Hybrid air/water cooling solution?
1,150 (0.47/day)
Upstate NY
System Name Dual Socket HP z820 Workstation
Processor Twin Intel Xeon E5 2673 v2 OEM processors (thats a total of 16C/32T)
Motherboard HP Dual Socket Motherboard
Cooling Stock HP liquid cooling
Memory 64GB Registered ECC memory kit (octal channel memory on this rig)
Video Card(s) MSI RX 5700 XT Gaming X 8GB
Storage 2 x 512GB SSD in raid 0
Display(s) Acer 23" 75Hz Gaming monitors 1080P x2
Case Brushed Aluminium
Audio Device(s) Integrated (5.1)
Power Supply HP 1125W Stock PSU
Mouse gaming mouse
Keyboard Dell
So the HP z820 has an interesting cooling system.
There is a "hood" that covers both of these radiators with 80mm fans, like this:
In my limited research this seems like a pretty rare setup. Can't really find anything like it.
Question is, why aren't more people doing this? Wouldn't it be nice to have a liquid cooler that bolts onto the CPU like an air cooler? In one neat little unit?
You could even have two thin 120mm radiators sandwiching a single 120mm fan in the middle.
hat
Enthusiast
21,750 (3.27/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
I don't think there's any good reason to do this. May as well use a regular tower cooler.
825 (0.43/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
I assume its just a water cooler without excess pipelines and the cooling ability would be mainly limited by that 120 radiator.
It wouldn't be better that a normal 120 water cooler, which would be not much different from a tower cooler, also it's gonna require more space on the motherboard.
Water is usually used to transfer heat for a relative long distance through easily adjustable pipelines so the radiator can be placed anywhere, in this case, the distance for heat to travel isn't long and also the radiator is already fixed on the cooler, then why bother using water if heat pipes can do the same job?
sneekypeet
not-so supermod
29,683 (4.32/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Cooler master has 92mm rads that swivel like this, but they didn't have the huge blower setup.
2,373 (0.57/day)
Audio Device(s) A LOT
14,277 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Fourstaff
10,084 (1.82/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
Probably designed to avoid one tower blowing hot air to the next?
9,662 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
That would be very inefficient, the second radiator would hardly dissipate any heat.
1,374 (0.35/day)
Processor 3900X 4.425
Motherboard X570 Tomahawk
Cooling Galahad 360 push-pull
Storage Optane 280gb PCI-E
Display(s) PG348Q
Case Core X71
Power Supply AX1500i
They do exist, I had a PC-cooler air heatsink that had tubing holes. They're rare and mostly worth just using with one method or another. Asus and a few others also had such GPUs.
As for the setup in the pic, yeah, looks like it is built for that workstation only. The other pic you posted looks to have some Nidec Ultraflo's with Deltas and AVC fans. All that stuff is probably going be louder than any fan configuration you've ever heard.
