High PCIe Slot Power Draw Costs RX 480 PCI-SIG Integrator Listing
511 (0.08/day)
DK
System Name Main setup
Processor i9 12900K
Motherboard Gigabyte z690 Gaming X
Cooling Water
Memory Kingston 32GB 5200@cl30
Video Card(s) Asus Tuf RTS 4090
Storage Adata SX8200 PRO 1 adn 2 TB, Samsung 960EVO, Crucial MX300 750GB Limited edition
Display(s) HP "cheapass" 34" 3440x1440
Case CM H500P Mesh
Audio Device(s) Logitech G933
Power Supply Corsair RX850i
Mouse G502
Keyboard SteelSeries Apex Pro
Software W11
but that IS in PCI-SIG spec. 2x8 pin, with the PCIe connector, are good for 375 watt.
And it is stamped OK as a standard by PCI-SIG ? last time i was reading about it the 2x8 wasnt a standard in their papers, but it is maybe ½ a year ago so it could have changed.
The reason for not putting the 8pin is 1. bad design not knowing the total power draw of a full card. or 2. it will look bad that their "medium" graphic card is needing one 8pin power connector when other brands are only using one 6 pin.
And yes with the fix it is still not compliant it is 75 Watt from the slot and 75watt from 6 pin, not 84Watt from the 6 pin.
4,197 (0.95/day)
System Name Skunkworks 3.0
Processor 5800x3d
Motherboard x570 unify
Cooling Noctua NH-U12A
Memory 32GB 3600 mhz
Display(s) Asus 1440p144 27"
Mouse *squeak*
Software Manjaro
It may not be a "standard" configuration, but the complaint is that AMD is going above the max rated power draw for the connectors. The 2x8 pin+slot setup doesnt do that.
511 (0.08/day)
DK
Processor i9 12900K
Cooling Water
Case CM H500P Mesh
Mouse G502
Software W11
Thats right... so there is no problem with it, it is just missing the PCI Express Catification logo :)
This is from wiki so no guarantees:
"Some cards are using two 8-pin connectors, but this has not been standardized yet, therefore such cards must not carry the official PCI Express logo. This configuration would allow 375 W total (1×75 W + 2×150 W) and will likely be standardized by PCI-SIG with the PCI Express 4.0 standard."
5,966 (0.94/day)
New York
Processor AMD Ryzen 9 9900x, Ryzen 9 5980HX
Motherboard Gigabyte B850 Gaming X
Cooling Be Quiet Dark Rock Pro 4(With Noctua Fans)
Memory 128GB Crucial Pro 6400
Video Card(s) Gigabyte RTX 3080, Asus 6800M
Storage Adata SX8200 1TB NVME/WD Black 1TB NVME
Display(s) Dell 27 Inch 165Hz
Case Lian Li A3 Mini
Audio Device(s) IFI Zen Dac/JDS Labs Atom+/SMSL Amp+Rivers Audio
Mouse Logitech G502 SE Hero
Keyboard Corsair K70 RGB Mk.2
VR HMD Samsung Odyssey Plus/ Quest 3
Im Rahmen des derzeit stattfindenden IDF (Intel Developer Forum) erklärte Al Yanes, der Präsident der PCI-SIG, nun im Gespräch mit c't, dass die beiden augenscheinlich konträren Standpunkte sehr wohl zusammenpassen: Innerhalb der festgelegten Konformitätstests gibt es schlicht keinen Subtest, der die Einhaltung der vorgeschriebenen Stromaufnahme überprüft. Dieser Sachverhalt erklärt auch, warum manch andere Grafikkarten mitunter mehr Saft aus ihren zusätzlichen Stromsteckern ziehen als eigentlich zulässig.
This clears up some things though, the president of PCI-SIG said that they don't test slot power draw in their own testing even though the standard/requirements they put out says that its supposed to be enforced.
. . . . . . .I don't even know what to say about that.
14,345 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
That makes sense to me, they draw up the standard and certify that components comply.
It should be up to manufacturers to ensure they comply to qualify.
It's no different than automobile manufacturers conducting their own crash tests for compliance in that standard.
qubit
Overclocked quantum bit
17,865 (2.84/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
This power problem was fixed with a driver update a little while ago so why is it still an issue?
2,516 (0.47/day)
Canada
And yet, nVidia is still selling 970s as '4Gb' RAM and 64?? ROPs...
Funny how that works, eh.
511 (0.08/day)
DK
Processor i9 12900K
Cooling Water
Case CM H500P Mesh
Mouse G502
Software W11
As i wrote earlier...
