Hynix A or M die for "futureproofed" AM5 build?
Status
Not open for further replies.
418 (0.36/day)
Denmark
Processor AMD Ryzen 7 3800X
Motherboard ASUS Prime X470-Pro
Cooling bequiet! Dark Rock Slim
Memory 64 GB ECC DDR4 2666 MHz (Samsung M391A2K43BB1-CTD)
Video Card(s) eVGA GTX 1080 SC Gaming, 8 GB
Storage 1 TB Samsung 970 EVO Plus, 1 TB Samsung 850 EVO, 4 TB Lexar NM790, 12 TB WD HDDs
Case Corsair Obsidian 550D
Audio Device(s) Creative X-Fi Fatal1ty
Power Supply Seasonic X-Series 560W
Keyboard Glorious GMMK
Searching the interwebs for DDR5 memory advice I've seen most people recommend modules using Hynix chips (and surprisingly recommend staying away from Micron, apparently :eek:). However, there seems to be a difference of opinion on whether Hynix A or M dice are the better choice. Apparently, A dice can clock higher while M dice have tighter timings.
Since current AMD CPUs cannot use higher clocked RAM as well as Intel ones, many people recommend going with M dice for AM5. But what about future AM5 CPUs (for instance Zen6/"Medusa")? Would it not make sense to prefer A dice, since Zen5 already has somewhat better memory support (as far as the current IO die can handle it) and Zen6 is sure to greatly improve on that, considering it'll get a brand new IO die?
I'm looking for memory that'll serve me well now, and, hopefully, even better once Zen6 comes around. Bonus question: Is A or M the newest iteration?
43,714 (6.78/day)
Whats wrong with the micron chips?
418 (0.36/day)
Denmark
The general consensus seems to be that Hynix is best and Micron is worst for DDR5, with Samsung somewhere in the middle. I bet for stock JEDEC speeds it's probably a toss-up.
43,714 (6.78/day)
More like splitting hairs than anything
Go with what fits your budget and roll with it
1,917 (4.14/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) 1080P 144hz
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Depends on the motherboard. AMD is perfectly capable of high memory frequency otherwise. That's where A/M-die is desired. 8000mt/s ranges.
433 (0.27/day)
Toronto
System Name GraniteXT
Processor Ryzen 9950X
Motherboard ASRock B650M-HDV
Cooling 2x360mm custom loop
Memory 2x24GB Team Xtreem DDR5-8000 [M die]
Video Card(s) RTX 3090 FE underwater
Storage Intel P5800X 800GB + Samsung 980 Pro 2TB
Display(s) MSI 342C 34" OLED
Case O11D Evo RGB
Audio Device(s) DCA Aeon 2 w/ SMSL M200/SP200
Power Supply Superflower Leadex VII XG 1300W
Mouse Razer Basilisk V3
Keyboard Steelseries Apex Pro V2 TKL
Depends on what speeds you're trying to hit. If you want the highest speeds, get the 24gb m dies, some call it v2 m dies. If you want the tightest timings up to 8200mt/s, get a highly binned a die.
My suggestion would be the 24gb m dies, as you get 1.5x more capacity and slightly higher speed ceiling at the expense of slightly looser timings which don't make too much of a difference unless you're chasing records
tabascosauz
8,226 (2.33/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Who has been recommending 16Gb M over 16Gb A-die?? :confused: just get 16A unless there's some kind of fire sale on 16M, it's 2025
24Gb M-die would be my choice since it is pretty much the equivalent of 16Gb A-die yet gives you access to the 48GB capacities.
ir_cow
4,771 (0.79/day)
USA
16GB A-Die will give you the lowest timings possible if you are willing to do some manual adjustments.
24GB all have higher tRFC which is higher latency . For AMD that equals lower performance. Easy fix if you just type in the 16GB tRFC values instead.
Is the op looking for best out of box performance (set EXPO and forget) or something a little extra on the side.
899 (0.15/day)
System Name HTPC whhaaaat?
Processor 2600k @ 4500mhz
Cooling Noctua NH-C14
Memory Gskill Ripjaw 2x4gb
Display(s) Vizio P 65'' 4k tv
Case Lian Li pc-c50b
Audio Device(s) Denon 3311
Power Supply Corsair 620HX
433 (0.27/day)
Toronto
Case O11D Evo RGB
Fully tuned, a die still has a trfc advantage. In reality, with a maxed out 65k tref, it doesn't matter all that much in the end and 24g is still the one to get.
21,795 (3.41/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4000 (Running 1:1:1 to FCLK)
Case Thermaltake Core X31
Software Windows 11 Enterprise
Yeah for JEDEC speeds its never going to matter. For OCing or EXPO just forget about Micron entirely.
freeagent
9,818 (4.18/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
My first set is a pair of A-Die to get me running, next set will be 2R M-Die I reckon.
Have to see how my first set runs first though..
899 (0.15/day)
The way I conceptualize it is to remember Micron can't make 20gbps GDDR6. Their chips can't overclock to hit 20gbps.
If you translate the difference from NRZ to PAM4, this is still true for GDDR6x. If you translate from NRZ to PAM3, this is true for GDDR7.
Samsung/Hynix ofc offer 20/40gbps. This translates elsewhere.
Their current manufacturing lines are similar to the 'older' hynix/samsung manufacturing lines.
