How to quickly & easily fix coil-whine(coil choke noise)
29,100 (6.86/day)
Completely the opposite, sadly..
EU? Or did you mean South America? Either way, the "SuperGlue" branded tubes will also work perfectly. Even the CrazyGlue brand will work as long as you get the liquid. Stay away from the gel form.
37 (0.05/day)
Oh, so is this to say that the one I currently bought is not a viable option? Damn.
It looked good with the high flow it stated, as I read 'wicking' was an essential part.
37 (0.05/day)
I'm familiar with that brand, good stuff, you're golden!
Holy shit that's a huge relief to hear, thank you so much. I'll certainly be sharing my results when I receive the new unit, ASSUMING it'll have Coil Whine, ha.
Few questions however, I'm not sure if it's just because I've used some cheap chinese glue or something, but most of the time when I use the stuff that I buy from a discount store, the glue becomes white and flakey at times?
Is that because it's just not quality stuff, or did I accidentally buy the gel version? It seemed quite runny and liquid-like?
Also, how certain is it that this glue I've purchased can withstand the temperatures the VRM pumps out? Example 100*C and the heat cycling?
Is it safe to say even if the glue does deteriorate, it's not anything to worry about given it's non conductive, and it'll simply be a clean n' reapply situation in the distant future?
Would it have been better to buy an electrical varnish instead? Can't imagine that'd actually wick into places as effectively though..
29,100 (6.86/day)
That is a curing thing. Not sure what causes it, but it's just surface crystallization thing. It has no effect on the viability or functionality of the glue. My theory is it's an over-oxidation effect due to variations in the formulation at the factory, but that just a theory.
No, and it won't. Tried it years ago. Never succeeded with it. It would be great if it did, but sadly...
37 (0.05/day)
Makes total sense yes, crystalisation which is making it look white and cloudy. Definitely wanted more quality stuff though like the Zap Glue I just received. Thank you again so much for all this! Can't wait to give it a go.
Norton
Moderator - Returning from the Darkness
14,108 (2.94/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
Good info about that here:
37 (0.05/day)
OFCOURSE... I wondered why when I store my superglue in a ziplock bag and toss it in the fridge, the bag kept getting all frosty and mottled white.
So the simple answer is to just park the project next to a gentle blowing fan. Too easy.
29,100 (6.86/day)
Excellent article! There are a few things there I didn't know about the subject.
For the application being employed on GPU's, it's really not an issue and will not affect the outcome.
2,092 (0.79/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
@Wolverine2349
unless you remove all paint down to bare metal of the psu, there is no "ground" connection to the pc case by touching,
so using silicon/rubber pads isnt an issue.
Yes, my monitor supports G-Sync and it's always enabled. I only turn it off when I do benchmarks.
dad gum. just did an rtx demo and have horrible LF coil whine while synced 60.
but it only happens with DLSS enabled.
37 (0.05/day)
37 (0.05/day)
Thanks Lex, what about here? This is the opposite side of the motherboard.. if I am correct, the CPU on left, and the GPU on right.
5,310 (3.73/day)
Colorado, U.S.A.
Software Windows 11 Home
37 (0.05/day)
Shit.. it's true. Hopefully only the ceramic ones.. I DO SWEAR though when I took the bottom off my laptop, it STILL sounded louder coming through the keyboard side and not the open side where the heatsink and everything was visible.
COULD still be those stupid chip capacitors.
Once everything dries, going to test and see if it is fixed. It is curing quite slowly. I put a gentle fan on it to try avoid the crystalisation.
The wicking certainly did happen though wow. I added the glue to one side, and I watched closely, eventually it started coming out the other side from under the chip. Hopefully it climbed in and filled voids, too.
Can't wait.
https://www.youtube.com/shorts/HqQbjMQ2-JI
Bring it on. :U
