I need help build 600 euro pc
502 (0.13/day)
Cyprus
Processor 13700KF - 5.7GHZ
Motherboard Z690 UNIFY-X
Cooling ARCTIC Liquid Freezer III 360 (NF-A12x25)
Memory 2x16 G.SKILL M-DIE (7200-34-44-44-28)
Video Card(s) XFX MERC 7900XT
Storage 1TB KINGSTON KC3000
Display(s) FI32Q
Case LIAN LI O11 DYNAMIC EVO
Audio Device(s) HD599
Power Supply RMX1000
Mouse PULSAR V2H
Keyboard KEYCHRON V3 (DUROCK T1 + MT3 GODSPEED R2)
Benchmark Scores Superposition 4k optimized - 20652
Hi guys i will make a computer and i need help picking out whats the best components to get for it. The site i will buy it from its computeruniverse , i got a 750 ti that i will tranfer over. Also i need a 240-256gb SSD. I would like it to be as "future proof" as i can get for that budget. Thanks guys
13,413 (1.99/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
You stated your budget and that's great. But you neglected to tell us the primary use for this computer. Is it for school or work papers? Social media and watching videos? Playing games only? Connecting to a home theater or what?
You said you have a 750 Ti. Is that it? So you also need a monitor? What size? What about keyboard and mouse? Speakers? OS?
4,844 (1.51/day)
Processor Core i7-13700
Cooling Cooler Master RGB something
Memory Corsair DDR5-6000 small OC to 6200
Storage 970 EVO NVMe M.2 500GB,,WD850N 2TB
Case Phantek Eclipse P400S
Audio Device(s) EVGA NU Audio
Power Supply EVGA 850 BQ
Software Windows 11 Professional v23H2
18,584 (2.68/day)
System Name AlderLake
Durvelle27
6,800 (1.49/day)
Memphis, TN
System Name Black Prometheus
Processor |
Cooling Thermalright PA120 SE |
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
18,584 (2.68/day)
Thats a really tight budget if you need all hardware parts and mouse, keyboard, monitor, OS, minus the graphics card...
502 (0.13/day)
Cyprus
Display(s) FI32Q
Mouse PULSAR V2H
No i only need the computer , cpu with aftermarket cooler if possible ,motherboard ,ram ,psu ,case and the ssd. Use will be light , movies and some moba games which the 750 ti can do just fine. Also i got an OS already so the budget is only for the hardware
13,413 (1.99/day)
Nebraska, USA
Mouse Logitech M190
You can certainly save some money by getting a CPU that comes with an OEM cooler. Contrary to what many want us to believe, OEM coolers are quite capable, even with mild to moderate overclocking - assuming a properly cooled case.
I recommend you buy as much RAM as you think you will ever need now - even if that means buying a lessor CPU for now.
Do you prefer Intel or AMD processors?
502 (0.13/day)
Cyprus
Display(s) FI32Q
Mouse PULSAR V2H
I do not mind, i just want to make the best computer for the budget i got .
peche
Thermaltake fanboy
6,709 (1.81/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
what about the rig listed on system specs?
600E will be for: Case / motherboard / processor / ram / psu
you already have SSD & Video Card right?
silentbogo
5,586 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
To be honest, at that budget you can't make anything "future-proof" , but if it is a MOBA PC, then it is a bit easier.
Basically all you need is i3-6100, a cheap H110 motherboard and some RAM.
Throw it all into a cardboard box, and you have a working PC.
On a serious note, check out this build:
http://uk.pcpartpicker.com/list/RDx8QV
Plug in your GTX750Ti, and start saving for next year's AMD Vega GPU.
P.S. with mainstream CPUs you don't really need aftermarket cooling. Especially today.
502 (0.13/day)
Cyprus
Display(s) FI32Q
Mouse PULSAR V2H
This pc is not for myself but i will be the one buying it ,
I would like if possible to get an i5 inside this.
Serious though, that pc is on GBP not on EUR , its about 80-100 out of budget but im pretty okay getting an i5 for this pc so it fits in budget just fine, the thing im worried about , 360w is enough for any future GPU upgrades ? Is that motherboard a good one? at 30eur more or so i can get a z170 gigabyte k3 one. Thanks for the help !
Kanan
Tech Enthusiast & Gamer
3,517 (1.03/day)
Europe
System Name eazen corp | Xentronon 7.2
Processor AMD Ryzen 7 3700X // PBO max.
