How to Overclock RX 550?
99 (0.07/day)
Edmonton, Alberta, Canada
System Name Black Box II
Processor Ryzen 7 5800X
Motherboard ASUS TUF Gaming X570-Plus Wifi
Cooling Chromax Noctua NH-D15
Memory 32GB (4 x 8GB) TeamGroup 3200MHz
Video Card(s) XFX Merc RX 6900XT Limited Black
Storage WD Black SN770 (1TB), Crucial P1 (1TB)
Display(s) LG 34UC79G-B, BenQ GL2760-B
Case CoolerMaster CM 690 III
Audio Device(s) Speakers: Altec Lansing 251 | Microphone: Tonor Q9
Power Supply Corsair RM1000x
Keyboard Corsair K70 Core
I have managed to get my hands on an RX 550 that was pulled from a prebuilt HP system.
Currently I am using AMD's Radeon Software to overclock. I managed to get it to boost clock speeds by 15% and I increased the power limit by 20%.
It held stable during a 15min session of Furmark but about an hour later, it crashed while I was watching YouTube and Radeon Software reset my overclock.
I am not really sure why this happens so any tips are appreciated!
Thank you for reading!
99 (0.07/day)
Did you get any error code ?
I got a message saying "Default Radeon Wattman settings have been restored due to Unexpected System Failure"
364 (0.31/day)
Have you tried running at stock clocks ?
what is the current amd software version?
42,324 (6.65/day)
Set Adrenaline back to all stock. Use MSI AfterBurner and study this video
99 (0.07/day)
I don't have this issue at stock settings, only when I overclock.
My graphics drivers are up to date
364 (0.31/day)
I see well here is how I solved wattman error before try it see if it works:
1 - make sure windows is up to date .
2- download DDU uninstaller ,adrenaline 2020 edition 20.9.1 , and msi afterburner.
3- disconnect from all form of internet connection (wireless and wired) make sure you stay disconnected , ( there is a workaround this but first we need to see if this works )
4- (optional) if possible reseat the gpu to a different pcie slot
5- boot into safe mode , run DDU and clean amd drivers, reboot and install adrenaline software then reboot again .
since you had no issues at stock speeds , you can now try overclocking using msi afterburner .
I hope it helps , good luck :) .
497 (0.25/day)
Processor AMD Ryzen 7 5700X3D
Motherboard AsRock B550M Pro4
Cooling Arctic Freezer 34 Esports One
Memory 32GB (4x8) Team Group DDR4 3600 CL18
Video Card(s) ELSA RX5700XT w/ 2x Arctic P12 MAX fans
Storage Sabrent Rocket Q 1tb NVME 3.0
Display(s) Dual Monitors: 27in Sceptre 1440p 165hz IPS (Main) + 27in MSI 1080p 144hz (Left) on monitor arms
Case I don't want to talk about it
Audio Device(s) Logitech X530 5.1 Spearkers + Sennheiser HD58X Jubilee
Power Supply Corsair HX850i 80+ Platinum
Keyboard Leopold FC750R Cherry MX Brown
Software Microsoft Windows 10 Professional x64
If you have no issues at stock, it is resetting settings when it detects instability caused by an unstable overclock.
866 (0.23/day)
Processor ryzen 5 5600x
Motherboard AB350m Pro4
Cooling custom loop
Memory TEAMGROUP T-Force TXKD416G3600HC18ADC01 16gbs XMP
Video Card(s) HP GTX1650 super 4gb
Storage MZVLB256HBHQ-000H1 PM981a (256GB)/3TB HDD
Display(s) Nitro XF243Y Pbmiiprx
Case Rosewill CULLINAN
Power Supply Corsair 750w
Mouse Best Buy Insignia
Keyboard Best Buy Insignia
Software Win 10 pro
do you want to go all out on it? (upload the bios and ill take a look)
99 (0.07/day)
866 (0.23/day)
Cooling custom loop
Software Win 10 pro
then upload it to here.
99 (0.07/day)
  • RX550-HP.rom
866 (0.23/day)
Cooling custom loop
Software Win 10 pro
flash this bios using THIS. afterwards, reset the pc and use amd ati pixal clock patcher then restart again. Dont use furmark, these cards have poor cooling on the vrms and it just cooks them. i increased the clocks and power settings to stock rx460(no 6pin). if its stable we can work on core clock and memory frequency using msi afterburner. then we will tighten the timmings as much as possible. the bios itself should correct the crash issue you are having.
  • hp mod.rom
99 (0.07/day)
Thank you very much! Before I flash the BIOS, is there any chance of me bricking the GPU from updating the BIOS? As in the card will no longer output any signal if it does not like the new BIOS? I am asking this because updating motherboard BIOS's seems to be a pretty large source of anxiety for a lot of people.
42,324 (6.65/day)
No that is the reason why final fighter modify your existing one
2,432 (0.51/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Video Card(s) Sapphire Nitro+ Radeon RX 6750 XT
Case Corsair 275R
Mouse Logitech G Pro (Hero)
Unfortunately, it also deletes my custom fan curve and makes me re-enter it, so God forbid that the driver times out for any reason, including a software bug that causes issues at light loads.
Including a totally random driver timeout when I was using Chromium Edge recently, IIRC, before I wiped my Samsung 970 Pro 512 GB NVMe SSD on the 7th.
The crashes at light loads, likely means you should go to Igor's Lab for help with Radeons.
