Help with port forwarding
1,617 (1.76/day)
G-City, UK
System Name AMDWeapon
Processor Ryzen 7 7800X3D
Video Card(s) Powercolor 7900 GRE Red Devil
Case Montech 903 MAX AIR
Audio Device(s) Corsair void wireless/Sennheiser EPOS 670
Mouse Glorious Model D l Pad GameSir G7 SE
Keyboard Redragon Vara K551P
Software Windows 11 Pro 24H2
Benchmark Scores Fast Enough.
You already have existing settings for ports 27014-27050 under the name Cold war. That seems like a fair validation check.
Yeah, I noticed.
What if I run out of External ports? How do I input the other Internal ports?
You already have an entry for those external ports. Also arn't the internal port numbers supposed to match the external port numbers because essentially your trying to pass-though the traffic to the target pc on the same ports?
I don't understand very well. I have learning difficulties. Feel so demoralised.
I know it must seem like I'm useless, need stuff explaining to me all the time.
Sorry.
3,245 (1.68/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Yeah, I noticed.
Here is what I think should happen... ( simple view )
As long as you are not reconfiguring the games port setup I think you should be mapping the external port (or range) to the same internal port (or range). Does this make sense now?
If your friends are going to your home town to visit you it's like you told them you are at MacDonalds but you ended up giving them the directions to Burger King. They are in the correct city but going to the wrong street address.
So this entry I think you got correct.
1,617 (1.76/day)
G-City, UK
in other words this doesn't seem right to me unless you are specifying custom ports for your game for your internal network. (the items in red)
To better illustrate what I mean...For example lets say you have a webserver you want to expose from your internal network you might specify external port range 80-80 mapped to internal port range 80-80 to the given server on the internal network. Now if the webserver on the internal network was configured for port 60100 instead you would map external port range 80-80 to internal port range 60100-60100. Does this make sense?
Still doesn't, no. I'm sorry.
Cold War works now on open nat type. Big spliff time methinks.
3,245 (1.68/day)
Mouse Logitech M575
Sorry for all the edits/re-edits.
Basically if your friends are going to your home town to visit you it's like you told them you are at MacDonalds but you ended up giving them the directions to Burger King. They are in the correct city but going to the wrong street address. If MacDonalds is the (external address) then you need to be at MacDonalds (internal address)
1,617 (1.76/day)
G-City, UK
Please don't apologise, you are trying your best to help me.
I'm in a bit of a state now. I'll try again in a bit.
Reason I get confused is that the list of COD games has so many ports, I just thought they would be copy left side, copy right side boom. Done.
Right. From this list, how would I input these? There are more ports on the right than left. If it was just "3074 - 3074" I'd get that, but it's not.
3,671 (0.86/day)
GMT +2
System Name Red Radiance l under construction
Processor 5800x
Motherboard x470 taichi
Cooling stock wrath
Memory TridentZ Neo rgb 3600mhz (2x8 kit)
Video Card(s) Sapphire Vega 64 nitro+
Storage 970 evo nvme
Display(s) lc27g75tq
Case tt core x5 tge
Audio Device(s) sennheiser's pc323d usb soundcard
Power Supply corsair AX860i
Mouse roccat burst pro
Keyboard roccat ryos mk fx
Software windows 10
Yeah, I noticed.
Sorry.
you dont need to add separate rule for all cod games.
as soon as you have forwarding rule for curtain range of ports your router doesnt care which cod game will use it
so for example 27014-27050 is used from cold war, vanguard, modern warfare etc.
you set it once in the router and all COD games that need it will use it.
then you have 27015 used by modern warfare 2&3 and warzone. since 27015 is included in the range 27014-27050 (remember 27017-27050=27014, 27015, 27016, 27017..... 27049, 27050) so you dont need to setup separate rule for it because it is already forwarded from the previous rule you've set (this one
also you cant run out of ports (internal or external) so dont worry about that.
you add only uniq entries in this case 3074 (you have it already so you can skip it), 3478, 4000 (done with mw3), 4379-4380, 6112-6119 (already done with mw32), 20500 (also have this already), 20510 (done with mw34), 27000-27031, 27036(it is included in 27014-27050) and 28960
3,245 (1.68/day)
Mouse Logitech M575
Here is what I would try, not to say that it's the only way.
ruleexternalinternalprotocol
A - tcp/udp example where port ranges match up in chart3074-30743074-3074tcp/udp
B - tcp example where port ranges don't match up in chart4000-40004000-4000tcp only
C - tcp/udp example where port ranges match chart6112-61196112-6119tcp/udp
D - udp example where port ranges don't match up in chart4379-43804379-4380udp only
E - another tcp only example27014-2705027014-27050tcp only
F - another udp only example27000-2703127000-27031udp only
1,617 (1.76/day)
G-City, UK
then you have 27015 used by modern warfare 2&3 and warzone. since 27015 is included in the range 27014-27050 (remember 27017-27050=27014, 27015, 27016, 27017..... 27049, 27050) so you dont need to setup separate rule for it because it is already forwarded from the previous rule you've set (this oneView attachment 361373)
I've just destroyed my kitchen door. I just can't understand. It's like all the numbers run round the screen.
3,245 (1.68/day)
Mouse Logitech M575
Ok then take a step back and take a breather. Just take one number at a time then to make it easy. Always one step at a time...
Step 1: Enter 4000 for internal and external and TCP for protocol, save
Step 2: Enter 6112-6119 for internal and external and TCP for protocol, save
Step 3: Enter 20500 for internal and external and TCP for protocol, save
...just keep doing that for all the number sets in the TCP column.
