[Help] Problems with a Chinese RX580 8GB 2048SP
1,588 (0.27/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
I saw a topic of on techpowerup of someone with the exact same PCB. Almost every vbioses which were suggested are starting with D00034:
I think it is wise to try the following RX570 bios (D00034 with Samsung K4G80325FC memory):
N1MR0D
9 (0.02/day)
Thanks, I tested this BIOS but the problem still persists. Core clock stuck at 300MHz
1,588 (0.27/day)
I think you need to try some AFOX bioses since the PCB has the exact same board number listed on their site.
https://www.afox-corp.com/show-51-149-1.html (AFRX580-8192D5H7-V2)
Can you give the following bios a try?
https://www.techpowerup.com/vgabios/245055/245055
Some other AFOX bioses which might work:
1,588 (0.27/day)
@N1MR0D Any luck with those AFOX bioses?
GiantCod
2 (0.00/day)
I believe my 2048 from ebay may look similar to yours, or at least same style heatsink. Think its the other type of ram though FB.
Happy to link the bios if it will help. Runs but needs the Patcher to remove bios check on boot for windows. Also seems to have decent performance when benchmarked. Maybe a little power hungry on for the 6 pin.
Mine also run PCI 1.1 at idle but once under load shows 3 in gpu-z. Have you clicked the little question mark next to the speed, then click start render. Does it now change to 3? (sorry if im stating the obious here)
copywizard
2 (0.00/day)
Hello all I was looking for a thread like this! I,am stuck with the same gpu and Envinda RX580 2048sp from aliexpress.
And it is also stuck at 300mhz core/gpu clock but the mem clock boosts to 1750 once under load.
I,am still in dispute with the seller once this is finished i will open up my card.
I have tried al kinds of bios files but non fixed my issue yet.
Does anyone have a solution for this problem ?
Please let me know if you need anything from my from original bios files to pictures from the card itself?
578 (0.37/day)
System Name Mini efficient rig.
Processor R9 3900, @4ghz -0.05v offset. 110W peak.
Motherboard Gigabyte B450M DS3H, bios f41 pcie 4.0 unlocked.
Cooling some server blower @1500rpm
Memory 2x16GB oem Samsung D-Die. 3200MHz
Video Card(s) RX 6600 Pulse w/conductonaut @65C hotspot
Storage 1x 128gb nvme Samsung 950 Pro - 4x 1tb sata Hitachi 2.5" hdds
Display(s) Samsung C24RG50FQI
Case Jonsbo C2 (almost itx sized)
Audio Device(s) integrated Realtek crap
Power Supply Seasonic SSR-750FX
Keyboard Redragon K539 brown switches
Software Windows 7 Ultimate SP1 + Windows 10 21H2 LTSC (patched).
Benchmark Scores Cinebench: R15 3050 pts, R20 7000 pts, R23 17800 pts, r2024 1050 pts.
Its a refurb card (made with recycled parts from faulty chinese gpus, they stuffed them on a generic pcb and slapped a crappy 2 heatpipe cooler on top). 65 usd for this thing is a ripoff, any major tinkering would potentially break this thing.
As of march 2023 you can get a real 580 (8gig, 2304 sp, 4 heatpipes, xfx) for around 75 usd (easy to find on aliexpress). Only needs a standard full maintenance (clean the dust, change the tim, change the thermal pads, lube the fans) and you get a silent rx 580 with near 1660S level of performance. (in dx12 games at least).
If you happen to already purchase that generic gpu, the best option would be to return it (or ask for a maximum refund, especially if the card doesnt work properly, if you do the dispute correctly, the aliexpress would return your money), and then get the aforementioned xfx.
copywizard
2 (0.00/day)
thank you for your reply but not a really helpful one in fixing the problem i have with the current card
carolt26
3 (0.01/day)
You can try the ASUS's rx580 bios.My rx580 2048sp(or 480)can work when used this bios.You can also try the bios called D0034 Polaris 20XL(I'm sorry I can't speak English well)
36 (0.03/day)
Bulgaria
System Name PC
Processor Intel Core i3-2120 3.30 GHz
Motherboard Lenovo 1730BF8 Chipset Q65
Cooling Intel Stock
Memory 4x2GB 1333MHz DDR3
Video Card(s) Gainward GeForce GT 710 1GB GDDR5
Storage WD VelociRaptor 300GB 10000RPM SATA-II 3.0 Gb/s
Display(s) HP S2031a 50.8 cm (20 inch)
Case Lenovo M81 ThinkCentre
Power Supply FSP 280W
Mouse Cheap
Keyboard Cheap
Software Windows 10 Pro 21H1
Benchmark Scores Not tested
I am little late with my responce, but i have same type card, but is MAXSUN Radeon RX 580 2048sp. I don't have any type of problem, unless count some time when i play games my temps go to 83-85C and the card fans when are in higher percent they are noisy. I don't know did you fix your problem, but always can try MAXSUN vbios.
huntergaming
2 (0.01/day)
well mine is Hynix, and with driver date august 24th..about pcie x 1.1. is normal, is eco mod when gpu don´t work heavy or just idle, just click on "? > start render test and you get x 16 3.0 easy. if nay want my bios just ask.
5 (0.00/day)
Thanks, this solved my problem but now the display port isn't working. Do you know some solution?
