I need help build 600 euro pc
1,200 (0.17/day)
System Name Desktop / Laptop
Processor AMD Ryzen R7 5600x / Intel i5-4200U
Motherboard ASUS TUF B550-Plus / Lenovo MB
Cooling Arctic Liquid Freezer II 280 / Stock
Memory Corsair Vengeance 2x16GB DDR 3800 / 8GB DDR3-1600MHz
Video Card(s) AMD Radeon 6900XT / Intel HD 4400
Storage 2.5TB SSDs + 4TB HDD / Samsung 850 EVO 500 GB
Display(s) 34" LG Ultrawide / 12.5 " 1080p IPS Touchscreen
Case Fractal Design R6 / Lenovo X240
Audio Device(s) Onboard / Onboard
Power Supply Enermax REVOLUTION87+ 1000W / Lenovo 40W
Mouse Razer Basilisk X
Keyboard Dell Business Multimedia Keyboard
Benchmark Scores Chicken Invaders 5 @125+ FPS
Z170 is of course the best because you can overclock even non k cpus by upping the bclk
831 (0.27/day)
System Name Gaming Desktop
Processor i7 6700k
Motherboard asus rog alpha
Cooling H110i
Memory Corsair Dominator 16gb DDR4 3200
Video Card(s) GTX 1080
Storage EVO 840 500gb, EVO 850 500gb, Perc 710 Raid WD RED 4tbx4
Case Corsair 500r
Power Supply Antec 850
Mouse Logitec G502
Keyboard a cheap dell
The most problem i have is choosing a motherboard from b150 h170 z170 being so close in price they are confusing.
if you're not getting a K proc then you don't need a Z motherboard. if you're getting a K proc you want a Z motherboard.
18,584 (2.66/day)
System Name AlderLake
872 (0.14/day)
Copenhagen, Denmark
System Name Ryzen/Laptop/htpc
Processor R9 3900X/i7 6700HQ/i7 2600
Motherboard AsRock X470 Taichi/Acer/ Gigabyte H77M
Cooling Corsair H115i pro with 2 Noctua NF-A14 chromax/OEM/Noctua NH-L12i
Memory G.Skill Trident Z 32GB @3200/16GB DDR4 2666 HyperX impact/24GB
Video Card(s) TUL Red Dragon Vega 56/Intel HD 530 - GTX 950m/ 970 GTX
Storage 970pro NVMe 512GB,Samsung 860evo 1TB, 3x4TB WD gold/Transcend 830s, 1TB Toshiba/Adata 256GB + 1TB WD
Display(s) Philips FTV 32 inch + Dell 2407WFP-HC/OEM/Sony KDL-42W828B
Case Phanteks Enthoo Luxe/Acer Barebone/Enermax
Audio Device(s) SoundBlasterX AE-5 (Dell A525)(HyperX Cloud Alpha)/mojo/soundblaster xfi gamer
Power Supply Seasonic focus+ 850 platinum (SSR-850PX)/165 Watt power brick/Enermax 650W
Mouse G502 Hero/M705 Marathon/G305 Hero Lightspeed
Keyboard G19/oem/Steelseries Apex 300
Software Win10 pro 64bit
Hi guys i will make a computer and i need help picking out whats the best components to get for it. The site i will buy it from its computeruniverse , i got a 750 ti that i will tranfer over. Also i need a 240-256gb SSD. I would like it to be as "future proof" as i can get for that budget. Thanks guys
what do you think about this system? i didn't put a GPU because you said that you would use the 750ti, and i didn't put a case because i don't know what you would prefer.
1,025 (0.33/day)
Croatistan
System Name 1.21 gigawatts!
Processor Intel Core i7 6700K
Motherboard MSI Z170A Krait Gaming 3X
Cooling Be Quiet! Shadow Rock Slim with Arctic MX-4
Memory 16GB G.Skill Ripjaws V DDR4 3000 MHz
Video Card(s) Palit GTX 1080 Game Rock
Storage Mushkin Triactor 240GB + Toshiba X300 4TB + Team L3 EVO 480GB
Display(s) Philips 237E7QDSB/00 23" FHD AH-IPS
Case Aerocool Aero-1000 white + 4 Arctic F12 PWM Rev.2 fans
Audio Device(s) Onboard Audio Boost 3 with Nahimic Audio Enhancer
Power Supply FSP Hydro G 650W
Mouse Cougar 700M eSports white
Keyboard E-Blue Cobra II
Software Windows 8.1 Pro x64
Benchmark Scores Cinebench R15: 948 (stock) / 1044 (4,7 GHz) FarCry 5 1080p Ultra: min 100, avg 116, max 133 FPS
Well a 30euro cooler to get cooler and quieter than stock is worth it i think ,
for the psu i do agree its a bad choice for this price point but i do want to get a good component one ,
although if you say that the corsair one will do fine then i might grab that and save 40-50 eur or so.
