I get low fps and stutters when I have a good gaming laptop
skilledguitarnoob
28 (0.06/day)
Hello, I've been experiencing around 120 to 170 fps on Minecraft. Sometimes it drops even lower.
I already set graphic settings to fast, disabled every single effect and particle. Reduced the chunk things. Nvidia drivers updated
I truly don't know what to do next.
CPU : Amd Ryzen 4800HS with Radeon Graphics
GPU : Nvidia Geforce RTX 2060 with Max-Q Design
Laptop : Asus ROG zephyrus G14
It gets pretty annoying cause it happens in RDR2, you can't even play for 5 minutes. Help me please
2,965 (2.06/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
what is the problem?
574 (0.34/day)
Florida
Processor 5800x3d
Motherboard MSI Tomahawk x570
Cooling Thermalright
Memory 32 gb 3200mhz E die
Video Card(s) 3080
Storage 2tb nvme
Display(s) 165hz 1440p
Case Fractal Define R5
Power Supply Toughpower 850 platium
Mouse HyperX Hyperfire Pulse
Keyboard EVGA Z15
When's the last time you blew the dust out?
574 (0.34/day)
Florida
Processor 5800x3d
Video Card(s) 3080
Storage 2tb nvme
Keyboard EVGA Z15
Did these problems start after you got the laptop back? maybe the technician didn't do a good job cleaning it.
skilledguitarnoob
28 (0.06/day)
no unfortunately they started before. I went because my computer got really bad, I used to go from 250fps to 30 in 5 seconds when I played rocketleague then it went right back up.
So he told me, well if the gpu has a problem we cannot do anything. He got the dust out and gave me my pc, it was good like it stuttered but not as much as before.
I just find strange the fact that i have low fps when the gpu cpu and ram are pretty good.
2,155 (0.34/day)
Austin TX
System Name Beyond Journeys End
Processor Ryzen 7 9700x
Motherboard ASRock b650 lightning wifi
Cooling Fractal 280 w/ Thermaltake toughfans
Memory 32Gb Gskill DDR5 6000
Video Card(s) 3080ti Game Rock
Storage Intel 905p 960gb + 2tb SKhynix P41
Display(s) LG C2 OLED 42"
Case Fractal Era 2
Audio Device(s) HD58X + Sennheiser GSX 1000
Power Supply Asus loki 850 SFX-L
Mouse Glorious Model O
Keyboard Akko Mod 007b HE
Software Tiny 11 + Ubuntu dual boot
Just to eliminate the basics.. You do have it plugged in to the power brick while gaming, right? Also have you tried setting your power profile to high performance in windows? Also assuming you have the laptop at the very least elevated slightly while gaming to give the fans extra room to breathe?
skilledguitarnoob
28 (0.06/day)
It is plugged, I always set to high performance. It is in fact slightly elevated.
18,584 (2.67/day)
System Name AlderLake
What windows version, you may have issues with a windows update.
AsRock
TPU addict
19,128 (2.98/day)
UK\USA
You could try adding high performance for Red Dead, right click desktop display settings \ Graphics settings, i don't know if they moved the option is Win11.
More details would be nice, RDO is a demanding game.
EDIT: minecraft issue might be some thing i had with hybrid a long time ago were the demand would not be enough and not switch or would switch back and forth be4twean graphic cards, so it could be a display driver issue so maybe try ones from before it started to happen.
skilledguitarnoob
28 (0.06/day)
Thanks you for replying, I am noob concerning technology so I just know that I have windows 11 pro, but i don't know which update it is.
Thank you, I will try the solution for Red Dead. Which details would you like ?
Also, I rollbacked to a driver from june 2022, but the issue seems to still be there.
PS : I said red dead but ROBLOX is also getting stutters, as well as genshin impact.
574 (0.34/day)
Florida
Processor 5800x3d
Video Card(s) 3080
Storage 2tb nvme
Keyboard EVGA Z15
Do you use armory crate?
8,504 (3.95/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
250fps to 30fps is a huge drop.
I'd be tempted to disable all startup software, it's possible it's background utilities doing some nonsense in the background.
skilledguitarnoob
28 (0.06/day)
Well, my pc came with it so i just adjust the fans somethings to performance / turbo
Should I also disable Radeon Software startup and SecurityhealthySystray ?