When you are done with the TCP column move to the UDP column and do the same thing one number set at a time...
Step 4: Enter 3478 for internal and external and UDP for protocol, save
Step 5: Enter 4379-4380 for internal and external and UDP for protocol, save
etc...
5,240 (0.88/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [MSI MAG B550 TOMAHAWK]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Crucial Pro 3200MHz (32GBx2)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Fanmusic TRUTHEAR IEM, HyperX Duocast]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
We're all neglecting the part where OP is probably double NAT'd at the ISP level and none of this matters. I have this issue and have to tunnel apps to my VPS if I want ports forwarded.
TLDR of that means you can't port forward if your ISP is double NAT'd. Some of them will offer to upgrade your service for more money to allow it.
Should also note that a moderate NAT in COD gets you the same ping as an open NAT. So if that's the end goal, you're wasting your time fretting over it. I'm pretty sure a moderate NAT just means you won't get paired with people who have a closed NAT.
1,617 (1.76/day)
G-City, UK
This is just embarrassing now. Still stuck and lost despite all these instructions.
5,240 (0.88/day)
1,617 (1.76/day)
G-City, UK
I'm not double nat'd as I've made Cold War open nat with just 2 rules.
I'm like trying to get blood out of a stone. I once went almost insane worrying about ohmage on speakers. Got told by my mates Mrs to shut the fuck up about it or leave their house...
Right. Should I just delete all the MW3 rules and start from scratch? Also I tried just entering just the TCP/UDP addresses and it refused to save it. I know I'm hard work but I want to succeed at this and not give up.
3,245 (1.68/day)
Mouse Logitech M575
Yes, well at least those that were wrong or simply correct them. (see below)
You had a couple that you did perfect. Focus on that and just repeat and build on that success.
Below in green = good. I tried to indicate corrections below... you were almost there just some corrections needed.
I think ShiBDiB is talking about your Internet Service Provider - not your local network.
1,617 (1.76/day)
G-City, UK
I think it makes sense now! Thank you for helping me, means a lot!
However, I know what an ISP is, haha.
This look okay?
3,245 (1.68/day)
Mouse Logitech M575
The line for mw36 looks wrong. I think you meant to enter external: 27000-27031, internal: 27000-27031
Now with all this done is COD working as you expected?
1,617 (1.76/day)
G-City, UK
No, it's still shite, lmao.
2,508 (0.80/day)
This type of port forwarding configuration stuff is hell when you don't do it often or ever. The frustration level is understandable. It's up there with de clogging the head nozzle on a printer and it using up like half the ink in the new cartridge you just bought for it.
1,617 (1.76/day)
G-City, UK
I've tried entering values and sometimes they just refuse to take, despite following the instructions carefully. Makes me feel really stupid.
2,508 (0.80/day)
You wouldn't be the first technology makes just about all of us feel stupid from time to time. It defiantly is confusing figuring out port forwarding and server configuration. They both need to be set just right or won't work as intended.
If you had some other servers working before try matching the ports and configuration files to those.
39 (0.11/day)
System Name Home workhorse-gaming
Processor Intel 13600KF @ 5400/4300
Motherboard Asus ROG Strix Z790A Gaming WiFi
Cooling Arctic Freezer 2 rev.7 360mm
Memory 2x16 Kingston Fury Renegade Silver RGB DDR6400@XMP settings - 32-39-39-80
Video Card(s) Palit GamePro 3080Ti with Alphacool Eiswolf 2 360 mm
Storage NVME, WD 550 Blue 1 TB (gen.3), Samsung 980 1 TB (gen.3), Kingston KC3000 2 TB (gen.4)
Display(s) Samsung Odyssey G5 LS27AG500NUXEN (IPS, flat), @120Hz, 10 bit color (165Hz@8 bit)
Case Corsair 5000D Airflow, 4xArctic Bionix P120
Audio Device(s) Creative Sound BlasterX AE5 Plus, Creative T580 boxes, Sennheiser HD569
Power Supply Seasonic Focus GX 850W Gold
Mouse Razer Basilisk V3 Chroma
Keyboard Asus TUF Gaming K3
VR HMD none
Software W11 pro
Benchmark Scores https://hwbot.org/xtu2/analyze/5404795?recalculate=true
Hi Blaeza, just to exclude 2 other factors from this:
- when you first ran the game(s) did you allow access to public networks too (in the UAC prompt)? If no, that could be a reason;
- is it possible that you have an antivirus suite that also replaces the windows firewall with its own? If yes, that could also be a possibility, I ran into issues with those.
The reason I'm asking is because I didn't had to set any port FW rules for any game in the last 10 years at least, so it's a bit perplexing to me and I thought that maybe the issue could be somewhere else.
My 2c.
1,617 (1.76/day)
G-City, UK
My 2c.
I always allow connectivity from UAC prompts and my only antivirus is win defender.
I've only been on PC 4 years. I've always had moderate nat when I was on Xbox 360/1, so I just wanted to have the most open connection possible for the first time.
I think I'm incompetent at technical things like this.
39 (0.11/day)
VR HMD none
Software W11 pro
You're not incompetent and I didn't meant it that way, just checking to be sure, sometimes the problem is elsewhere than we think at first.
Try another way:
- make only one rule TCP/UDP: external range 3074-28960, internal range 3074-28960. If that doesn't work I'm out of ideas to be honest.