Corsair CX550M is made by CWT and uses chinese or taiwanese capacitors. Not necessarily bad, but they are second tier. Enermax Maxpro is produced by Enermax and uses japanese capacitors, but it isn't modular.
If you plan to upgrade CPU in the future, take MSI Z170A Krait Gaming 3X or Krait Gaming R6 Siege motherboard, which are 30€ more expensive than the one I previously suggested. However, if you plan to keep your PC for about 4 or less years, go with MSI H170 Gaming M3, which is a very good motherboard.
If you are on a very strict budget, pick Gigabyte GA-B150 HD3P which is 30€ cheaper than MSI H170.
My personal choice for i5 6500 would be MSI H170 Gaming M3...
504 (0.13/day)
Cyprus
Processor 13700KF - 5.7GHZ
Motherboard Z690 UNIFY-X
Cooling ARCTIC Liquid Freezer III 360 (NF-A12x25)
Memory 2x16 G.SKILL M-DIE (7200-34-44-44-28)
Video Card(s) XFX MERC 7900XT
Storage 1TB KINGSTON KC3000
Display(s) FI32Q
Case LIAN LI O11 DYNAMIC EVO
Audio Device(s) HD599
Power Supply RMX1000
Mouse PULSAR V2H
Keyboard KEYCHRON V3 (DUROCK T1 + MT3 GODSPEED R2)
Benchmark Scores Superposition 4k optimized - 20652
I'm going for something like this, i know 650w is overkill but its the same price as the 550w so why not (im not going over by many watts to reduce efficiency anw).
Also for the case there is the fractal r4, define s, s340 , so im going for something among those 4 (with the one on the build being the most favorite).
Cpu with stock cooler is 23 euro more so its cheaper to go for aftermarket cooler, i think this one will suffice.
Do you see anything i should change ?
Thanks all for the help.
504 (0.13/day)
Cyprus
Display(s) FI32Q
Mouse PULSAR V2H
I'm between Enermax Maxpro , corsair vengeance and seasonic s12ii for psu, all 3 seem to have good reviews and i dont care being modular or not.
I really don't have any idea which to go for :p
Edit: actually as the budget allows for something more expensive i do have the choice to go for something else also. Not sure if its worth it though.
831 (0.27/day)
Processor i7 6700k
Cooling H110i
Case Corsair 500r
Mouse Logitec G502
not bad. i'd probly spend the extra 2 euros on the asrock z170 board list above in case you decide to upgrade later.
82 (0.03/day)
Melbourne
System Name Edit King
Processor i7 3930k
Motherboard ASRock X79 Extreme 6
Cooling Corsair H110i GT
Memory 4 x 4GB GSkill 2133
Video Card(s) R9 Nano x 2
Storage Seagate Barracuda 2TB
Display(s) LG 34UM88
Power Supply EVGA G2 750
Mouse Gigabyte M6580
Keyboard Azio
Computer Universe is a bit expensive. Try -
CPU: AMD FX-8370 4.0GHz 8-Core Processor (€176.98 @ Mindfactory)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (€35.71 @ Amazon Deutschland)
Motherboard: Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard (€137.52 @ Amazon Deutschland)
Memory: G.Skill Trident X Series 8GB (2 x 4GB) DDR3-2400 Memory (€58.74 @ Mindfactory)
Storage: Silicon Power Slim S55 240GB 2.5" Solid State Drive (€62.00 @ Amazon Deutschland)
Case: Corsair 300R ATX Mid Tower Case (€79.84 @ Mindfactory)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply (€63.51 @ Amazon Deutschland)
Total: €614.30
504 (0.13/day)
Cyprus
Display(s) FI32Q
Mouse PULSAR V2H
Total: €614.30
Thanks for the reply but i decided to go for an i5 , also i'm not from Germany i will be ordering from 1 place to ship here.
1,200 (0.17/day)
For 3 euros more get at least the Z170 board. Also as I showed you by buying cheaper case and shipping on a cooler now you can get a i7 in around the same price range or get a 500GB SSD with an i5. Do you really need to spend more than 10% of your budget on a case?
