I have a 3080ti 20gb how can I hit the drive
jioshj
3 (0.00/day)
934 (0.14/day)
Round Rock, TX
Processor 9950x
Motherboard Asus Strix X870E-E
Cooling Kraken Elite 280
Memory 64GB G.skill 6000mhz CL30
Video Card(s) Sapphire 7900XTX Pulse
Storage 1X 4TB MP700 Pro - 1 X 4TB SN850X
Display(s) LG 32" 4K OLED + LG 38" IPS
Case Lian Li o11 Air Mini
Power Supply Corsair RM1000x
Software WIndows 11 Pro
I have to admit, i didnt even know this card existed until right now, lol
Are you asking where to get the driver? Looks like you already have it installed.
If you're asking why GPUZ doesnt see it, Looks like it was added in v2.52
  • Added support for NVIDIA GeForce RTX 4070 Ti, RTX 3080 Ti 20 GB, RTX 3070 Ti (GA102), RTX 3050 (GA107), A800 80 GB PCIe
jioshj
3 (0.00/day)
How do I install the driver
Forcibly installed drivers cannot deliver performance
7,425 (4.96/day)
São Paulo, Brazil
Video Card(s) RTX A2000 (soon: Palit GeForce RTX 5090 GameRock)
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
Unfortunately, this is an unreleased prototype graphics card, which is not supported by the regular NVIDIA graphics driver. The 320-bit 20 GB type of 3080 Ti was canceled in favor of the 384-bit, 12 GB type that released to the public.
You may want to try NVCleanstall and add device ID 2205 to the driver installer. But that's best I can guide you. Good luck!
jioshj
3 (0.00/day)
OK. I don't think I can use it
7,425 (4.96/day)
São Paulo, Brazil
Adding the device ID to the installer through NVCleanstall did not work? There are no official drivers for this graphics card as it was canceled shortly before its release. It is very similar to the RTX 3090 otherwise, so while modifying INFs or force-installing drivers, pick the original RTX 3090 as a reference.
The final RTX 3080 Ti is a different revision with a different configuration, it has half the memory capacity, but the entire bus is filled. They've also enabled LHR on it, which this prototype doesn't have.
wolf
Better Than Native
8,428 (1.30/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Memory 32GB DDR5 6000 CL30
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
Well done! It working at all is very cool, I'd love one of these pre-release cards as a collector.
Alex_Vorodis
2 (0.00/day)
Hahah :)
I have a second one the same. Half a year ago I bought two at once. :)