"And yes with the fix it is still not compliant it is 75 Watt from the slot and 75watt from 6 pin, not 84Watt from the 6 pin."
Regarding the 970:
It has 4GB memory the issue is that the last 0.5gb is not full speed (can't figure out if it is the total 4GB that is slowed down or only the 0.5gb??)
2,744 (0.54/day)
Greece
Motherboard MSI B550 Tomahawk
Cooling ZALMAN CNPS9X OPTIMA
Case SHARKOON M25-W 7.1 BLACK
Keyboard Trust GXT280
:roll::roll::roll::roll::roll::roll::roll::roll::roll::roll::roll::roll::roll::roll:
Too little too late!
They make a topic out of something non-existant atm and didn't notice once it was at least existant.
Ridiculous announcement by them (not TPU) to sum it up...
qubit
17,865 (2.84/day)
Quantum Well UK
Keyboard Yes
I remember the fix being tested by various tech sites which made the card compliant.
Everton Souza
1 (0.00/day)
Regarding the 970:
Gonna try to help on this one.
3,5 gb - 224 bit bus
0,5 gb - 32 bit bus
So compared to a 980 all memory access is slower. You only uses/gets the advertised 256 bit memory bus when accessing data from faster "partition" and slower one at the same time.
511 (0.08/day)
DK
Processor i9 12900K
Cooling Water
Case CM H500P Mesh
Mouse G502
Software W11
TPU test dosn't show that. there is still to high draw from the 6pin (84Watt).
https://www.techpowerup.com/img/16-07-08/rx-480-pcie-fix-power.jpg
OK
Again from Wiki so.....
For accessing its memory, the GTX 970 stripes data across 7 of its 8 32-bit physical memory lanes, at 196 GB/s. The last 1/8 of its memory (0.5 GiB on a 4 GiB card) is accessed on a non-interleaved solitary 32-bit connection at 28 GB/s, one seventh the speed of the rest of the memory space. Because this smaller memory pool uses the same connection as the 7th lane to the larger main pool, it contends with accesses to the larger block reducing the effective memory bandwidth not adding to it as an independent connection could
5,966 (0.94/day)
New York
OK
its still ok the 6 pin is overly robust and the spec should be changed to accommodate that 84W is perfectly fine.
and what does this have to do with the 970, . . . . I miss something?
853 (0.14/day)
Pacific Coast
System Name Z77 Rev. 1
Processor Intel Core i7 3770K
Motherboard ASRock Z77 Extreme4
Cooling Water Cooling
Memory 2x G.Skill F3-2400C10D-16GTX
Video Card(s) EVGA GTX 1080
Storage Samsung 850 Pro
Display(s) Samsung 28" UE590 UHD
Case Silverstone TJ07
Power Supply Seasonic PRIME 600W Titanium
Mouse EVGA TORQ X10
Keyboard Leopold Tenkeyless
Benchmark Scores 3DMark Time Spy: 7695
"The list is compiled for hardware devices implementing the various PCI-Express specifications to the letter."
right.. spikes in the power draw don't count I imagine..
You mean RMS? Yes, they are using RMS rating like all other power companies, utilities, and applications do.
http://practicalphysics.org/explaining-rms-voltage-and-current.html
RMS:
In statistics and its applications, the root mean square (abbreviated RMSor rms) is defined as the square root of mean square (the arithmetic mean of the squares of a set of numbers).
Just because some site created a video with an oscilloscope and then provided a convoluted method of filtering and talked about spikes doesn't make you all the sudden smarter than the industry.
4,357 (0.88/day)
Mexico
System Name Dell-y Driver
Processor Core i5-10400
Motherboard Asrock H410M-HVS
Cooling Intel 95w stock cooler
Memory 2x8 A-DATA 2999Mhz DDR4
Video Card(s) UHD 630
Storage 1TB WD Green M.2 - 4TB Seagate Barracuda
Display(s) Asus PA248 1920x1200 IPS
Case Dell Vostro 270S case
Power Supply Dell 220w
Software Windows 10 64bit
mmm well this means that Dell XPS and Alienware PCs will surely sport an RX 470 instead... maybe Sapphire will have to churn out some "reference" 470s for them.
2,744 (0.54/day)
Greece
Wrong. Both in EU and US there are seperate organisations for crash-testing vehicles with their own standards. Car manufacturers try to comply with those tests by simulating them nowadays on computers or in prevous decades by crash-testing pre-production cars to be sure they wouldn't fail when the official test was conducted. :toast:
32 (0.01/day)
FYI the 1080 is not there. Neither are the 1070 and 1060. The 470 and 460 are also missing.
nvm they are listed by the chip name. Which is silly because the chip is not the entire gpu+board...
