System Name | HELLSTAR |
Processor | AMD RYZEN 9 5950X |
Motherboard | ASUS Strix X570-E |
Cooling | 2x 360 + 280 rads. 3x Gentle Typhoons, 3x Phanteks T30, 2x TT T140 . EK-Quantum Momentum Monoblock. |
Memory | 4x8GB G.SKILL Trident Z RGB F4-4133C19D-16GTZR 14-16-12-30-44 |
Video Card(s) | Sapphire Pulse RX 7900XTX. Water block. Crossflashed. |
Storage | Optane 900P[Fedora] + WD BLACK SN850X 4TB + 750 EVO 500GB + 1TB 980PRO+SN560 1TB(W11) |
Display(s) | Philips PHL BDM3270 + Acer XV242Y |
Case | Lian Li O11 Dynamic EVO |
Audio Device(s) | SMSL RAW-MDA1 DAC |
Power Supply | Fractal Design Newton R3 1000W |
Mouse | Razer Basilisk |
Keyboard | Razer BlackWidow V3 - Yellow Switch |
Software | FEDORA 41 |
I wanted to see if the power supply would work without the fan.
What did I do wrong?
Will it work with cooking oil?
System Name | RogueOne |
Processor | Xeon W9-3495x |
Motherboard | ASUS w790E Sage SE |
Cooling | SilverStone XE360-4677 |
Memory | 128gb Gskill Zeta R5 DDR5 RDIMMs |
Video Card(s) | MSI SUPRIM Liquid X 4090 |
Storage | 1x 2TB WD SN850X | 2x 8TB GAMMIX S70 |
Display(s) | 49" Philips Evnia OLED (49M2C8900) |
Case | Thermaltake Core P3 Pro Snow |
Audio Device(s) | Moondrop S8's on schitt Gunnr |
Power Supply | Seasonic Prime TX-1600 |
Mouse | Lamzu Atlantis mini (White) |
Keyboard | Monsgeek M3 Lavender, Moondrop Luna lights |
VR HMD | Quest 3 |
Software | Windows 11 Pro Workstation |
Benchmark Scores | I dont have time for that. |
All of this. Please don’t use cooking oil.As soon you put something in... like even the housing, it is contaminated.
Do pure mineral oil or 3M Novec
Processor | faster at instructions than yours |
Motherboard | more nurturing than yours |
Cooling | frostier than yours |
Memory | superior scheduling & haphazardly entry than yours |
Video Card(s) | better rasterization than yours |
Storage | more ample than yours |
Display(s) | increased pixels than yours |
Case | fancier than yours |
Audio Device(s) | further audible than yours |
Power Supply | additional amps x volts than yours |
Mouse | without as much gnawing as yours |
Keyboard | less clicky than yours |
VR HMD | not as odd looking as yours |
Software | extra mushier than yours |
Benchmark Scores | up yours |
why not just take out the fan?I wanted to see if the power supply would work without the fan.
it wouldWould not any dirt and residue in the power supply make the distilled water electrically conductive?
“Quiet, you”All of this. Please don’t use cooking oil.
like a fried turkey....that is a brilliant idea and you should go for it. Please make a video of it as well for all of usWill it work with cooking oil?
System Name | CyberPowerPC ET8070 |
Processor | Intel Core i5-10400F |
Motherboard | Gigabyte B460M DS3H AC-Y1 |
Memory | 2 x Crucial Ballistix 8GB DDR4-3000 |
Video Card(s) | MSI Nvidia GeForce GTX 1660 Super |
Storage | Boot: Intel OPTANE SSD P1600X Series 118GB M.2 PCIE |
Display(s) | Dell P2416D (2560 x 1440) |
Power Supply | EVGA 500W1 (modified to have two bridge rectifiers) |
Software | Windows 11 Home |
System Name | AM4_TimeKiller |
Processor | AMD Ryzen 5 5600X @ all-core 4.7 GHz |
Motherboard | ASUS ROG Strix B550-E Gaming |
Cooling | Arctic Freezer II 420 rev.7 (push-pull) |
Memory | G.Skill TridentZ RGB, 2x16 GB DDR4, B-Die, 3800 MHz @ CL14-15-14-29-43 1T, 53.2 ns |
Video Card(s) | ASRock Radeon RX 7800 XT Phantom Gaming |
Storage | Samsung 990 PRO 1 TB, Kingston KC3000 1 TB, Kingston KC3000 2 TB |
Case | Corsair 7000D Airflow |
Audio Device(s) | Creative Sound Blaster X-Fi Titanium |
Power Supply | Seasonic Prime TX-850 |
Mouse | Logitech wireless mouse |
Keyboard | Logitech wireless keyboard |
Are you sure you used distilled water? There's also de-mineralized water and also de-ionized water. There's difference in process how those water types are created.I wanted to see if the power supply would work without the fan.
