Help with RTX 4090 - Low timespy score and low fps in cyberpunk 2077, CPU bottleneck?
TGuerreiro
4 (0.08/day)
Hi, I recently upgraded my computer with an RTX 4090 Suprim Liquid X but it's getting very low scores in time spy and low fps in cyberpunk 2077.
My specs
i9-10900KF
MSI RTX 4090 Suprim Liquid X
32GB 3600MHz DDR4
2tb Nvme WD Black SN850X
Time Spy Score
Total: 25203
Graphics score: 30032
CPU score: 13.188
Cyberpunk 2077
Settings: 4K, DLSS Quality, Frame Generation ON, Max settings (psycho), Ray Tracing ON, Path Tracing ON
Score: Average 94.93fps
Is my CPU causing a bottleneck?
Did I win the lottery and get a poorly performing 4090?
If I buy one 7800x3d, x870, ddr5 6000Mhz CL 30, will I get much better performance?
Thanks in advance!
2,965 (2.06/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
Yes
Impossible
Yes
177 (0.12/day)
System Name Upgraded CyberpowerPC Ultra 5 Elite Gaming PC
Processor AMD Ryzen 7 5800X3D
Motherboard MSI B450M Pro-VDH Plus
Memory CM4X8GD3000C16K4D (OC to CL14)
Video Card(s) XFX Speedster MERC RX 7800 XT
Storage TCSunbow X3 1TB, ADATA SU630 240GB, Seagate BarraCuda ST2000DM008 2TB
Display(s) AOC Agon AG241QX 1440p 144Hz
Case Cooler Master MasterBox MB520 (CyberpowerPC variant)
Power Supply 600W Cooler Master
I personally wouldn't get a 7800X3D. The Ryzen 7 9800X3D is out now, and is significantly more powerful than the 7800X3D while usually not being a lot more expensive.
To be fair, the performance difference with an RTX 4090 in Cyberpunk 2077 at 4K with RT is negligible (sometimes not even measurable), but the 9800X3D is still the fastest CPU, and would give you better options for future GPU upgrades without having to replace the CPU to avoid bottlenecking again, or for games that are relatively more CPU-intensive than Cyberpunk 2077 (Cyberpunk with RT is one of the most GPU-intensive games relative to its CPU usage. Even if Cyberpunk 2077 isn't CPU-bottlenecked, it's still possible that a lot of other games would be).
Though if you're in a region where the 9800X3D is unobtainium, or where the 7800X3D is a lot cheaper, the 7800X3D is still a very good gaming CPU and might be the better option for you personally.
43,051 (6.72/day)
To be fair, the performance difference with an RTX 4090 in Cyberpunk 2077 at 4K is fairly negligible, but the 9800X3D is still the fastest CPU, and would give you better options for future GPU upgrades without having to replace the CPU to avoid bottlenecking again, or for games that are relatively more CPU-intensive than Cyberpunk 2077 (Cyberpunk with RT is one of the most GPU-intensive games relative to its CPU usage. Even if Cyberpunk 2077 isn't CPU-bottlenecked, it's still possible that a lot of other games would be).
2fps, really that is like pissing in the wind. I'd go with the lower cost chip at that rate.
TGuerreiro
4 (0.08/day)
I'm thinking about the 7800x3d because here in Brazil the 9800x3d hasn't been officially released yet and the stores that have the 9800x3d are selling it for R$ 4,271 (~736.25 USD) and the 7800x3d for R$ 2,999.99 (~516.98 USD), ~220 USD difference.
Will there be a big difference with a 7800x3d or 9800x3d compared to my i9 10900k in 4k?
823 (0.24/day)
System Name Harm's Rig's
Processor 5950X /2700x / AMD 8370e 4500
Motherboard ASUS DARK HERO / ASRock B550 Phantom Gaming 4
Cooling Arctic Liquid Freezer III 420 Push/Pull -6 Noctua NF-A14 i and 6 Noctua NF-A14 i Meshify 2 XL
Memory CORSAIR Vengeance RGB RT 32GB (4x16GB) DDR4 4266cl16 - Patriot Viper Steel DDR4 16GB (4x 8GB)
Video Card(s) ZOTAC AMP EXTREME AIRO 4090 / 1080 Ti /290X CFX
Storage SAMSUNG 980 PRO SSD 1TB/ WD DARK 770 2TB , Sabrent NVMe 512GB / 1 SSD 250GB / 1 HHD 3 TB
Display(s) Thermal Grizzly WireView / TCL 646 55 TV / 50 Xfinity Hisense A6 XUMO TV
Case Meshify 2 XL- TT 37 VIEW 200MM'S-ARTIC P14MAX
Audio Device(s) Sharp Aquos
Power Supply NZXT C1500 Platinum ATX 3.1 | Fully FSP Hydro PTM PRO 1200W ATX 3.0 PCI-E GEN-5 80 Plus Platinum -
Mouse G502
Keyboard G413
I have a 4090 with a 5950X , at 4K RT or no RT , waste of money , for a few fps or less !
177 (0.12/day)
Ok, fair enough. At those prices, the 7800X3D is probably the better option.
At the moment, no, especially in Cyberpunk 2077 at 4K with an RTX 4090 there won't be a difference in performance between the 7800X3D and 9800X3D. There might be a difference in other games which are more CPU-intensive, or if you upgrade to a more powerful GPU (e.g. an RTX 5090) in the future, but for now the 7800X3D is the better choice if it's ~$200 cheaper.
