How do i get drivers for graphis card on 2000?
2,267 (1.90/day)
UK
The only card that works is the VOODOO 3.Photo below shows ASUS drivers for v7100
as you see i have it on the board o_OSo how do i get the drivers for the card on here?o_OWhat am i doing wrong?It is hard enough getting drivers for these old cards.Why can,t there be a data base where you can get drivers for any card?
2220 i know it has not been installed, i am trying to get it on there :banghead:.
Frick
Fishfaced Nincompoop
19,244 (2.84/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
2,267 (1.90/day)
UK
I saw this one and got it on the flash drive.
ASUS display driver version 56.55 for Win98SE and ME.
Version 56.55
14.19 MB
2004/03/09
I see the one i am showing on 20000 is for XP.If they have drivers for 98se and Me along with the one for XP .Why have they not got one for 2000? o_O
I have the one for 98se and Me .
Frick
19,244 (2.84/day)
Piteå
Version 56.55
14.19 MB
2004/03/09
Did you try installing it? 52.16 is also avaliable on the same site, you can try that.
3,654 (1.31/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
The initial one you tried is the correct one - ASUS display driver version 56.55 for Win2K and XP.
What do you see in the Device Manager? Does it only show problems or default drivers for display device? Do you have chipset drivers all sorted out?
You should be able to point at the drivers directly from the device settings and avoid ASUS installer which may or may not work.
Besides, that is a Geforce 2 MX. Nvidia does have legacy drivers available from their site and you do not have to rely on AIB drivers which always were a crapshoot.
Product Type: Legacy
Product Series: Geforce 2 MX Series
Product : Geforce2 MX/MX 400
Operating System: Windows 2000
Search.
The latest available drivers seem to be ForceWare Release 90, 93.71 from 2006.11.2. A lot newer than the ones on ASUS' page.
No idea if the direct link works: https://www.nvidia.com/content/Driv...k_international_whql.exe&lang=us&type=GeForce
Try those.
2,267 (1.90/day)
UK
Search.
Try those.
Thanks for that. :) But i still can,t get any 3DMARK ,s on
here 99 or 2000.What does it mean an error when the data was moved o_O I had to move it to get it on 2000o_Othats about 3dmark 2000. 3Dmark 99 wanted Direct x 6.1 which i tried to :( Are there any alternatives to 3d mark?
Hardware acceleration enabled i click that and it goes away. o_O I am lost with all this.:(Iys not shutting down now. :(
1,856 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
1) Unpack old installers for 3dmark with 7zip/Winrar (yes, .exe installer is an archive you can unpack).
Running "unpacked" or all files in one folder, should eliminate any temporary file issues. Make sure you have patches installed.
2) Have you installed chipset drivers before GPU ones ?
3) Try updating to DirectX 8 : LINK.
1,016 (3.31/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Windows 2000 has 4 service packs. By the time you're done installing all of them, could just install XPSP2 instead....
2,267 (1.90/day)
UK
Search.
Try those.
Thanks for that. :)But i can,t install either 99 or 2000 3dmark.:(
It is service pack four.
The 3dmarks were from Phils computer lab.I will try the Future mark site.No .
3,654 (1.31/day)
Usually it is better to get drivers or software from the original source rather than some more or less strange archives.
Old 3DMarks are available from their own site: https://benchmarks.ul.com/legacy-benchmarks
The prerequisites are usually included with the installer. As @agent_x007 suggested, DirectX versions might need some playing around with though. Probably best bet to install the DirectX 8 - perhaps the latest version you can find - and hope that it does properly work with older versions. It should but you never know. 3DMark99 is DX6 and 3DMark2000 is a DX7 benchmark.
2,267 (1.90/day)
UK
I will give it go tomorrow, i have been working on it for long enough today.Thanks once again for your advice :)
Does anyone use Brave Browser?You can ask it any question
this is mine
*If you put more ram than its max will it still work?*
Based on the search results, the answer is nuanced. Here are the key points:
  • BIOS limitations: The system’s BIOS may not be able to recognize or utilize the excess RAM, leaving no free RAM available for use. (From “memory - What happens when more RAM is installed than the motherboard supports? - Super User”)
  • Motherboard-dependent: The behavior of the system when installing more RAM than supported depends on the motherboard. It may work up to the maximum supported size, and then crash or malfunction. (From “What Happens If You Put More RAM Than Supported? - Internet Access Guide”)
  • Cache-memory usage: Some operating systems, like Linux, can use excess RAM as cache-memory for the disk, potentially improving system performance. (From “memory - If one never uses more RAM than they have, will upgrading RAM still speed up the PC? - Super User”)
  • No guarantee: There is no guarantee that the system will function correctly or utilize the excess RAM, as it depends on various factors, including the BIOS, motherboard, and operating system.
