High RX 6750 XT hotspot temps?
Dave1
2 (0.00/day)
Hey guys,
Just got my Gigabyte Gaming OC RX 6750 XT back from RMA, and I'm very wary of this card as it has given me some black screen issues and I think I am close to running out of having any right to get this resolved.
After I start 3DMark Time Spy, or stress the GPU in any other similar way, the hotspot temperature will immediately jump to above 110C and remain around 110C (above and below) for the entirety of the time it's being stressed. I have attached a screenshot of my temps about 2 seconds after the 3DMark Time Spy benchmark started.
The GPU temp itself stays pretty low.
This isn't normal, right? I'm not sure if I'm being paranoid, as it performs better than average in 3DMark, and doesn't seem to be throttling too severely (although it is throttling somewhat).
What's the way forward? Get a refund and go for a 7700 XT or something (I think I can get one)? Trust Gigabyte with a second RMA? Or am I just being totally paranoid?
I would really appreciate some advice!
729 (1.13/day)
Processor Ryzen 5700x
Motherboard Gigabyte Auros Elite AX V2
Cooling Thermalright Peerless Assassin SE White
Memory TeamGroup T-Force Delta RGB 32GB 3600Mhz
Video Card(s) PowerColor Red Dragon Rx 6800
Storage Fanxiang S660 1TB, Fanxiang S500 Pro 1TB, BraveEagle 240GB SSD, 2TB Seagate HDD
Case Corsair 4000D White
Power Supply Corsair RM750x SHIFT
It doesn't really correlate with the GPU temp, usually at load you will only find a 20c or so difference between GPU and hotspot, I personally wouldn't be happy running it with that high of a hotspot temp, the fact it happens as soon as any kind of load is applied as well is odd, could well be a faulty sensor reading, though I'd still be inclined to return it and go for the 7700xt
14,279 (6.43/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
No, it's not normal. It's terrible.
Hotspot around 100-105 °C with GPU temp not far behind is ok, but in your case, there's a 50 °C delta between the two, which means there are parts of the GPU die that don't come into contact with the cooler due to bad thermal paste application or mounting pressure.
I'd RMA it straight away.
Ruru
S.T.A.R.S.
13,335 (3.00/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
Too much.
Exactly. 50C delta is a clear indicator that something's not fine under the cooler.
234 (0.10/day)
Processor Intel i5-13600KF
Motherboard ASRock Z790 PG Lightning
Cooling NZXT Kraken 240
Memory Corsair Vengeance DDR5 6400
Video Card(s) XFX RX 7800 XT
Storage Samsung 990 Pro 2 TB + Samsung 860 EVO 1TB
Display(s) Dell S2721DGF 165Hz
Case Fractal Meshify C
Power Supply Seasonic Focus 750
Mouse Logitech G502 HERO
Keyboard Logitech G512
this card as it has given me some black screen issues...I am close to running out of having any right to get this resolved.
That's a tough spot. You could try a couple things to get a better handle on the problem.
Try taking the side off you case, and maybe even blowing a fan on the whole system. If temps improve a lot then you probably need more airflow.
Try reducing the power limit by 5 or 10 percent and see what happens. If you still have a big delta maybe it's bad contact.
Maybe it's a wonky sensor.
How serious are your black screen issues, and can you reproduce them?
If you send it back and it passes tests and "GPU temp itself stays pretty low" and "performs better than average" what should they do?
That delta does look crazy and my buddy has a couple of these gigabyte 6750 cards in fairly small cases and he's not noticed anything like this.
14,279 (6.43/day)
Midlands, UK
Cooling Yes
Storage A lot
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
It's not gonna help. GPU temperature is extremely low already, and the card is throttling itself to keep hotspot within 110 °C. It's definitely a contact issue. RMA.
116 (0.05/day)
Processor Ryzen 5800X3D
Motherboard AsRock B550 Velocita
Cooling Noctua NH-D15S
Memory 2x16GB DDR4 Corsair Vengeance
Video Card(s) Sapphire 7900XT Nitro+
Storage 1TB+1TB NVME Drives
Display(s) Alienware AW3423DWF
Case Lian Li LanCool 3
Power Supply Seasonic Bronze 850W
Mouse Razer Basilisk Ultimate
Keyboard Razer Huntsman V2 Analog
VR HMD Oculus Quest 2
Software Windows 11 Pro 64bit
I have a 6750XT in a computer and its Gigabyte and it behaves the same. It still works after 2-3 years or so ... I think its a problem with their heatsink design/manufacturing.
2,218 (0.43/day)
Repaste it. (Properly)
A good repaste or good thermal compound can make 10 degree difference in between core and hotspot.
Hotspot = hottest area of the GPU.
462 (0.10/day)
France
Processor i7 12700K
Motherboard MSI PRO Z690-A WIFI DDR4
Cooling Noctua NH-U14S
Memory G.Skill Ripjaws V 32GB 4400Mhz CL19 1T
Video Card(s) AMD Radeon 6700 XT
Storage 970 EVO 250GB|Crucial m4 128GB|MX300 525GB|MX500 1TB|PNY XLR8 2TB|Kingston NV2 2TB|14TB HDD|4TB HDD
Display(s) Acer XG270HU 27" 1440p 144Hz
Case Fractal Design DEFINE R4 Black Pearl Window
Mouse Razer Naga Trinity
Keyboard EVGA Z15 RGB Mechanical Gaming Keyboard
My 6700XT from AMD (not custom) shows like a 2 to 8 degrees difference between the GPU temp and the hotspot temp.
