How to maintain your fans, Also how to succesfully perform fan surgery
Sticky this?
  • Total voters
    43
arkas
1 (0.00/day)
I've seen this post, fixed my fans and signed up to the forum just to say thank you. Thank you man. I used lithium grease and it's fine.
History: I had used WD 40 (failed) I also used 3 in 1 (failed also) I tried to inject lithium grease -inspired from a video where a man was regreasing his trailers wheels- (failed also) then I did the "surgery" and it's all good now. :)
de.das.dude
Pro Indian Modder
9,173 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| J1nnx took Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
if you use copper grease it stops the squeaking really well. wd and other stuff is just temporary fixes. WD is not a lubricant its a water displacer for removing rusty nuts losening hinges and etc :D
Mussels
Freshwater Moderator
58,413 (7.86/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
^ this
WD40 is a cleaner, not a lubricant. its definitely worth using, but you gotta grease it up after.
2,097 (0.52/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
I had the stock fan on my old athlon PC getting stuck so I had to manually start it with my finger. So one day took it apart, cleaned it, and here comes the stupid part - I used cooking oil to lubricate it but after a day or two it just died.
I learned to NEVER USE COOKING OIL on a fan.
de.das.dude
Pro Indian Modder
9,173 (1.71/day)
VR HMD ;_;
never use cooking oil. coconut oil(funny eh?) is still okay but cooking oil is just bad as it attracts dirt.
9,916 (1.83/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
yes, although its oily, i just use it for door
if you have any left motor oil, you can use it. just one drop and it will fine :D
de.das.dude
Pro Indian Modder
9,173 (1.71/day)
VR HMD ;_;
its about the viscosity... not other things... if its too thin... it wont work, line in the case of WD. if its too viscous it will create heat.
7,099 (1.01/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
I've used 3 in 1 before with decent results. Also have used Sewing Machine oil, which was ideal.
43,618 (6.44/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
I use this on all of my fans:
4,016 (0.66/day)
Ohio
System Name Desktop|| Virtual Host 0
Processor Intel Core i5 2500-K @ 4.3ghz || 2x Xeon L5630 (total 8 cores, 16 threads)
Motherboard ASUS P8Z68-V || Dell PowerEdge R710 (Intel 5520 chipset)
Cooling Corsair Hydro H100 || Stock hotplug fans and passive heatsinks
Memory 4x4gb Corsair Vengeance DDR3 1600 || 12x4gb Hynix DDR3 1066 FB-DIMMs
Video Card(s) MSI GTX 760 Gaming Twin Frozr 4GB OC || Don't know, don't care
Storage Hitachi 7K3000 2TB || 6x300gb 15k rpm SAS internal hotswap, 12x3tb Seagate NAS drives in enclosure
Display(s) ViewSonic VA2349S || remote iDRAC KVM console
Case Antec P280 || Dell PowerEdge R710
Audio Device(s) HRT MusicStreamer II+ and Focusrite Scarlett 18i8 || Don't know, don't care
Power Supply SeaSonic X650 Gold || 2x870w hot-swappable
Mouse Logitech G500 || remote iDRAC KVM console
Keyboard Logitech G510 || remote iDRAC KVM console
Software Win7 Ultimate x64 || VMware vSphere 6.0 with vCenter Server 6.0
Benchmark Scores Over 9000 on the scouter
I'd post what I use, but I'd get an infraction.
3,539 (0.67/day)
Netherlands
System Name AP201 | N2Plus | NUC
Processor AMD Ryzen 5 3600 | Amlogic S922X | Intel Core i5-7260
Motherboard Gigabyte B550M DS3H |Odroid N2+ | NUC Board 7
Cooling Inter-Tech Argus SU-200, 3x Arctic P12 & 1x Corsair 140mm case fan | stock heatsink+fan | stock HSF
Memory Gskill Aegis DDR4 32GB | 4 GB DDR4 | 16 GB DDR4
Video Card(s) Sapphire Pulse RX 6600 (8GB) | Arm Mali G52 | Iris Plus 640
Storage SK Hynix 240GB, Sam. 840 + 850 EVO (2x (250 GB)| Samsung 850 Evo 500GB | WD Green 240 GB
Display(s) AOC G2260VWQ6 | LG 24MT57D |
Case Asus Prime 201 | Stock case (black version) | Stock case
Audio Device(s) integrated
Power Supply BeQuiet! Pure Power 11 400W | 12v barrel jack | 19V laptop brick (Asus)
Mouse Logitech G500 |(runs mostly headless) | no-name ergo mouse
Keyboard Qpad MK-50 (Cherry MX brown)| (runs mostly headless) | Blaze Keyboard
Software Fedora, Windows 10 | Gentoo Linux | EndeavourOS
Do not click the spoiler in sensitive environments, although I do not see the issue.
I bet it is Durex Play
AsRock
TPU addict
19,167 (2.98/day)
UK\USA
Thought i should give this thread a bump as seen as i just did some maintenance on a fan i needed for a little project.
I use oil and superlube, although 1st i use CRC electronic cleaner to get the rubbish out of the bearings, then soak them in Sin synthetic lube which i used to use with RC cars, after putting the bearing back in i seal one side with the super lube so the oil don't leakout then seal it from the other side.
568 (0.19/day)
System Name ACME Singularity Unit
Processor Coal-dual 9000
Motherboard Oak Plank
Cooling 4 Snow Yetis huffing and puffing in parallel
Memory Hasty Indian (I/O: 3 smoke signals per minute)
Video Card(s) Bob Ross AI module
Storage Stone Tablet 2.0
Display(s) Where are my glasses?