In summary, installing more RAM than its maximum supported capacity may not necessarily render the system unusable, but its behavior and performance will depend on the specific hardware and software configurations.
Why i have put this on here is i bought two sticks of Rambus Ram and was try to get them to work in my Sony vio pcv rxi thought i tried them every which way ,but today i thought i would try them in slots 1 and 3 and lo and behold they work :clap: .So it now has double the Ram in there.I also put the piece from brave because i was thinking of putting the two 256 sticks in there as well but after that i will leave it.The Sony s max ram is 512.Is it worth putting service pack 3 on there?
I will try and put ME on there at a later date.Have to get back to the other one trying to get 3DMARK working on there.
Thanks for your help londiste :)3DMARK 2000 score .I noticed that on the board i am trying to get 3dmark to work it says Direct x 3d acceleration is not available? o_O
1,856 (0.61/day)
System Name BOX
Keyboard HP KB-9970
Based on your GPU-z screenshot, you are using Catalyst 4.3 driver (ie. Microsoft provided one).
Try installing different driver for your current ATI card - Radeon 9600 Pro (or force installing if that fails).
2,267 (1.90/day)
UK
Yes you are right there it installed it self but it is running XP.It did have the one that i have on the one i trying to get 3dmark on.
6,756 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
snappy driver installer origin
718 (0.10/day)
GA, USA
System Name Gamer
Cooling Apogee XL, MCR360, MCP655, Micro-rez
Video Card(s) Red Dragon RX 6800 XT
Case Rocketfish (Lian Li) e-ATX
Audio Device(s) Harman Kardon HK695 2.1
Power Supply Seasonic Focus GM-750
Mouse HP Gaming wired
Keyboard Logitech G110 wired
VR HMD HP WMR 1440^2
Software Win10 Pro 64bit
2,267 (1.90/day)
UK
Thanks 68olds :)But i am trying to get 3dmark 99 or 2000 on the other board.I was advised to put direct x 8 on there but still not working.Could you give me links to get either one working on there.This is what is in 99 mark.
They have changed there design you have to be on line now.:(Only two files for 2000. Directx 8 showing.
*DIRECT3D ACCELERATION NOT AVAILABLE*
Greyed out. :(
718 (0.10/day)
GA, USA
System Name Gamer
2,267 (1.90/day)
UK
The issue of Direct3D being unavailable and greyed out can occur due to several reasons. Here are some possible causes and solutions:
  • Insufficient 3D hardware requirements: Your computer may not meet the minimum 3D hardware requirements to run the game or application. Check your system specifications to ensure they meet the requirements.
  • Outdated or incompatible graphics drivers: A missing, outdated, or incompatible version of graphics drivers might be the culprit. Ensure you have the latest drivers installed for your video adapter.
    • Power user settings locked: Some profile settings, including “Enable Custom Direct3D support,” might be treated as power user settings and locked by default. This can prevent customization of Direct3D settings.
  • To resolve the issue, try the following:
    Update your graphics drivers to the latest version.
    Enable DirectDraw Acceleration if it is disabled.
    Check your system settings to ensure “Enable Custom Direct3D support” is not locked and can be enabled.
    Verify your system meets the minimum 3D hardware requirement
  • If the issue persists, you may need to consult the documentation for your specific game or application for further troubleshooting steps or compatibility requirements.
718 (0.10/day)
GA, USA
System Name Gamer
That's not helpful information for others to help you. What other board? Please be as specific as possible.
718 (0.10/day)
GA, USA
System Name Gamer
If I'd guessed, I would have thought the 'other board' was your RDRAM board. :roll: Thanks for clarifying.
That's a nice board to play with & it's nice you can get all the drivers for it from Gigabyte. Most important is being on the latest BIOS, followed by the 4in1 chipset drivers, then USB 2.0, LAN, & Audio drivers.
What O/S are you playing with on this system? Does it have the 9600 Pro installed?
2,267 (1.90/day)
UK
Win 2000 the ASUS V7100 which came with the Sony ,i could not find the drivers for 2000 for the 9600 which i was using on the Gigabyte board and worked fine with XP,
