HWInfo's Power Reporting Deviation Sensor Reveals How Motherboard Makers are Cheating Ryzen CPUs
9,785 (3.47/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Even though this may be anecdotal it may explain why every AM4 Gigabyte board I have bought and OC have gone to 00 post code over time.
  • Like
Reactions: hat
3,506 (1.12/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
But the article also say: "The issue with using this exploit is, that it messes up the power management of the CPU and potentially also decreases its lifespan because it is running the CPU outside the spec..."
So TPU title even if click-baity is not false.
Running a CPU out of spec doesn't lower life span per say. For example, there are plenty of Intel motherboards that boost for periods longer then Intel spec, even with MCE disabled. You'd really need to prove that degradation would indeed occur at whatever settings a particular motherboard is using.
21 (0.01/day)
Sydney, Australia
System Name 5800X3D-RTX3090
Cooling Phanteks Glacier One 360MP D-RGB AIO
Memory 64GB Corsair Vengeance LPX 3600MHz CL16 DDR4
Video Card(s) nVidia RTX 3090 Founders Edition
Storage 4 x 4TB WD SN850X M.2 NVMe
Display(s) 27" IPS @ 144hz, G-Sync
Case Phanteks Enthoo Evolv X - Anthracite Grey
Audio Device(s) Speakers: Razer Leviathan v1 | Audio ICs and codecs: ALC1220-VB, ESS SABRE9118 DAC, & DTS:X Ultra
Power Supply 1300W Seasonic Prime PX 80+
Mouse Razer Basilisk Ultimate
Keyboard Razer Blackwidow Elite
VR HMD Valve Index, Oculus Rift S
Software Win10 Pro
Wow. I'd love to see a list of offending boards & manufacturers compiled at some point (noting BIOS revisions). I'm still rocking a GTX 1080 Ti & 4790K, but my next build is absolutely going to be Ryzen. Frankly, I'd rather support a company that doesn't risk or reduce the longevity of their their customers hardware by gaming the numbers like this.
11,880 (2.18/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Is this just on X570, I cannot get a value out of hwinfo for my x470, see below?
no sign of it, I checked in settings , it is not hidden or unmonitored, it isn't there?.
two motherboard bios 3004,3101 tested, no sign.
3,832 (0.74/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
If that were the only thing wrong however you and Ian it seems fails to realize that before this ya didn't know your board could be lying to the cpu. Then you go to do your overclock and further run your chip into the redzone all the while not knowing how close you are to it. That's just not cool. And on the topic of degradation the Stilt's already shown us maximum FIT voltage to prevent it and it is not hard to degrade a matisse cpu. Stilt's had degradation running as low as 1.33v in about a month.
I think it is Matisse cpus only. I tested my kids 1600AF on x570 and did not see the deviation reading either.
19,376 (3.50/day)
I also think motherboard reviewers need to read this asap. They need to dig into the bios and disable all the auto oc features so we get a real feel for boards.
I disagree with this sentiment.
Most users simply don't and will not do such a thing. IMO, testing should be done setting optimized defaults and XMP/DOCP. This is the way you get 'out of box' performance as everyone else would. What people tweak and such is impossible to get consistent.
11,880 (2.18/day)
Manchester uk
VR HMD Oculus rift
I agree though the likes of gamer's Nexus prefer to force intel and AMD reference specs on board's.
Disabling MCE ,pbo etc, that's not how they're used.
All benching should be how they're used, All , everywhere (I'll adopt a say no more on this here in in Tpu)
I would however like. This information put into reviews too though, as a heads up so to speak.
3,832 (0.74/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
As I wrote the problem is the lack of disclosure. If you wanna bury your head in the sand about this that's your prerogative. The fact is MB makers grease their boards all the time, running stuff out of spec just to look good on benchmarks. That is a LIE and it does the consumer a disservice.
