How to check flatness of CPUs and coolers - INK and OPTICAL INTERFERENCE methods
1,916 (4.15/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) 1080P 144hz
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Can you do the 245K and 285K also? I wonder if there's any discrepancies. These look the same as all the other ink tests. Flat enough to put a cooler on. :)
3,438 (1.69/day)
Power Supply Corsair RM750x
Mouse Logitech M575
With everybody excited about the new Arrow lake CPUs I thought I should check, how flat they are and what do they do in the socket.
A new CPU out of the socket surprisingly is not flat, but it has a bulge in the middle.
In socket, which is the new reduced load type, the CPU again bends significantly, in this case twists a bit too.
View attachment 368905View attachment 368906
I expected a little bit more from the new type of ILM.
When I see this I wonder if I can take my old CPU's do the same thing then capture it in a clear resin to enjoy the optical effect forever.
1,114 (1.75/day)
Today I bought another Deepcool AG620 cooler. Previously I complained that the base of the first cooler was a very pointy cone - really awful shape.
I am pleased to report that the second cooler has much better shape than the first one - it seems much flatter. I do not think that it is necessary to adjust the shape of the base, if you want to keep the cooler universal.
I will try to flatten just the middle part, so that the cooler gets the shape of the excellent Assassin IV cooler, which has presicely machined base - truncated cone with perfectly flat spot in the middle. It seems it is already pretty close to the desired shape and it will be easy to do.