Cooling Noctua NH-D14 SE2011 w/ AM4 kit // 3x Corsair AF140L case fans (2 in, 1 out)
Memory G.Skill Trident Z RGB 2x16 GB DDR4 3600 @ 3800, CL16-19-19-39-58-1T, 1.4 V
Video Card(s) Asus ROG Strix GeForce RTX 2080 Ti modded to MATRIX // 2000-2100 MHz Core / 1938 MHz G6
Storage Silicon Power P34A80 1TB NVME/Samsung SSD 830 128GB&850 Evo 500GB&F3 1TB 7200RPM/Seagate 2TB 5900RPM
Display(s) Samsung 27" Curved FS2 HDR QLED 1440p/144Hz&27" iiyama TN LED 1080p/120Hz / Samsung 40" IPS 1080p TV
Case Corsair Carbide 600C
Audio Device(s) HyperX Cloud Orbit S / Creative SB X AE-5 @ Logitech Z906 / Sony HD AVR @PC & TV @ Teufel Theater 80
Power Supply EVGA 650 GQ
Mouse Logitech G700 @ Steelseries DeX // Xbox 360 Wireless Controller
Keyboard Corsair K70 LUX RGB /w Cherry MX Brown switches
VR HMD Still nope
Benchmark Scores 15 095 Time Spy | P29 079 Firestrike | P35 628 3DM11 | X67 508 3DM Vantage Extreme
That build is good (silentbogos). If you want an i5 replace the i7 with an i5 6500 and also I would go for a psu with at least 500 watts. The rest is fine.
Motherboard is fine unless you want to overclock but then you need another cpu too which also increases the price a lot.
8,098 (1.34/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
Why not: https://www.techpowerup.com/reviews/MSI/Nightblade_MI2/
And before anyone has a cow about the 350 watt PSU:
Even with ridiculous loads such a system would never see during normal use, the maximum power I could get my chosen configuration to pull was 304 W. A couple more drives might make those numbers go up just a bit, but we're talking about a mechanical and an M.2 SSD as the only possible options. I used an MSI GAMING GTX 970 and an Intel i7-6700K as well as two 8 GB SO-DIMMs (the maximum supported is 32 GB), so any configuration below these specs should have no problems whatsoever in running for a long time without stressing FPS's 350W power supply.
502 (0.13/day)
Cyprus
Display(s) FI32Q
Mouse PULSAR V2H
What do you guys think of this :
OCZ trion 150 240gb
2x8gb g.skill 2400mhz cl11
ASUS 970 PRO GAMING/ AURA V2.2
AMD FX-8320E
XFX XTR 550w
NZXT Source 340
Cooler Master Hyper 212 Evo
Is it worth getting the amd 8-core over the i5 6500 ? it will save me about 80eur which are spent on better case / psu .
Also it fits the budget perfectly :D
Edit: Is it worth to wait for those 80eur and just go for the same stuff plus i5 6500, and a ASUS B150 PRO GAMING instead ?
8,098 (1.34/day)
Hillsboro, OR
System Name Main/DC
Get Intel, or wait until January for AMD "Zen". The AM3+ socket is end of life.
502 (0.13/day)
Cyprus
Display(s) FI32Q
Mouse PULSAR V2H
22,806 (6.06/day)
Okay man, i will wait then to get intel , thanks
If you want performance on a budget, scour the interwebs for a Haswell or Broadwell i5-K, stick a 20-25 euro tower cooler on it and go wild. You'll have a top-end mainstream rig and all it costs is 10% performance per clock over a Skylake build, at probably 2/3 or even half the price. You'll also get to buy much cheaper DDR3 RAM instead of DDR4, and again, performance difference is negligible.
33 (0.01/day)
OCZ trion 150 240gb
AMD FX-8320E
XFX XTR 550w
NZXT Source 340
Intel Core i5-6500
MSI B150M Mortar
Corsair Vengeance LPX Black 8GB DDR4 Kit (2x4GB) 2400 MHz CL14
Arctic Freezer 11 LP
OCZ Trion 150 480 GB
Seasonic S12II-520 Bronze 520 Watt
Fractal Design Core 1500
Or any other decent case under 50 euros and start saving for a graphics card.
