Hot Temps for 5800X3D
freeagent
9,508 (4.09/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Honestly it is one the coolest running chips I have owned. Though my chip is one of the early ones.. so I dunno..
329 (0.87/day)
Mile High City
System Name Keds
Processor 5600X3D
Motherboard Gigabyte X470 AORUS ULTRA GAMING
Cooling Corsair H100i
Memory 32 GB Team Force DDR4 3200 CL16
Video Card(s) Power Color RX 7900 XT Red Devil
Storage 2x 1TB SSD / NVME
Display(s) AOpen 27in 1440p 170hz (27HC5UR)
Case Modified Corsair 540 Air
Audio Device(s) Logitech G35 / Corsair HS80
Power Supply EVGA 850GQ
Mouse Corsair M65
Keyboard Corsair Strafe Silent
Software Win 11 Home (Modded)
Benchmark Scores It will beat a snail in a down hill race.
I have a 5600X3D and it runs hot, if I dont undervolt it with PBO Tuner2.. -20 is what I am using on all core and its never goes over 75c on full cinebench load with a really old AOI set to silent mode. 240mm H100i the original H100i.
It normally runs in the 50s low 60s while gaming..
1,083 (1.61/day)
Processor Ryzen 7800x3d
Motherboard Asus B650e-F Strix
Cooling Corsair H150i Pro
Memory Gskill 32gb 6000 mhz cl30
Video Card(s) RTX 4090 Gaming OC
Storage Samsung 980 pro 2tb, Samsung 860 evo 500gb, Samsung 850 evo 1tb, Samsung 860 evo 4tb
Display(s) Acer XB321HK
Case Coolermaster Cosmos 2
Audio Device(s) Creative SB X-Fi 5.1 Pro + Logitech Z560
Power Supply Corsair AX1200i
Mouse Logitech G700s
Keyboard Logitech G710+
Software Win10 pro
Hard to cool, not hot. Big difference.
Its the heat density, not the heat output - bigger coolers wont do a thing, but better thermal paste or better contact will change temperatures massively.
That, and i find pump speed makes a big difference.
329 (0.87/day)
Mile High City
System Name Keds
Processor 5600X3D
Mouse Corsair M65
Pump speed does in deed.. I have mine running full tilt.. but then dont have to have the fans up very high since it is running to fast. I do miss my open loop for how quiet the system was.
freeagent
9,508 (4.09/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Thermalright will change your lives.
329 (0.87/day)
Mile High City
System Name Keds
Processor 5600X3D
Mouse Corsair M65
Yeah.. not with fan noise, no air cooler will ever change my mind on that.
1,083 (1.61/day)
Software Win10 pro
Yeah, i find my system very quiet though - was the primary goal. Everything is undervolted, and cpu limited to 70c in bios - pump running at 1000 rpm, and the noctua a12 fans at 800 rpm. Barely audioable :)
freeagent
9,508 (4.09/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
1,083 (1.61/day)
Software Win10 pro
freeagent
9,508 (4.09/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Im honestly willing to take that bet.
That is your setup in your system specs?
Edit:
Mine is in my sig.
I can return my case setup to it stock form, only its 2 stock fans up front and be ok.
I can also run perfectly fine with no fans on my cooler, so it would be semi passive..
1,083 (1.61/day)
Software Win10 pro
freeagent
9,508 (4.09/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
329 (0.87/day)
Mile High City
System Name Keds
Processor 5600X3D
Mouse Corsair M65
Betcha you're system is louder than mine :D
Its current set up.. yeah.. probably is..
My open loop, 360 and a 240, SP fans, had them hard set to 900 rpm. Could only tell the damn system on on because the LEDs on the fans. Temp never exceeded 45C CPU or GPU. Was a 5820k clocked at 4.6ghs and a GTX 1080 with its nuts in a vice.
freeagent
9,508 (4.09/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
It is all good my man, it was all in jest anyways :)
But.. I can get this thing to be freakishly quiet if I take out the fans. I just don't like my ram and my GPU to get warm.. and a silent computer really is freaky. I don't think I like the silence.
Deleted member 229121
Preach GIF
I spent exactly half of what my NH-U12A Chromax cost on a PA-120 Black and knocked a full 10c off in R23 @ 72c.
Could probably get it a little lower too, this is with NF-A12s @ 1700 rpm (they were full send on the U12-A).
5,454 (0.89/day)
Australia
It is indeed a hot running chip, but ive yet to run a heat gun over it to see if the readings are actually true but I was able to get my 5800X3D from 90c down to 80c on a smaller U9S Cooler with a redo in thermal compound, changing the fan position slightly adding a second fan and doing the -30 offset.
Mussels
Freshwater Moderator
58,413 (7.87/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
I've had air coolers (dark rock slim) out perform custom water loops. They're fussy with how coolers are mounted, rather than needing bigger coolers.
I sold that dark rock slim, and i'm still sad about it.
sfjuocekr
9 (0.02/day)
Just going to debunk this "CO" being an undervolt, it is not.
The DLDO is a Digital Low DropOut regulator, PSM stands for Pulse Skip Mode. CO aka Curve Optimizer sets DLDO PSM Margin... this tells the regulator how far it can overshoot or undershoot under load changes.
If you run your CPU at CO -30 and apply load, it will first undershoot because your margin is set low and then slowly increase to the point where it wants to run at given the power limits you set.