Wondering what this list really is. Because you would expect several versions of each chip to correlate with the board design, but for everything there is only one listed.
Lots of cards are missing.
1,959 (0.26/day)
The Kingdom of Norway
Processor Ryzen 5900X
Motherboard Gigabyte B550I AORUS PRO AX 1.1
Cooling Noctua NB-U12A
Memory 2x 32GB Fury DDR4 3200mhz
Video Card(s) PowerColor Radeon 7800 XT Hellhound
Storage Kingston FURY Renegade 2TB PCIe 4.0
Display(s) 2x Dell U2412M
Case Phanteks P400A
Audio Device(s) Hifimediy Sabre 9018 USB DAC
Power Supply Corsair AX850 (from 2012)
Software Windows 10?
Not at all, but still nice to see that there is consequences, and AGAIN it still just show how bad AMD design department is...... why didn't they just put a 8pin from the start.... Swallow that less than 150W pride suckers.... :)
lol didnt the geforce 750ti or 950 or something do the exact same thing
511 (0.08/day)
DK
Processor i9 12900K
Cooling Water
Case CM H500P Mesh
Mouse G502
Software W11
hmm I'm a RED kinda guy, so I don't know OLD Nvidia Tech, but I know for sure that my living on the RED is long gone, so my new GFX is going to be a 1080... I had hops for the RED team but let me just say i'm really disappointed..... they could have done much better just rebranding the 290 again and make it in 14nm FinFET.
But that is just my opinion.
32 (0.01/day)
You can't rebrand a GPu and make it on a smaller process.
and if you are looking at a 1080 why on earth do you care about a 290 rebrand instead of a 480? At best you should be saying vega is taking forever.
872 (0.14/day)
Copenhagen, Denmark
System Name Ryzen/Laptop/htpc
Processor R9 3900X/i7 6700HQ/i7 2600
Motherboard AsRock X470 Taichi/Acer/ Gigabyte H77M
Cooling Corsair H115i pro with 2 Noctua NF-A14 chromax/OEM/Noctua NH-L12i
Memory G.Skill Trident Z 32GB @3200/16GB DDR4 2666 HyperX impact/24GB
Video Card(s) TUL Red Dragon Vega 56/Intel HD 530 - GTX 950m/ 970 GTX
Storage 970pro NVMe 512GB,Samsung 860evo 1TB, 3x4TB WD gold/Transcend 830s, 1TB Toshiba/Adata 256GB + 1TB WD
Display(s) Philips FTV 32 inch + Dell 2407WFP-HC/OEM/Sony KDL-42W828B
Case Phanteks Enthoo Luxe/Acer Barebone/Enermax
Audio Device(s) SoundBlasterX AE-5 (Dell A525)(HyperX Cloud Alpha)/mojo/soundblaster xfi gamer
Power Supply Seasonic focus+ 850 platinum (SSR-850PX)/165 Watt power brick/Enermax 650W
Mouse G502 Hero/M705 Marathon/G305 Hero Lightspeed
Keyboard G19/oem/Steelseries Apex 300
Software Win10 pro 64bit
RMS:
couldn't find anything confirming what you said. furthermore, i find this whole story a bit shady, i mean, first they have the rating then they dont.. its a load of bs if you ask me.
1,959 (0.26/day)
Case Phanteks P400A
GTX 1060 isnt even on the list...
qubit
17,865 (2.84/day)
Quantum Well UK
Keyboard Yes
You're taking that graph out of context.
Here's the last paragraph of the conclusion which says that it's fixed (heck the title of the article says it's fixed) especially with compatibility mode which maxes it out at 73W. Without compatibility mode it averages 76W with peaks of 79W which is what the graph you linked to shows and isn't a problem for all but the crappiest of motherboards.
Here you can see that the new driver adds about 2.3% performance, which is a pretty decent improvement. Once you enable Compatibility Mode though, performance goes down slightly below the original result (0.8% lower), which means Compatibility Mode costs you around 3%, in case you really want to use it. I do not recommend using Compatibility Mode, personally I don't think anyone with a somewhat modern computer would have run into any issues due to the increased power draw in the first place, neither did AMD. It is good to see that AMD still chose to address the problem, and solved it fully, in a good way, and quick.
And here's the link if you wanna read the whole thing in context: https://www.techpowerup.com/223981/amd-releases-pci-express-power-draw-fix-we-tested-confirmed-works
