how to switch x8 to x16
108 (0.15/day)
Processor AMD Ryzen 5 5600G
Case NX
Mouse Razer Viper 8khz,
Keyboard Rapoo
Hy guys!
I would like to switch the bus from x8 to x16.
If the graphics card is physically installed in an x16 slot on the motherboard, but the system recognizes it as x8,.
My pc: amd ryzen 7 5800x3D
motherboard:ASUS B550 PRIME PLUS
Videocard: GeForce RTX™ 4060 EAGLE OC 8G
Thank you
829 (1.87/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
No. Get another card that features full x16 mode.
53 (0.09/day)
The Netherlands
Processor AMD Ryzen 7 5800X3D
Motherboard ASRock Fatal1ty X370 Professional Gaming
Cooling Noctua NH-D15 SE-AM4
Memory G.Skill Trident Z F4-3200C14D-32GTZ
Video Card(s) Inno3D RTX 4080 16GB X3
Power Supply Corsair RM1000x (2021)
To add to the above: Note that this card probably wouldn't get any real benefit from having an x16 link anyways, x8 at 4.0 speeds should be plenty of bandwidth. No need to worry there.
(one thing that I would recommend would be to hit the question mark icon next to the Bus Interface field, to see if it scales up to 4.0 under load -- if it's actually stuck at 2.0 that would be an issue)
1,445 (0.31/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Audio Device(s) Logitech Z906 5.1
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
add more as this site seems to always do with newest cards and test pci-express scaling using a 4090 it only lost 3% going from pcie 4.0 16x to 8x. That is a card that is far more stressful on pcie then a 4060 could dream to be.
las
1,693 (0.38/day)
System Name Meh
Case Fractal Design North XL
Audio Device(s) FiiO DAC
It won't matter, PCIe 4.0 x8 has the same bandwidth as PCIe 3.0 x16, you will get full GPU performance at x8 :)
AMD did this on several cards as well.
Aquinus
Resident Wat-man
13,191 (2.75/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
331 (0.78/day)
Mile High City
System Name Keds
Processor 5600X3D
Motherboard Gigabyte X470 AORUS ULTRA GAMING
Cooling Corsair H100i
Memory 32 GB Team Force DDR4 3200 CL16
Video Card(s) Power Color RX 7900 XT Red Devil
Storage 2x 1TB SSD / NVME
Display(s) AOpen 27in 1440p 170hz (27HC5UR)
Case Modified Corsair 540 Air
Audio Device(s) Logitech G35 / Corsair HS80
Power Supply EVGA 850GQ
Mouse Corsair M65
Keyboard Corsair Strafe Silent
Software Win 11 Home (Modded)
Benchmark Scores It will beat a snail in a down hill race.
That 4060 does not need x16 lanes of pcie 4.0. I have a RX6900XT on an old x470 board running on pcie 3.0 and I get full performance out of it.
9,828 (3.45/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
The physical limit of your card is x8. As such you will see no performance loss. Pcie 4x16, however is much faster (in theory) than x8.
ir_cow
4,858 (0.80/day)
USA
You will get zero benefit from going to 16x gen 4 with a RTX 4060. No extra fps... Nothing
18,584 (2.65/day)
System Name AlderLake
RMA!
j/k..
It should run fine as is or get a more powerful GPU.
