
Either change the adapter I.D.
or change the firmware I.D.
1,919 (0.56/day)
Seattle, WA
Working through them with a hex editor to see if I can make the appropriate change to the firmware without too much trouble.
2,012 (0.36/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
1,980 (0.40/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
HI
Thanks for the heads-up with regard to the OP's Vbios write issue; however on this occasion I am unable to help out; due to a lack of knowledge on the Nvidia Vbios [only just recently started to play with these]
+1 Caring1; editing the Vbios image with HEX
Note: to OP good luck with this quest; will be keeping an eye on this thread
atb
Law-II
Status
