- Jun 8, 2011
- 17,029 (3.43/day)
- Somerset, UK
System Name | Not so complete or overkill - There are others!! Just no room to put! :D |
Processor | Ryzen Threadripper 3970X |
Motherboard | Asus Zenith 2 Extreme Alpha |
Cooling | Lots!! Dual GTX 560 rads with D5 pumps for each rad. One rad for each component |
Memory | Viper Steel 4 x 16GB DDR4 3600MHz not sure on the timings... Probably still at 2667!! :( |
Video Card(s) | Asus Strix 3090 with front and rear active full cover water blocks |
Storage | I'm bound to forget something here - 250GB OS, 2 x 1TB NVME, 2 x 1TB SSD, 4TB SSD, 2 x 8TB HD etc... |
Display(s) | 3 x Dell 27" S2721DGFA @ 7680 x 1440P @ 144Hz or 165Hz - working on it!! |
Case | The big Thermaltake that looks like a Case Mods |
Audio Device(s) | Onboard |
Power Supply | EVGA 1600W T2 |
Mouse | Corsair thingy |
Keyboard | Razer something or other.... |
VR HMD | No headset yet |
Software | Windows 11 OS... Not a fan!! |
Benchmark Scores | I've actually never benched it!! Too busy with WCG and FAH and not gaming! :( :( Not OC'd it!! :( |
Nah those numbers are normal for Ryzen CPUs, it´s the voltage they apply for very short bursts to boost up to 4.2GHz. This is why I don´t like running stock, it does stay within 180W TDP, but jumps up and down with clocks and voltages every splitsecond. While 2 or 4 cores are @ 1.5V, the others are much lower and then they switch, this is why HWMonitor records 1.5V on all cores as this was the max. they reached, but not at the same time.
The high voltages are more often applied in idle, when it does not hit the power limit, under load I see ~1.2V on the non boosting cores.
But I would like to hear from you what your friend/colleague/guy said. Every input from other 1950x owners is helpful.
I'll see what I can do but I will definitely be interested in what his rig is pulling