1,200 (0.17/day)
System Name Desktop / Laptop
Processor AMD Ryzen R7 5600x / Intel i5-4200U
Motherboard ASUS TUF B550-Plus / Lenovo MB
Cooling Arctic Liquid Freezer II 280 / Stock
Memory Corsair Vengeance 2x16GB DDR 3800 / 8GB DDR3-1600MHz
Video Card(s) AMD Radeon 6900XT / Intel HD 4400
Storage 2.5TB SSDs + 4TB HDD / Samsung 850 EVO 500 GB
Display(s) 34" LG Ultrawide / 12.5 " 1080p IPS Touchscreen
Case Fractal Design R6 / Lenovo X240
Audio Device(s) Onboard / Onboard
Power Supply Enermax REVOLUTION87+ 1000W / Lenovo 40W
Mouse Razer Basilisk X
Keyboard Dell Business Multimedia Keyboard
Benchmark Scores Chicken Invaders 5 @125+ FPS
Do you plan to overclock? And do you have hard drive or you need one?
Here are 3 example builds:
If you don't plan to overclock and have a HDD (622e):
If you plan to overclock and have a HDD (606e):
If you don't plan to overclock and dont have a HDD (615e):
If you don;t plan to ever overclock you can further bring down the cost by buying a H170 or B150 motherboard.
1,025 (0.33/day)
Croatistan
System Name 1.21 gigawatts!
Processor Intel Core i7 6700K
Motherboard MSI Z170A Krait Gaming 3X
Cooling Be Quiet! Shadow Rock Slim with Arctic MX-4
Memory 16GB G.Skill Ripjaws V DDR4 3000 MHz
Video Card(s) Palit GTX 1080 Game Rock
Storage Mushkin Triactor 240GB + Toshiba X300 4TB + Team L3 EVO 480GB
Display(s) Philips 237E7QDSB/00 23" FHD AH-IPS
Case Aerocool Aero-1000 white + 4 Arctic F12 PWM Rev.2 fans
Audio Device(s) Onboard Audio Boost 3 with Nahimic Audio Enhancer
Power Supply FSP Hydro G 650W
Mouse Cougar 700M eSports white
Keyboard E-Blue Cobra II
Software Windows 8.1 Pro x64
Benchmark Scores Cinebench R15: 948 (stock) / 1044 (4,7 GHz) FarCry 5 1080p Ultra: min 100, avg 116, max 133 FPS
You didn't mention whether you need monitor, peripherals...
Here is one configuration for 595 € without GPU, monitor and peripherals:
502 (0.13/day)
Cyprus
Display(s) FI32Q
Mouse PULSAR V2H
I will be needing peripherals but they are extra , 600euro are for the computer only without the GPU .
The one i think i will go for is very similar to the one you posted but instead there is no HDD or DVD and the psu i think is the xfx xtr 550 which is higher quality and for case the nzxt s340.
The HDD can be added later if necessary , same for the DVD burner.
Thanks
1,025 (0.33/day)
Croatistan
You cannot add DVD drive in NZXT case. Personally, I would stay away from NZXT and Fractal, regardless of their popularity, for two reasons: they don't have DVD slots (you can place also fan controllers in DVD slot, which is a nice thing) and they are too expensive for what they offer. There are other good cases for reasonable price such as Zalman R1, Zalman Z9 Neo, Deepcool Dukase V2, Deepcool Tesseract SW, Sharkoon VS4-W and they are almost twice cheaper than hyped NZXT.
XFX XTR is good, but pretty much any PSU from reputable manufacturers will do, unless you plan to push your PC over the limits. Anyway, check Enermax Maxpro 600W, which is an excellent PSU for reasonable price. I think its about 60€ in Germany.
1,200 (0.17/day)
Thanks
You don't really need a 100 euro PSU in a 600e system. I think you should better invest these money in better cpu, bigger ssd or better mobo. The cx550m is a very solid psu. I had mine running with a overclocked fx-6300 and my 7950 which under full occt psu stress test would pull ~500w from the socket. With my i5 I pull about ~400w heavily overclocked and with current and future gpus pulling much less you won't need more than that in all honesty.
Also if you don't get a K cpu and you don't overclock the stock cooler is good enough. I ran my 2500k with a stock pentium g630 cooler for a while until I got money to get good water aio to be able to push it further.
502 (0.13/day)
Cyprus
Display(s) FI32Q
Mouse PULSAR V2H
Well a 30euro cooler to get cooler and quieter than stock is worth it i think ,
for the psu i do agree its a bad choice for this price point but i do want to get a good component one ,
although if you say that the corsair one will do fine then i might grab that and save 40-50 eur or so.
The most problem i have is choosing a motherboard from b150 h170 z170 being so close in price they are confusing.