My consideration was for the potential of future GPU upgrades and for games that are more CPU intensive. In those situations, the performance difference between a 7800X3D and 9800X3D will often be a lot more than 2fps.
But even so, when the price difference is more than $200, the 7800X3D would still probably be better value. If performance in Cyberpunk 2077 at 4K with ray tracing is your only concern, then paying more for a 9800X3D would be completely pointless. You could even get basically the same performance from a Ryzen 5 9600X or 7600X, which are about half the price of a 7800X3D (or even less) in most regions, though I'm not sure how much it costs in Brazil.
43,051 (6.72/day)
User can move to a 9800 or 9950 later in time.
Frick
Fishfaced Nincompoop
19,735 (2.86/day)
w
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
Yes
Impossible
Yes
In 4K Cyberpunk with maxed out everything, including path tracing? I don't think the performance will be "much better".
Ruru
S.T.A.R.S.
13,144 (2.98/day)
Jyväskylä, Finland
Processor AMD Ryzen 7 5800X / Intel Core i7-8600K
Audio Device(s) Sony WH-CN720N / TV speakers
VR HMD Oculus Rift CV1
To be honest, that's almost in the margin of error.
726 (1.18/day)
Processor Ryzen 5700x
Motherboard Gigabyte Auros Elite AX V2
Cooling Thermalright Peerless Assassin SE White
Memory TeamGroup T-Force Delta RGB 32GB 3600Mhz
Video Card(s) PowerColor Red Dragon Rx 6800
Storage Fanxiang S660 1TB, Fanxiang S500 Pro 1TB, BraveEagle 240GB SSD, 2TB Seagate HDD
Case Corsair 4000D White
Power Supply Corsair RM750x SHIFT
My specs
i9-10900KF
32GB 3600MHz DDR4
Time Spy Score
Total: 25203
CPU score: 13.188
Cyberpunk 2077
Thanks in advance!
Check that video, specifically testing at 4k with a 9900k, 10900k, 12900k and 13900k all with the 4090, in general you will see the biggest boost to your 1% lows with a newer CPU though the averages also see a boost with the 12/13 series CPU's which is quite substantial in some titles, in general you could see a boost of 20%+ FPS with a CPU upgrade even at 4k, whether it's worth the $ as you would have to invest in not just a new CPU but motherboard and likely RAM also that is down to you, but yes, at 4K with a 4090 and a newer 13th gen/Ryzen 7*x3D you will get a pretty hefty uplift in lows and averages in some games as you are currently CPU bound, is it worth a $600-$800 investment, only you can answer that question, anyone saying at 4k the CPU doesn't matter is wrong, in a lot of scenarios 1% FPS and even averages are higher with the newer platforms
IMO 7800x3D would be a perfect upgrade and let your 4090 stretch it's legs as much as it could
Yes, quite substantial in some games and on par/not noticeable in others, but this is likely where your bottleneck is coming into play
1,576 (0.23/day)
The Gulag Casino
System Name ROG 7900X3d By purecain
Processor AMD Ryzen 7 7900X3D
Motherboard ASUS Crosshair X670E Hero
Cooling Noctua NH U12A
Memory 64Gb G.Skill Trident Z5 neo RGB 6400@6000mhz@1.41v
Video Card(s) Aorus RTX4090 Extreme Waterforce
Storage 990Pro2Tb-1TbSamsung Evo M.2/ 2TbSamsung QVO/ 1TbSamsung Evo780/ 120gbKingston Now
Display(s) LG 65UN85006LA 65" Smart 4K Ultra HD HDR LED TV
Case Thermaltake CoreX71 Limited Edition Etched Tempered Glass Door
Audio Device(s) On board/NIcomplete audio 6
Power Supply Seasonic FOCUS 1000w 80+
Mouse M65 RGB Elite
Keyboard K95 RGB Platinum
Software Windows11pro
Benchmark Scores [url=https://valid.x86.fr/gtle1y][img]https://valid.x86.fr/cache/banner/gtle1y-6.png[/img][/url]
I went with an X3D chip and stayed with AM4 initially. From a 5950x 32thread monster down to 16 threads and 8cores. It gave me a 10fps boost at 4k. Thats close to what I'd get from a gpu upgrade.
I then went to a 7800X3D and AM5, this gave me another 10fps, the 9800X3D offers up to a 30fps gain. Thats the same as a GPU upgrade so you should make certain to go with the advice above and get a 9800X3D.
The only reason I can think of for holding off, apart from waiting for prices to fall in a yr or so. Is to see how the 9950X3D handles games. If the 9950X3D is clocked a lot higher and there are no latency or scheduling issues this time^^, we should expect maybe up to another 10-15fps. So this is a massive jump for the 9000X3D series. We are really being spoiled this year and next year could be the same again.
Very interesting times to be a system builder.
Low quality post by rotofly
rotofly
4 (0.08/day)
I am still an expert and I do not have this card. I only have information about this card. Everyone is cheated by China.:kookoo: mad
mrgpumaniac
5 (5.00/day)
When i was testing my previous pc ( currently not have ) with Rtx 4090 and 14900K and DDR5 on 1440P i was comparing my results with other users on youtube. And it was ok. Maybe try on youtube to check.
