- Nov 15, 2021
- 3,568 (2.67/day)
- Knoxville, TN, USA
I meant if your incoming voltage was low already.Ferrite chokes can not do harm
Still doesn't work that way. Ferrite chokes will do nothing to a brown-out situation, good or bad.I meant if your incoming voltage was low already.
Well, mebbe the ferrite ones work differently.Still doesn't work that way. Ferrite chokes will do nothing to a brown-out situation, good or bad.
Then you're correct in that you're not talking about ferrite chokes.Well, mebbe the ferrite ones work differently.
I can assure you that the chokes I am more familiar with would cause voltage drop if applied to an AC wire.
System Name | Rainbow Sparkles (Power efficient, <350W gaming load) |
Processor | Ryzen R7 5800x3D (Undervolted, 4.45GHz all core) |
Motherboard | Asus x570-F (BIOS Modded) |
Cooling | Alphacool Apex UV - Alphacool Eisblock XPX Aurora + EK Quantum ARGB 3090 w/ active backplate |
Memory | 2x32GB DDR4 3600 Corsair Vengeance RGB @3866 C18-22-22-22-42 TRFC704 (1.4V Hynix MJR - SoC 1.15V) |
Video Card(s) | Galax RTX 3090 SG 24GB: Underclocked to 1700Mhz 0.750v (375W down to 250W)) |
Storage | 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000P NVME USB 3.2 |
Display(s) | Phillips 32 32M1N5800A (4k144), LG 32" (4K60) | Gigabyte G32QC (2k165) | Phillips 328m6fjrmb (2K144) |
Case | Fractal Design R6 |
Audio Device(s) | Logitech G560 | Corsair Void pro RGB |Blue Yeti mic |
Power Supply | Fractal Ion+ 2 860W (Platinum) (This thing is God-tier. Silent and TINY) |
Mouse | Logitech G Pro wireless + Steelseries Prisma XL |
Keyboard | Razer Huntsman TE ( Sexy white keycaps) |
VR HMD | Oculus Rift S + Quest 2 |
Software | Windows 11 pro x64 (Yes, it's genuinely a good OS) OpenRGB - ditch the branded bloatware! |
Benchmark Scores | Nyooom. |
I can't say really. Can't replicate the same environment, as I changed all the fans, and did other stuff to the system, and I'm lazy to do the paper cone thing. But I'll update when I do.
I meant to put them on a psu-gpu cable, as Mussels mentioned a while back, but a few on the socket-psu part wouldn't do any harm neither.
I meant the power cable coming into the PSU.
Oh yeah, entirely different then. they arent in-line resistors or capacitors or anythingWell, mebbe the ferrite ones work differently.
It turned out that at 7am every morning, the occupant would switch on their old TV which would in turn knock out broadband for the entire village.
USB is DC as well.Oh yeah, entirely different then. they arent in-line resistors or capacitors or anything
They used to be *EVERYWHERE*, even built into USB cables and such
USB is DC, but it could pick up interference easily because it's long straight wires - think a USB powered speaker, they were super prone to electrical noise with pops and crackles when a phone recieved an SMS nearbyUSB is DC as well.
The only use I have seen for a choke on AC before this was as an easy way to limit voltage.
I guess the ferrite ones are insensitive to 60Hz fluctuation?
System Name | 1️Purple Haze 2️Vacuum Box |
Processor | 1️AMD Ryzen 7 5800X3D (-30 CO) 2️Intel Xeon E3-1241 v3 |
Motherboard | 1️MSI B450 Tomahawk Max 2️Gigabyte GA-Z87X-UD5H |
Cooling | 1️Dark Rock 4 Pro, P14, P12, T30 case fans 2️212 Evo & P12 PWM PST x2, Arctic P14 & P12 case fans |
Memory | 1️32GB Ballistix (Micron E 19nm) CL16 @3733MHz 2️32GB HyperX Beast 2400MHz (XMP) |
Video Card(s) | 1️6900XTXH ASRock OC Formula LM'd & Phanteks T30x3 2️5700XT Sapphire Nitro+ LM'd & Arctic P12x2 |
Storage | 1️ADATA SX8200 Pro 1TB, Toshiba P300 3TB x2 2️Kingston A400 120GB, Fanxiang S500 Pro 256GB |
Display(s) | TCL C805 50" 2160p 144Hz VA miniLED, Mi 27" 1440p 165Hz IPS, AOC 24G2U 1080p 144Hz IPS |
Case | 1️Modded MS Industrial Titan II Pro RGB 2️Heavily Modded Cooler Master Q500L |
Audio Device(s) | Audient iD14 MKII, Adam Audio T8Vs, Bloody M550, HiFiMan HE400se, Tascam TM-80, DS4 v2 |
Power Supply | 1️Rosewill Capstone 1000M 2️Enermax Revolution X't 730W (both with P14 fans) |
Mouse | Logitech G305, Bloody A91, Amazon basics, Logitech M187 |
Keyboard | Redragon K530, Bloody B930, Epomaker TH80 SE, BTC 9110 |
Software | W10LTSC 21H2, PBO2, FF, MusicBee, mpv, ImageGlass, OpenRGB, FanControl, Greenshot, DS4Win, Signal |
What @Mussels said.If anyone have any suggestions I'm all ears.
System Name | CyberPowerPC ET8070 |
Processor | Intel Core i5-10400F |
Motherboard | Gigabyte B460M DS3H AC-Y1 |
Memory | 2 x Crucial Ballistix 8GB DDR4-3000 |
Video Card(s) | MSI Nvidia GeForce GTX 1660 Super |
Storage | Boot: Intel OPTANE SSD P1600X Series 118GB M.2 PCIE |
Display(s) | Dell P2416D (2560 x 1440) |
Power Supply | EVGA 500W1 (modified to have two bridge rectifiers) |
Software | Windows 11 Home |
Talk about ripples
check the middle section of this page https://www.tomshardware.com/reviews/corsair-rm750x-2021-power-supply-review/4
This makes me wonder..Amazing that the video card noise comes from the MOSFETS (toward the end of the video)
yes I am wonder too, can some one bereave enough to glue them?This makes me wonder..
That's what I was wondering. The GTX560 shown in the OP still makes a bit of noise. I'm wondering if it's the MOSFETs AND if gluing them would have an effect. I already have some ferrite chokes coming to experiment with. I think Mussels is on to something that could be one variable in the total equation.yes I am wonder too, can some one bereave enough to glue them?
This rendered a result. This GTX560 was much more quiet after the chokes were glued, but still made some noise. After now gluing the MOSFETs, there is even less sound. With the side of the case on, it is only just audible. So I'm left wondering how common MOSFET noise really is.
I can help you out here.As far as I know silicone is non conductive and can handle temperatures much higher than the MOSFETs can reach so in theory I should be fine I guess.
If you already have this and still hearing noise, i am guessing you can leave MOSFET for now??BTW I have heatsinks glued on top of the MOSFETs for cooling and I wonder is this could worsen an eventual coil whine coming from there.
NO!! Don't use this kind of glue. Silicone glues contain acidic solvents which WILL DESTROY your card. Acids will severely corrode the metal pathways and components.with liquid silicon glue
That's some good glue, but I still can not recommend it for the application subject of this thread. The wicking action of super glue is an important factor. Silicone glue has no wicking action.not as a ADs but this work.
there is electronic grade stuff that release no acid in cure time.
I think the glue stuff in power supply is the same type.