Solaris17
Super Dainty Moderator
27,186 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
What are your actual temps gaming? Can we get some logs?
8,504 (3.95/day)
Case Veddha T2
Mouse MX Anywhere 2
No, probably not - it's part of the graphics driver the laptop uses when the Geforce isn't active.
SecurityHealthySystray is the just the windows defender tray icon; It's definitely not doing any harm - I treat that as part of the OS and never have any issues with it.
Sort by manufacturer and with the exception of the graphics driver from AMD and the Nvidia driver for the gaming GPU, everything else third party can be disabled - at least temporily for testing.
I'd normally say disable all of the tweaking/overclocking/monitoring software from Asus, it shouldn't be necessary at all - but on a laptop it's probably actually useful for fan control and hotkeys. Temporarily disabling it will let you see if the performance issues go away, at least - and if they solve nothing you can turn them back on again.
771 (0.77/day)
London, UK
Processor AMD Ryzen 7 5800X3D
Motherboard ASUS B550M-Plus WiFi II
Cooling Noctua U12A chromax.black
Memory Corsair Vengeance 32GB 3600Mhz
Video Card(s) Palit RTX 4080 GameRock OC
Storage Samsung 970 Evo Plus 1TB + 980 Pro 2TB
Display(s) Acer Nitro XV271UM3B IPS 180Hz
Case Asus Prime AP201
Audio Device(s) Creative Gigaworks - Razer Blackshark V2 Pro
Power Supply Corsair SF750
Mouse Razer Viper
Keyboard Asus ROG Falchion
Software Windows 11 64bit
Download hwinfo, run it, then play a game and exit so you can see the temps.
I think it’s throttling issue.
1,854 (0.39/day)
Romania
Your monitor is 144Hz. Why are you not limiting your framerate to 60-90 fps ? I have a G14 too, but with a GTX1650. And when i play on it i always limit my framerate to 30 or 60fps depending on the type of game.
I also did unerclock my 4800HS using the guide bellow, i have yet to see a real performance hit, but the temperature dropped by about 15-20ºC. Try this, you can easily change it if you want more performance:
Solaris17
27,186 (3.83/day)
Alabama
VR HMD Quest 3
skilledguitarnoob
28 (0.06/day)
Yeah but logs?
how do i get logs ?
Central Processor(s) ------------------------------------------------------
[CPU Unit Count]
Number Of Processor Packages (Physical): 1
Number Of Processor Cores: 8
Number Of Logical Processors: 16
AMD Ryzen 7 4800HS --------------------------------------------------------
[General Information]
Processor Name: AMD Ryzen 7 4800HS
Original Processor Frequency: 2900.0 MHz
Original Processor Frequency [MHz]: 2900
CPU ID: 00860F01
Extended CPU ID: 00860F01
CPU Brand Name: AMD Ryzen 7 4800HS with Radeon Graphics
CPU Vendor: AuthenticAMD
CPU Stepping: RN-A1
CPU Code Name: Renoir
CPU Technology: 7 nm
CPU OPN: 100-000000099
CPU Thermal Design Power (TDP): 45.0 W
CPU Thermal Design Current (TDC): Limit: 51.0 A
CPU Electrical Design Current (EDC): Limit: 90.0 A
CPU Package Power Tracking (PPT): Limit: 42.0 W
APU STAPM (Skin Temperature-Aware Power Management) Limit: 45.0 W
CPU Power Limit 1 (Long Duration)/Processor Base Power (PBP): Power = 42.00 W [Unlocked]
CPU Power Limit 2 (Short Duration)/Maximum Turbo Power (MTP): Power = 60.00 W [Unlocked]
CPU Max. Junction Temperature (Tj,max): 96 C
CPU PBO Scalar (Reliability Reduction): 1.00x
CPU Thermal Trip Limit: 115.0 C
CPU HTC Temperature Limit: 115.5 C
