Help with removing timer function on circuit board
Jswe
2 (0.00/day)
Hi! Need some help with removal of the timer funktion on a Bosch heatpad (PFP1136), any ideas on how?
Regards,
J
2,357 (0.45/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
Can't tell you anything with just picks. The timer looks to consist of a capacitor and an up/down counter on an IC but that's basically all I can say w/o actually fiddling with it. Could you include a pic with he outside of the case that has the switch labels.
sneekypeet
not-so supermod
29,685 (4.31/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Test it with power and hard wire it! On the flip side, timers are a good thing, and are sometimes there so the board does not overheat and you catch fire while sleeping!
13,657 (2.02/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Just cut the two wires from both ends of that device and throw the device away. In connect one of these to both wires.
2,100 (0.47/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
Way to help him short cut any safety measures that device had. You know better than that.
It's an instant fire hazard.
43,529 (6.77/day)
Its a safety device, you defeat it there is no warranty and you are your own liability if you kill yourself or someone else by doing this.
13,657 (2.02/day)
Nebraska, USA
Mouse Logitech M190
Instant fire hazard? Now that is simply ridiculous! He wants to dig around in circuits disabling the timing feature. That's the timing feature and you should know better than that.
The best solution if the device is broken is to replace the pad.
21,732 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 64GB (2x 32GB) G.Skill Flare X5 @ DDR5-6200 CL30
Case Thermaltake Core X31
Bill, it doesn't even look like a straighthrough AC timer device if I'm not mistaken. There are several wires on what I am assuming is a DC (or something else) end.
Your advice this time strikes me as just bad advice. Please don't take that personally, but as constructive criticism (and criticism I'm not claiming is neccesarily 100% right.) I'd like you to make sure you didn't miss something and I admit my electronics knowledge is really just basic, but this seems wrong.
We all give bad advice on occasion, usually because we missed something. Not sure if it's you or me here but we both should take our time thinking here. A second look never hurts.
13,657 (2.02/day)
Nebraska, USA
Mouse Logitech M190
It was bad advice. I admit and I apologize to Jswe and everyone else. :oops: It was meant tongue in cheek but this is not the place for it. So again, I apologize.
Because we have no schematics, cannot see the part numbers or values of the all the components, nor can we see all the trace routes, my sincere advice it to just replace the pad.
21,732 (3.40/day)
Olympia, WA
System Name Pioneer
Agreed.
As an aside, I'm glad to see I'm not going completely out of date and there's some kind of fancy schmancy quad polarity AC pass through timer thing going on (how else could two wires go in, 4 come out?)
I mean I guess technically there could be multiple AC phases at play, but I thought that a little complex for a heating pad... plus I never liked AC and don't really understand it, I'm a modern day Thomas Edison, lol!
2,100 (0.47/day)
Spencerport NY
System Name Master
The timer is there to allow a cool down period so things don't overheat. I DO know that thank you.
Regardless, you know it was bad advice so there is no point in making it more than it is. I'm all done here. :)
13,657 (2.02/day)
Nebraska, USA
Mouse Logitech M190
My "guess" would be for high (4) and low (2).
...so there is no point in making it more than it is.
And yet you found it necessary to come back in after I showed my embarrassment, admitted I was wrong and apologized twice just to get your final jabs in. I guess you've got your warm fuzzy now, so good for you. :rolleyes:
2,100 (0.47/day)
Spencerport NY
System Name Master
lol. It wasn't like that at all. I just responded to your post to me that I DID know what the timing feature was and what it was for. I don't do passive aggressive.
Cool off man. There was no jab at you.
jesus. The ego's on some of you people are incredible.
34 (0.01/day)
Processor Intel Core i7 4790K 4.0Ghz 8Mb Cache
Motherboard Asus MAXIMUS VI HERO Z97
Cooling CM V8
Memory GSkill DDR3 2x8Gb 1866Mhz Sniper Cas9
Video Card(s) Zotac Geforce GTX 980Ti 6Gb GDDR5 AMP! EXTREME
Storage SAMSUNG Spinpoint F1 1TB-Western Digital 1Tb Black-Samsung SSD 850 EVO 500Gb-Sandisk Extr.SSD 120 GB
Display(s) AOC G2460PQU
Case Corsair Graphite 600 White
Audio Device(s) Sou Blaster Z
Power Supply CoolerMaster 1000Q
Mouse Logitech G710s
Keyboard Corsair Strafe RGB
Software Win 10 64bit Pro
Burn baby.. BURN! jajajajaj
13,657 (2.02/day)
Nebraska, USA
Mouse Logitech M190
:roll:And yet another jab! Wow!
If my ego and arrogance was so great, I would not have been able to swallow my pride, admit my mistake or apologize. Instead, I would have dug myself into a deeper hole by insisting I was right and further criticized those who said otherwise.
Now you are welcome get another jab in. I'm done here.
2,100 (0.47/day)
Spencerport NY
System Name Master
WTF is your problem dude.
Get over yourself already.