Case Hand sewn bull hide
Audio Device(s) On demand tribe singing
Power Supply Spin-o-Wheel-matic
Mouse Hamster original
Keyboard Chisel 1.9a (upgraded for Stone Tablet 2.0 compatibility)
Software It's all hard down here
Nice info in this thread, thank you for bumping! Though i'll be honest, this is a touch too much for my taste. As in i'd have thought this can be avoided/not strictly necessary.
All my rigs so far, i never had a fan going bad on me. Bit of care during blowing (and that only once a month, if not rarer) and that was it. Of course, i pay premium for fans, O.K., i replace everything with Noctuas or others of equivalent pricing, including the case ones. And that's it.
(exception being the GPU fans, these motherbuggers are just bound to start rattling sooner or later. Which.. is why i bought the GPU in my sig, lol. I swore i'd never have a GPU-attached fan again. If that means custom loop in the next rig, so be it)
Of course, Murphy's being Murphy's, i bet you i'll have to return here eventually :D
23 (0.00/day)
I don't know how many I already brought back to life, tons. Basically ALL fans go 'put at some time. (Talking about after some years or so).
Nice instructions, doing the same thing, just be careful not to lose the small rubber rings and the washers when you open up the fans.
Take the entire thing out, clean the axle and the hole with 96% alcohol. Clean everything, also the washers, and of course the entire fan, blades etc.
Put it back. One drop of sewing machine oil on the axle/hole. Put the final ring and then the washer back (note the order there, the rubber goes first, then the washer), then the nylon clamp ring and then put the cap on and the label. Done.
The entire thing to do is easy and effective, not even a reason to get new fans really. But in my case (PUN!!) the problem was not so much fixing the fan, but mounting the fan back on the HSF with zip ties. The GPU was blocking access there so I had to take out the GPU. Since the HSF was also dirty I took the opportunity to take out the entire HSF, which of course also meant applying new MX4 on the CPU etc. I always hate it when something which SHOULD be simple and only should take 2 mins turns out some major op :)
Anyway...not sure whether Vaseline or sewing machine oil would actually be better, this time I used oil since the old fan was all greasy, I might actually have fixed this one (a Scythe) before once.
** As for fans with ball bearings...what you can do there is to put the bearings into alcohol....leave them in there for a while and later dunk them in oil. Just an idea.
*** Edit 2: In your PC bios, keep the setting activated where it monitors your FAN speed. Otherwise you will never know when your fan actually craps out! The BIOS and it sporadically reporting that the fan is not turning ("CPU FAN ERROR") or turning slower than it should as it happened here is also a sign that the fan is going and needs to be replaced or this fix.
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
quick & easiest way to clean Case fans????? open case up , with power, or power fans on outside of case, get paintbrush, and gently touch it to the spinning fan blades, cleans dirt/dust off SUPER fast, and makes fan cleaning easy as can be.
13,791 (1.86/day)
It's not recommended to fill the bearing chamber with oil. It'll cause the fan blade rotor to slip within the bearing and cause unwanted noise. Bearings should be either replaced or thoroughly cleaned and re-lubed (for which you need to use the vacuum chamber approach to force in the lubrication agent). Filling oil chamber is only recommended for sleeve bearing based fans.
I usually clean fan blades with a micro fiber cloth. Compressor doesn't remove it all, plus it sprays compressor oil which later causes more dust to stick...
5,596 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
That only cleans the top side of the fan not usually the place that dust accumulates the most try doing that to the underside and the fan will stop turning. You're better off turning of the system and removing the fan allowing you to get to both sides of the blades it also allows you to check for cracks in the fins of which I've found the coolermaster sickle blade fans to be the worse for especially if they're a few years old
5,596 (1.02/day)
Gougeland (NZ)
I'll usually use a compressor first then an old horse hair paint brush then iso alcohol to get rid of any stick shit left behind
de.das.dude
Pro Indian Modder
9,173 (1.71/day)
VR HMD ;_;
true, but this is not for cleaning fans :)
383 (0.23/day)
System Name Spaceheater
Processor Ryzen 9 5950X H2O
Motherboard asus x570-e ROG Strix
Cooling Triple radiator + vardar fans D5 for cpu and external MO-RA 420 NF-A20 1200 rpm dual D5 pump for GPU
Memory 4x8 GB G.Skill Trident Z Neo F4-3600C16Q-32GTZN
Video Card(s) Liquid devil 7900 XTX with PTM7950 + AMD 6900 XT in 2e machine
Storage 2x 980 pro 2tb 2x 860 EVO 1tb raid0 2x mx500 2 tb raid0 2x WD40EZRZ 4 tb raid0
Display(s) LG 38WN95C-W 3840x1600 144hz | 11,9 inch system info display
Case Lian Li PC-O11 Dynamic XL (ROG Certified) White
Audio Device(s) z5500 + steelseries Arctis Nova Pro wireless
Power Supply be quiet! Dark Power Pro 12 1200W
Mouse Logitech G502 X
Keyboard Keychron Q1
Software windows 11 23H2
Could't find any answers but how long a fan usually last after lubricating it with white vaseline or something equally as good before it starts making noise again ? i have alphacool fans hydraulic fan bearing since may 1 month ago 1 started to fail and grind fixed up with white vaseline now works good again, now today another fan started to make ticking noise also lubricated now, im worried i end up lubricating them all 1 by 1, can i expect them to last least 6 month's or should i expect to replace them soon ?
14,265 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
de.das.dude
Pro Indian Modder
9,173 (1.71/day)
VR HMD ;_;
vaseline dries out pretty quickly. thats why i switched to grease.