CPU Type: Production Unit
CPU Platform: FP6
Microcode Update Revision: 8600104
SMU Firmware Revision: 55.67.0
Core Performance Order: 3, 4, 5, 7, 2, 8, 1, 6
cLDO VDDP: 0.7514 V
Number of CPU Cores: 8
Number of Logical CPUs: 16
[Operating Points]
CPU Minimum: 400.0 MHz = 4.00 x 100.0 MHz
CPU Base: 2900.0 MHz = 29.00 x 100.0 MHz
CPU Boost Max (Fmax): 4300.0 MHz = 43.00 x 100.0 MHz
Precision Boost Clock Limit: 4300.0 MHz = 43.00 x 100.0 MHz
CPU Automatic Overclocking Offset: 0 MHz
CPU Current: 4042.7 MHz = 40.50 x 99.8 MHz @ 1.2813 V
CPU Bus Type: UMI
NVIDIA GeForce RTX 2060 ---------------------------------------------------
[Video Chipset]
Video Chipset: NVIDIA GeForce RTX 2060
Video Chipset Codename: TU106M
Video Memory: 6144 MBytes of GDDR6 SDRAM [Samsung]
[Video Card]
Video Card: NVIDIA GeForce RTX 2060 with Max-Q Design [ASUS]
Video Bus: PCIe v3.0 x16 (8.0 GT/s) @ x8 (8.0 GT/s)
GPU Type: Discrete
Video RAMDAC: Integrated RAMDAC
Video BIOS Version: 90.06.58.40.03
Video Chipset Revision: A1
[Performance]
Graphics Processor Clock: 1215.0 MHz
Video Unit Clock: 1125.0 MHz
Graphics Memory Clock: 1375.2 MHz (Effective 11002.0 MHz)
Graphics Memory Bus Width: 192-bit
Number Of ROPs: 48
Number Of Unified Shaders: 1920
Number Of Ray Tracing Cores: 30
Number Of Tensor Cores: 240
Number Of TMUs (Texture Mapping Units): 120
ASIC Manufacturer: TSMC
ASIC Serial Number: 466067394961
NVIDIA SLI Status: Not Present
Resizable BAR (ReBAR) Support: Supported
Resizable BAR (ReBAR) State: Disabled (256 MB)
Hardware ID: PCI\VEN_10DE&DEV_1F12&SUBSYS_1F111043&REV_A1
PCI Location (Bus:Dev:Fnc): 1:00:0
[Driver Information]
Driver Manufacturer: NVIDIA
Driver Description: NVIDIA GeForce RTX 2060 with Max-Q Design
Driver Provider: NVIDIA
Driver Version: 30.0.15.1278 (GeForce 512.78)
Driver Date: 05-May-2022
DCH/UWD Driver: Capable
DeviceInstanceId PCI\VEN_10DE&DEV_1F12&SUBSYS_1F111043&REV_A1\4&21CF790E&0&0009
Location Paths PCIROOT(0)#PCI(0101)#PCI(0000)
771 (0.77/day)
London, UK
Mouse Razer Viper
Run hwinfo, click at the clock icon to reset the values.
Then play any game for some minutes.
Exit and check if there is throttling due to high temps.
Then you can see the maximum temps for cpu and gpu.
865 (1.18/day)
System Name Lenovo slim 5 16'
Processor AMD 8845hs
Motherboard Lenovo motherboard
Cooling 2 fans
Memory 64gb 5600mhz cl40
Video Card(s) 4070 laptop
Storage 16tb, x2 8tb SSD
Display(s) 16in 16:10 (1920x1200) 144hz
Power Supply 270w psu
take a screen shot by clicking the windows key, right shift and S key
118 (0.08/day)
Processor R7 7800X3D
Motherboard MSI B650 Tomahawk
Memory 2x32GB 6000CL30
Video Card(s) RTX 3070 FE
Case Lian Li O11 Air Mini
Power Supply Corsair RM1000x
1) check your temps, clocks and gpu/cpu utilization
2) make sure the game is running on your 2060 and not the iGPU. Some games can run into issues when trying to juggle the workloads between iGPU and dGPU, you can look into disabling iGPU to see if that fixes it
2,520 (0.52/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Case Corsair 275R
Mouse Logitech G Pro (Hero)
Some laptops seem to have "secret-severe-throttling-syndrome", something I would never expect with a decent laptop!
Stutters are also a symptom of a faulty SSD. Common symptoms of a faulty SSD are: Error messages from Windows about a file being corrupted coming out-of-the-blue, and extreme slowness that occurs randomly.