So for example, if you set your 5800X3D at 115/95/95 it will boost all the way up to 4450 on all cores and run it with CO 0... it will first overshoot its voltage and then lower it as the frequency changes. If you run it with -30 it will undershoot the voltage as the frequency changes and creep up to meet the power limit. In BOTH situations my (your) CPU will run at 1.216v... because that is what needs to stay at that load and it is allowed to reach that because 115 = 95 * 1.2... math never fails.
I also see a lot of false "overclocking" screenshots, where they show CPU-Z doing a multiplier * FCLK... this is SO WRONG. If you increase the FCLK past 100 your CPU will NOT increase its multiplier past 44. You CAN NOT overclock this CPU using a FCLK increase and assume it reaches the 44.5 multiplier in an all core load. It simply DOES NOT DO THAT, the SMU will NOT allow you to do it.
If anyone can prove me wrong, try me and show me a screenshot where you are running at that multiplier with your set FCLK. Also show me a CB23 result, because on average the 5800X3D my CPU scores 14.6k and I have yet to see a valid overclock claim score more than 15k... until then, everyone is full of it.
I have tried to fiddle with the SMU a LOT, if you write any value but 45.5 to the max multiplier register... your CPU will run at 3400 MHz. So this tells me there is a hard limit that the SMU controls, which is completely independent of used platform firmware.
The two screenshots below are from CB23, the first one is from last year and the second one is from today. These run are done on Ubuntu Linux, running CB23 in WINE and there are four VM's running in the background. Temperatures stay in the mid 70'ties. I have seen written testimonials where people claim to have reached over 15k, but again these are still stock and not overclocked at all.
Also regarding temperature, the measurements are made near the CPU cores themselves and there is a piece of insulation slapped on top. This cache sees a gradient of heat, but there does not seem to be anything to measure it. There is another sensor that measures the "package" or SoC temperature, under full load mine rarely reaches 40 degrees and when I touch my CPU block... that temperature seems to be about right as it is warm to the touch. Removing the load also confirms this, as it dives below 40 degrees immediately. So in my opinion, saying the heat density is greater is wrong. The measurement we read is simply made at a location where the most heat is... as it should. A 1g/cm2 coin at 100 degrees compared to a 2g/cm2 coin at 100 degrees equals 100 degrees regardless of density.
freeagent
9,508 (4.09/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
CO is not an undervolt at all, as it pushes clocks up. It only turns into an undervolt when you don’t have the power to back it up, leading it to starve. I am at work right now but I would love to pick this apart just a little more :)
3,383 (1.68/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Wouldn't there be a difference in the amount of wattage needed to heat two different coins to the same temperature of two different masses right? Doesn't that invalidate this quoted point?
sfjuocekr
9 (0.02/day)
No that is not what it does.
Like I tried to explain, CO aka Curve Optimizer changes the DLDO PSM Margin. It responds to load changes based on a TLD (Transient Load Detector) and tries to quickly regulate (that is what a DLDO does) the voltage up to what is requested.
For voltage regulators basic electronics are still true: P = U * I
So if you set a current limit at 95 with a given voltage you can not exceed the power target, in my example 115. Increasing the PPT beyond that point does nothing.
Also adding two screenshots to show the behavior of FCLK > 100 and FCLK == 100.
Wouldn't there be a difference in the amount of wattage needed to heat two different coins to the same temperature of two different masses right? Doesn't that invalidate this point?
No, we are measuring temperature.
3x0
973 (1.15/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Lamzu Atlantis Mini Wireless
Keyboard HyperX Alloy Origins Aqua
168 (0.17/day)
System Name lawooder
Processor 5800x3D
Motherboard B550M Aorus Elite
Cooling Arctic Freezer 34 DUO
Memory 32GB 4000Mhz CL16 (2x16GB)
Video Card(s) RTX 3070 Ti
Storage SN770 250GB/SN750 500GB/SA510 1TB
Display(s) VG279QM 1080P 280hz + VG27AQ 1440P 165HZ
Case MSI MAG Something
Audio Device(s) fiiO EK10 + HD 599
Power Supply Focus GX 750 Watts
Mouse XM1r
Keyboard Xtrfy K4
My 5800X3D get hotter wih more CO on stuff like games. Warzone is a good example. with -30 CO I get temps north of 70c.
With stock CO my temps are 60c.
Its a BIG misconception that CO helps temps, yeah it can, but in certain workloads the cores will reach higher frequency, thus, higher temperature.
199 (0.05/day)
Processor Ryzen 7 5800x3D
Motherboard Gigabyte B550 Gaming X v2
Memory Corsair Vengeance LPX 2x32GB 3600Mhz C18
Video Card(s) XFX RX 6800 XT Merc 319
Storage Kingston KC2500 2TB NVMe + Crucial MX100 256GB + Samsung 860QVO 1TB + Samsung Spinpoint F3 500GB HDD
Display(s) Samsung CJG5 27" 144 Hz QHD
Case Phanteks Eclipse P360A DRGB Black + 3x Thermalright TL-C12C-S ARGB
Audio Device(s) Logitech X530 5.1 + Logitech G35 7.1 Headset
Power Supply Cougar GEX850 80+ Gold
Mouse Razer Viper 8K
Keyboard Logitech G105
I dont completely understand what are you on about BCLK and multipliers but it seems to be working for me. CPU simply clocks higher with higher BCLK. Here's a SS from last month but I can try to get a new one if you wish. Or any other test really.