I don't know if Samsung is so bad, as much as they don't bin their chips very well (the way they do it is kind of odd).
Hynix is much more consistent imho, and this translates into their system DRAM offerings being preferred for that reason.
I also think Hynix is generally cheaper than Samsung. Micron is very cheap, but just not on the same level.
They're good for keeping prices in-check though, given we've had price-fixing in the past.
431 (1.57/day)
System Name Kuro
Processor AMD Ryzen 7 7800X3D@65W
Motherboard MSI MAG B650 Tomahawk WiFi
Memory Corsair DDR5 6000C30 2x48GB (Hynix M)@6000 30-36-36-76 1.36V
Video Card(s) PNY XLR8 RTX 4070 Ti SUPER 16G@200W
Storage Crucial T500 2TB + WD Blue 8TB
Case Lian Li LANCOOL 216
Power Supply MSI MPG A850G
Software Ubuntu 24.04 LTS + Windows 10 Home Build 19045
Benchmark Scores 17761 C23 Multi@65W
Could say that I have tried to reduce the tRFC and tRAS values on my 24Gb M-die to something apparently stable and close to A-die values, which did not give sufficiently visible performance increases for my current uses, and caused crashes on weekly basis. Running stock A-XMP with a little less voltage at least mostly cured the crashes.
Yep, I've had enough RAM tuning for the moment.
tabascosauz
8,226 (2.33/day)
Western Canada
System Name ab┃ob
96GB :love:
I stick to 50k tREFI anyways, so I would love to get my hands on an extra 32GB of capacity
43,714 (6.78/day)
What's the reason? I mean I provided a link for their oc line which iirc is what xmp/docp/expo do via spd tables installed on the modules.
Also there is Mushkin
431 (1.57/day)
System Name Kuro
96GB :love:
96GB may sound like a lot, and to be honest is a lot, but it does feel even more helpless when you have the workload to fill it all up and then ask for more. :roll:
Plus currently there are limits on more than tREFI compared to 64GB, though whether it matters all that much in real world is debatable.
I wonder what 128GB would be like, when and if 32Gb chips roll out.
freeagent
9,818 (4.18/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I just want the 9900/9950X3D to be released so I can make my choice so I can try my ram.. I almost bought a 9900X today but I don't want to kick myself later.
127 (0.05/day)
Seattle area, Wa
System Name Not pretty
Processor Ryzen 9 9950x
Motherboard Crosshair X870E
Cooling 420mm Arctic LF III, for now
Memory 64GB, DDR5-6000 cl30, G.Skill
Video Card(s) EVGA FTW3 RTX 3080ti
Storage 1TB Samsung 980 Pro (Win10), 2TB WD SN850X (Win11)
Display(s) old 27" Viewsonic 1080p, Asus 1080p, Viewsonic 4k
Case Corsair Obsidian 900D
Power Supply Super Flower
Benchmark Scores Cinebench r15, w/ 1680v2 @ 4.6ghz and XMP enabled, 1648 1680v2 @ 4.7ghz RAM @ stock 1333MT/s, 1696
It's hard to say because no one knows what Zen 6's Memory controller will be able to handle, or what speeds Zen 6's IF will run. I don't know if CU-DIMMs will be the next 'have to buy thing' for Zen 6. Don't know until we get there, which is a long way away.
24GB DIMMs seem to typically be M-dies and 16GB or 32GB DIMMs seem to typically be A-dies. Memory prices will most likely be different when late 2026/early 2027 comes around than they are today. Paying more for higher spec memory today might not pan out in two years.
ir_cow
4,771 (0.79/day)
USA
24GB DIMM can only be Micron or Hynix 24Gbit M-De.
16 and 32 DIMM can be a number of things. Even 16Gbit M-Die.
Anyways I agree with you about not knowing what the future holds. I would buy for the current platform.
418 (0.36/day)
Denmark
Thank you all for your input. It's made me quite a bit more enlightened.
The choice I need to make is actually between 16Gb A or 24Gb M. Wasn't aware that 16Gb M even existed.
So with 24Gb M being more or less equal to 16Gb A it seems to come down to if I want to have 64GB or 96GB in my new build. Either 2x 32GB A or 2x 48GB M (50% more RAM at 50% higher price). Decisions, decisions...
1,772 (0.88/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
For futureproofing I would go 16gb A-die or 24gb M-die. They can both do 8000+, M-die can do 10000+. No ram from Micron or Samsung can to my knownledge di that atm. Hynix 16gb M can only do 7000-7600. Samsung and Micron do 5600-7600 max with worse timings than Hynix.
418 (0.36/day)
Denmark
Got another, related, question for you guys. Is memory from v-color any good? They have some very tasty kits. Although not sure if the highest-binned ones are worth the markup.
899 (0.15/day)
I'm sure they're fine. I like Team simply bc they have decent settings programmed and are usually pretty cheap for their bins. Also, I remember their origin back in the day and their rep on XS. Nostalgia ftw.
I haven't kept up if there's a 'very particular kit' that's all the rage these days. I stopped doing that when OCZ got out of the biz. Now I just make sure the bin/chips are what I want.
GLHF.
6,134 (0.84/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
There is no future proofing in PC hardware. Buy what will serve your needs today, be prepared to replace it when it no longer serves those needs.
Status
