Help With Throttlestop My 10750H is Hitting 120 Watts and Overriding My Power Limits!!!
27 (0.02/day)
i need help, i have a unlocked bios so, i can search some options in it.
120 watts are unsustainable for my laptop
409 (0.26/day)
System Name Old friend
Processor 3550 Ivy Bridge x 39.0 Multiplier
Memory 2x8GB 2400 RipjawsX
Video Card(s) 1070 Gaming X
Storage BX100 500GB
Display(s) 27" QHD VA Curved @120Hz
Power Supply Platinum 650W
Mouse Light² 200
Keyboard G610 Red
Set "Maximum processor state" to 99%. Hope this helps.
409 (0.26/day)
Storage BX100 500GB
Mouse Light² 200
Keyboard G610 Red
Check "Disable Turbo" on the left.
13,783 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
it keeps ignoring the limits
maybe its an error from throttlestop?
Highly unlikely.
I have requested this be moved by a Mod to the correct Throttlestop section so the author of that software can have a look at the issue.
27 (0.02/day)
the average power consumption is lower but the spikes still hitting 80 - 90 watts
Highly unlikely.
I didn't use techpoweup for a while, I didn't know there was a section for throttlestop, thank you very much
1,136 (0.17/day)
Malaysia
Motherboard ASUS A520M-K
Display(s) AOpen 27HC5R 27" 1080p 165Hz
Case COUGAR MX440 Mesh RGB
Audio Device(s) Creative X-Fi Titanium HD + Kurtzweil KS-40A bookshelf
Power Supply Corsair CX750M
Click FIVR, unlock voltage control and undervolt it. Start small, like -5 to -10mV on adaptive voltage
unclewebb
7,750 (1.31/day)
In the TPL window check the MMIO Lock box. Clear the Sync MMIO box. Try checking both Clamp boxes in the Power Limit Controls section to enforce the requested power limits.
Check the Ring Down Bin box in the FIVR window and always leave the Windows Max processor state at 100%.
unclewebb
7,750 (1.31/day)
Тurn on SpeedStep
When Speed Shift (SST) is enabled, the older SpeedStep is not used. Having SpeedStep enabled or not makes no difference.
@proooo
After you check the Short Power PL2 Clamp box, attach a log file if you are still having problems.
27 (0.02/day)
@proooo
I did what you told me and it keeps hitting 100w, i used occt and here is the log.
i hope the log is useful.
  • 2024-07-28.txt
unclewebb
7,750 (1.31/day)
The log is very useful. Instead of posting an image of a log file, just attach the log file in its original .txt format. That makes it easier to scroll through the whole thing.
The log file shows that the 60W power limit is being enforced the majority of the time. Try checking the MMIO Lock box in the TPL window like I previously suggested. Also check the Lock box in the Power Limit Controls section. Locking both the MMIO and MSR limits might help fix the problem.
Do not check the More Data box when logging data. Power consumption is not read directly from the CPU. When you increase the monitoring frequency and shorten the amount of time that power consumption data is calculated, you will end up with a larger amount of error. The 100W peak for 1/8th of a second looks mostly like monitoring error to me.
745 (1.25/day)
System Name Asus G16
Processor i9 13980HX
Motherboard Asus motherboard
Cooling 2 fans
Memory 32gb 5600mhz cl40
Video Card(s) 4080 laptop
Storage 16tb, x2 8tb SSD
Display(s) QHD+ 16:10 (2560x1600, WQXGA) 240hz
Power Supply 330w psu
What model laptop is it?
27 (0.02/day)
it's an ideapad gaming 3 15imh05.
i disabled more data and the readings are normal now, but now it turned off completely, I think it's some damage to my cpu :(
I still really appreciate trying to help me, if I discover something I will post it.
Thank you very much unclewebb.
1,136 (0.17/day)
Malaysia
Don't worry about it if your CPU is damaged you probably won't be able to boot your laptop
27 (0.02/day)
I fixed it xd, i disabled this option on bios and my cpu looks good again
unclewebb
7,750 (1.31/day)
Intel Dynamic Tuning and ThrottleStop can fight each other over control of your CPU. That might have been causing those brief power peaks.
409 (0.26/day)
Storage BX100 500GB
Mouse Light² 200
Keyboard G610 Red
Excellent! Glad to hear it! Thanks for letting us know!
847 (0.59/day)
System Name ASUS TUF F15
Processor Intel Core i5-10300H
Motherboard ASUS FX506LHB
Cooling Laptop built-in cooling lol
Memory 24GB @ 2933 Dual Channel
Video Card(s) Intel UHD & Nvidia GTX 1650 Mobile
Storage Adata XPG SX8200 Pro 512 GB & WD Blue SN550 500 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH 2.1-channel
Power Supply ASUS 180W PSU (from more powerful ASUS TUF DASH F15 lol)
Mouse Logitech G604
Keyboard SteelSeries Apex 7 TKL
Software Windows 10 Enterprise 21H2 LTSC
View attachment 356627View attachment 356626
disable turbo or/and disable HT. You may laugh but laptop has bad cooling so it's stupid to think that powerful multicore CPU will push the limits like desktop one with big tower cooler or AIO.
27 (0.02/day)
After a few days of testing I can say that everything works well, it is solved, I guess this concludes the thread, I hope that one day this information will be useful.
