- Jun 24, 2015
- 8,219 (2.33/day)
- Western Canada
System Name | ab┃ob |
Processor | 7800X3D┃5800X3D |
Motherboard | B650E PG-ITX┃X570 Impact |
Cooling | NH-U12A + T30┃AXP120-x67 |
Memory | 64GB 6400CL32┃32GB 3600CL14 |
Video Card(s) | RTX 4070 Ti Eagle┃RTX A2000 |
Storage | 8TB of SSDs┃1TB SN550 |
Case | Caselabs S3┃Lazer3D HT5 |
@tabascosauz Downgrading to official 2604 bios increased the stock result to 4.1ghz and an extra 100mhz when undervolting/power limiting.
90w ppt, 60A tdc, 80A edc with -30mv on all cores
65W limits are 88/60/90. I keep EDC at 90 and just adjust PPT upwards as necessary, though you can decide for yourself based on % utilization of PPT/TDC/EDC reported by HWInfo.
How hot is your room ambient? If it's not hotter than 30C, everything actually looks a little on the warm side, by 5-10C. I would have suggested remounting, but noticing IO die temps and cache temps ambient just seems quite high. If above 30C, temps look a lot more reasonable.
Otherwise, things look fine, except that Vcore is slightly on the low side. It's good news that -30 works but that usually lands you around the 1.15-1.2V mark. You can play around with Vcore (one of the options in the dropdown is a + or - offset), see if your clocks improve from running say +0.025V.
Also, does -30 actually give a regression in clocks compared to -20 or -25. You're clock stretching a fair bit (4.125 effective vs 4.15 clock). Shouldn't be more than a 10MHz difference