Ok the 6750XT is hotter due to higher clocks and all but your card shouldn't have like a 50+ degrees difference between the GPU temp and the hotspot.
Did you try to clean install the drivers (using the AMD cleaner) and check again ? Maybe it's a drivers' bug.
If it's not, RMA while you can. There might be something wrong, either the probes (sensors) or the cooler.
116 (0.05/day)
Another very stupid way fix throttling is true morepowertool to disable hot spot throttling :D (if the probes are bad - the temp is off by huge margin ... if they are not bad then you will fry the gpu)
DOHCtor
11 (0.04/day)
I'm on the exact same boat with that same Gigabyte card.. (Gaming OC 6750XT)
..and this is my Sapphire Pulse 6800XT..
..both running with a maxed out fan for comparaison's sake.
9,730 (3.46/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
You have to take the card apart and apply more TP. That is a common problem with all Gigabyte cards. The first time I saw it was the Vega 64 and the next time was the 6500XT and it was the exact same issue. The shrouds are too big to give that temp variation.
DOHCtor
11 (0.04/day)
Well cooler screws were loose so i tried tighten em' back first. If it fails...
Edit. It failed..
9,730 (3.46/day)
Cooling In Win SR36
462 (0.10/day)
France
Processor i7 12700K
Send those screenshots to the Gigabyte support when applying for RMA.
For you to know, my 1080Ti was from Gigabyte and it just died 3 years after I bought it. Bad luck maybe but out or the RMA window for me...
Just don't try your luck if you can just get your hardware replaced.
DOHCtor
11 (0.04/day)
Hmmm.. maybe the cooler just sucks on that card... or the paste had dried out..
462 (0.10/day)
France
Processor i7 12700K
9,730 (3.46/day)
Cooling In Win SR36
DOHCtor
11 (0.04/day)
Survey says... Cooler sucks!!!
The paste in the ribs is the problem.
I'd say the ribs are the problem... where there is a rib there is a void where there are no contact made with the chip. Who knows, maybe after a day or 2 the paste will get "hot" and temps will improve.. i've seen it in the past. Like it thins out and contact improves..
Will report back in a day or 2.
Anyway, if it's still possible to get the hardware replaced when there is an issue, just get it replaced. If not, yeah ok try to do things and...blacklist Gigabyte maybe xD
Well, Gigabyte are kind of hit or miss here. My previous 2 HD7950 still works flawlessly even if one of the fans in one of those kicked the bucked long ago.. As for the 6750XT, it works fine... When it's not overheating... Still, it sees a lot less action now that i also have a 6800XT..
Funny thing is, when the card is not loaded, the temps are the most stable you'll ever see. But apply a load on it and....
Moral of the story. Until they improve their Coolers, Gigabyte will be firmly established in the "entry level" category in my mind..
9,730 (3.46/day)
Cooling In Win SR36
Trust me just take the 8 screws out and apply a thick application of Tp. That way if the ribs suck up some the Core will still have some to keep the heat in check.. That is why Gigabyte cards are cheaper. Next time I would recommend gettign As Rock the next time. They rival the price as well.
462 (0.10/day)
France
Processor i7 12700K
If your warranty window is passed, maybe find another cooler, it could be better than trying to fix the impossible. Thermal paste doesn't do magic if everything is wrong with the cooling system.
I will just blacklist Gigabyte for the next 20 years. I had a good motherboard but after few years it began unstable, my 800+€ 1080Ti died in 3 years...yeah this brand just stinks hard.
If you can RMA, do it. Maybe sell the replaced hardware just when you get it and go buy anything else. If you can't, yeah, thermal paste but still, you would see if every crucial components are safe under the cooling system or not. Back in the old days, there were brands making cheap air GPU cooling systems but this time is over, sadly.
DOHCtor
11 (0.04/day)
Well, i repasted it as it seems Kapone allready had good luck repasting Gigabyte cards. Plus, i had some paste around and it only took about 15 minutes. Easy peasy. Unfortunately for OP and less so for me, that cards cooler sucks and repasting it won't do miracles. Right now, we know that.. Case is closed.
462 (0.10/day)
France
Processor i7 12700K
I'm glad you managed to fix it then =)
I hope you would have a better luck next time your get to buy a Gigabyte product.
DOHCtor
11 (0.04/day)
Wasn't "malfunctioning" per se.. and it seems working okay-ish now. The temps are horrible but as we now know, it's the nature of the beast.
2,585 (0.53/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Case Corsair 275R
Mouse Logitech G Pro (Hero)
And I thought my GPU core temps were bad! (very high delta)
Mine are normally something like this:
43C GPU 73C GPU hotspot (it often will reach 78C)
On my Sapphire Nitro+ RX 6750 XT.
At least the final sum isn't bad like yours. I haven't seen it reach 90C. Wonder if it's the GPU Vcore being at 1200mV?! Should I undervolt?
Those are the temps I get at 2.9 GHz.