504 (0.13/day)
Cyprus
Display(s) FI32Q
Mouse PULSAR V2H
Thanks all for the help, these are the items i ordered yesterday. I might add a 1050 ti to replace the 750ti .
I know PSU is overkill but it was about the same price as the 500w one. Also motherboard was 10euro more expensive than the msi H170 one and i decided to get this ,
might do some bclk OC if i can get the bios that allows it.
Kanan
Tech Enthusiast & Gamer
3,517 (1.02/day)
Europe
System Name eazen corp | Xentronon 7.2
Processor AMD Ryzen 7 3700X // PBO max.
Cooling Noctua NH-D14 SE2011 w/ AM4 kit // 3x Corsair AF140L case fans (2 in, 1 out)
Memory G.Skill Trident Z RGB 2x16 GB DDR4 3600 @ 3800, CL16-19-19-39-58-1T, 1.4 V
Video Card(s) Asus ROG Strix GeForce RTX 2080 Ti modded to MATRIX // 2000-2100 MHz Core / 1938 MHz G6
Storage Silicon Power P34A80 1TB NVME/Samsung SSD 830 128GB&850 Evo 500GB&F3 1TB 7200RPM/Seagate 2TB 5900RPM
Display(s) Samsung 27" Curved FS2 HDR QLED 1440p/144Hz&27" iiyama TN LED 1080p/120Hz / Samsung 40" IPS 1080p TV
Case Corsair Carbide 600C
Audio Device(s) HyperX Cloud Orbit S / Creative SB X AE-5 @ Logitech Z906 / Sony HD AVR @PC & TV @ Teufel Theater 80
Power Supply EVGA 650 GQ
Mouse Logitech G700 @ Steelseries DeX // Xbox 360 Wireless Controller
Keyboard Corsair K70 LUX RGB /w Cherry MX Brown switches
VR HMD Still nope
Benchmark Scores 15 095 Time Spy | P29 079 Firestrike | P35 628 3DM11 | X67 508 3DM Vantage Extreme
Looks okay but rather buy a rx470 than a gtx 1050ti, way faster and only a tad more expensive.
504 (0.13/day)
Cyprus
Display(s) FI32Q
Mouse PULSAR V2H
Guys i got the items but its not booting , i tried outside of the case with motherboard+cpu + cooler (connected to cpu_fan) and 1 or both rams on different slots , PSU connected 24pin and cpu 8pin.
I start it it shows nothing (i tried installing the 750 ti too) , i changed from hdmi to dvi still nothing , i even did a cmon reset still nothing , i tried with different psu also .
I do not own other ddr4 to test or other 1151 motherboard, any idea what is going wrong or how to fix it ?
There is no screen or audio on the motherboard to identify the problem so i am clueless on what is going wrong , PC starts (black screen) and after a while it shutdowns and restarts (endless loop)
504 (0.13/day)
Cyprus
Display(s) FI32Q
Mouse PULSAR V2H
I read now one comment that says with higher clock ram the motherboard wont boot , you have to install a 2133mhz ones and set from bios the xmp to boot , i hope this is the problem and i will test it as soon as i can get my hands on one
831 (0.27/day)
Processor i7 6700k
Cooling H110i
Case Corsair 500r
Mouse Logitec G502
before you go scavenging for ram. a little troubleshooting is in order.
1st unplug everything but power and fans and double check those connections. remove any pci/pcie devices.
put in 1 ram stick and see if it boots.
high speed ram should default to 2133 and boot. if theres a cmos clear option via button or jumper try that.
504 (0.13/day)
Cyprus
Display(s) FI32Q
Mouse PULSAR V2H
But i said i did all those things :p also i assembly the motherboard and cpu outside of the case so no fans or any other connection just cpu motherboard cooler PSU and ram(which i tried in every spot each ram).
I know high speed ram should default to 2133 and boot but i found a comment on amazon that says it wouldnt boot with higher freq ram and he had to put lower speed ones , configure the bios and then put the other ram to work.
Ofcourse it may be a DOA mobo but i have to try that first , also to eliminate the possibility the ram are at fault so all that remains is the motherboard and CPU.
I discharged myself before touching the components and i aligned the cpu to the motherboard correctly, i did not screw up anything i'm certain.
504 (0.13/day)
Cyprus
Display(s) FI32Q
Mouse PULSAR V2H
Problem is fixed , everything works great and temps are incredibly low , to the point where i consider something being wrong :p
CPU : 19C idle , 34C under full load (OCCT)