Maybe you could try the AMD/ATI Pixel Clock Patcher to see if it solves the problem
Or try this one that i found and worked too
Unfortunately I opened it and discovered that mine is a 215-0876204 which is an RX 470 modified to look like an RX580 sp2048.
1,588 (0.27/day)
That is a workaround and not a solution! AMD/ATI Pixel Clock Patcher will not fix the root cause!
Can you make a seperate thread for your card? Please make a photo of the PCB and memory.
Soul-Venom
6 (0.03/day)
I have the same problem,can someone please suggest me a bios,I've already tried many bios's but the screen flickering and driver timeouts still persist,and yeah i tried many drivers,latest and old ones,currently running amd/ati bios
5,521 (4.20/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Galax Stealth STL-03
This GPU was mined to the ground. I'm fairly sure one of those memory chips at the minimum failed due to thermal damage given the amount of yellowing on them. Buying Chinese Polaris cards from mining rigs is as good as setting your money alight. Return your card if you acquired it recently.
1,588 (0.27/day)
Soul-Venom
6 (0.03/day)
I really wish to return it,but i bought it for a time now,so can't use it anymore?even with a less powerfull bios?
1,588 (0.27/day)
Sorry,no one was giving me suggestion and i was frustrated with this card
Two bioses where provided within 24 hours. See timestamps. 5 days later you resurrect a dead thread....
Lets continue in your own thread and provide the photo's I asked before so we can confirm the correct bios is provided
13 (0.01/day)
System Name Which one? Lol
Before anything, I know buying an RX580 from aliexpress isn't always (and almost never) the best choice, but being on very low budget and with the extreme markup for graphics cards in my country, it was the most sound choice available, specially considering I managed to grab it on 11.11 for $65.
I've been trying to solve the issue on my own for the past couple of weeks and I've made some progress. Initially I thought it was a drivers issue as the original problem was the system randomly freezing minutes after booting up or bluescreens. The problem persisted even on fresh windows 10 and linux installs so I figured the problem must be the BIOS, as chinese manufacturers modify these for crypto mining.
Here's a pic of GPU-Z on the original BIOS and the "GPU-Z Parameter" image the seller has on the product page
View attachment 281282View attachment 281292View attachment 281283
(Sorry for all the pictures of GPU-Z on my monitor instead of screencaps)
Did some digging and decided to flash this BIOS after confirming that the memory on my card was Samsung
View attachment 281280View attachment 281281
GPU-Z after flashing the 570 BIOS
After flashing the BIOS no crashes at all (until later). I used the PC like that for a couple days but when I tried gaming on it, the performance was extremely low (20fps on Cyberpunk 2077 720p on minimum graphics and 11%-15% gpu relative performance on userbenchmark). Not only that but when it does some hardware encoding for Parsec or Jellyfin it crashes. So I decided to try flashing a different BIOS. Currently I've tried the 570 BIOS, which I've already linked and this "veineda" BIOS. Both seem to work but with the extremely low performance issue.
And I've also tried this "MLLSE" BIOS which performed noticeably better during the userbenchmark test but glitched and bluescreened before it ended. Will randomly bluescreen minutes after boot.
On further inspection I noticed that the memory has a "128" engraved on it, so I've been looking for a BIOS that supports samsung K4G80325FC memory and has "D00034 Polaris20 XL A1 GDDR5 128Mx32 4GB 300e/300m" in the product name like this BIOS, as opposed to the "D00033 Polaris20 XL A1 GDDR5 256Mx32 8GB 300e/300m" on the other ones I've tried. I still haven't found a suitable BIOS as all the ones I've found only support different memory (Micron, hynix). Could this actually be the problem or am I just making assumptions?
I'll also try it in my friends PC in a couple days to check for compatibility issues it may have with my PC.
My knowledge is limited to what I've read while trying to fix this problems the past few days so any help is appreciated.
I bought a MLLSE rx580 8GB 2048sp from Newegg on 4/12/23 for $69.99 plus tax. I recently put it in a build for a customer and was having weird issues. I got display and Windows installed drivers, but I ran the auto detect on AMD and have nothing but issues. Even manually clicking rx580 drivers and downloading Adrenaline I got errors that it couldn't be opened. Running any sort of benchmark would run at 1-2fps. I figured there was some driver issue. I took the heatsink off and the chip is AMD 215-0910052 and coming back to a RX570x? Even in GPUZ it would show as a 570, which I know is fairly common. Now I'm wondering if it is infact some weird driver/compatibility issue with Adrenaline or if the V BIOS is messed up. There is one that someone posted here I can try. Titled MLLSE RX 580 2048sp 8GB BIOS Filename 253019.rom. I've never flashed a V BIOS and don't have the tool, but I can buy one. Sorry if this is all over the place. This was a couple months ago and I'm trying to remember all the steps I took. I'm currently starting another build for someone and may try it in this build to replicate the issues or get it to work. Thanks!
5,521 (4.20/day)
São Paulo, Brazil
MLLSE are Chinese recycled GPUs - and the 2048 SP is a Chinese-only SKU. It shouldn't have been sold on Newegg, tbh.
The hardware is likely dead/damaged, there is no QA as it reuses components from cards that were mined to the brink of death installed on a new PCB.