Processor | Intel i9 9900K @5GHz w/ Corsair H150i Pro CPU AiO w/Corsair HD120 RBG fan |
Motherboard | Asus Z390 Maximus XI Code |
Cooling | 6x120mm Corsair HD120 RBG fans |
Memory | Corsair Vengeance RBG 2x8GB 3600MHz |
Video Card(s) | Asus RTX 3080Ti STRIX OC |
Storage | Samsung 970 EVO Plus 500GB , 970 EVO 1TB, Samsung 850 EVO 1TB SSD, 10TB Synology DS1621+ RAID5 |
Display(s) | Corsair Xeneon 32" 32UHD144 4K |
Case | Corsair 570x RBG Tempered Glass |
Audio Device(s) | Onboard / Corsair Virtuoso XT Wireless RGB |
Power Supply | Corsair HX850w Platinum Series |
Mouse | Logitech G604s |
Keyboard | Corsair K70 Rapidfire |
Software | Windows 11 x64 Professional |
Benchmark Scores | Firestrike - 23520 Heaven - 3670 |
System Name | le fish au chocolat |
Processor | AMD Ryzen 7 5800X |
Motherboard | ASRock B550 Phantom Gaming 4 |
Cooling | be quiet! Pure Rock 2 |
Memory | 2x 16GB (32 GB) G.Skill RipJaws V DDR4-3600 DIMM CL16-19-19-39 |
Video Card(s) | NVIDIA GeForce RTX 3080, 10 GB GDDR6X (ASUS TUF) |
Storage | 2 x 1 TB NVME & 2 x 4 TB SATA SSD in Raid 0 |
Display(s) | MSI Optix MAG274QRF-QD |
Power Supply | 750 Watt EVGA SuperNOVA G5 |
i sure hope ^^"This has to be a troll post, right?
that wouldn't matter, the second you put something in which is unclean (dust or minerals for an example) it becomes conductive againAre you sure you used distilled water? There's also de-mineralized water and also de-ionized water. There's difference in process how those water types are created.
Sometimes it is messy. Sometimes shop sells de-ionized water as distilled. De-ionized may contain micro organisms, bacteria, etc which can cause problems.
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality case, 2 x Fractal Design 140mm fans, stock CPU HSF |
Memory | 32GB (4 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Logitech M190 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
you can cross that question from your list of "PSU questions I thought I would never have to answer"The fire risk is enormous.
System Name | "Icy Resurrection" |
Processor | 13th Gen Intel Core i9-13900KS Special Edition |
Motherboard | ASUS ROG MAXIMUS Z790 APEX ENCORE |
Cooling | Noctua NH-D15S upgraded with 2x NF-F12 iPPC-3000 fans and Honeywell PTM7950 TIM |
Memory | 32 GB G.SKILL Trident Z5 RGB F5-6800J3445G16GX2-TZ5RK @ 7600 MT/s 36-44-44-52-96 1.4V |
Video Card(s) | ASUS ROG Strix GeForce RTX™ 4080 16GB GDDR6X White OC Edition |
Storage | 500 GB WD Black SN750 SE NVMe SSD + 4 TB WD Red Plus WD40EFPX HDD |
Display(s) | 55-inch LG G3 OLED |
Case | Pichau Mancer CV500 White Edition |
Power Supply | EVGA 1300 G2 1.3kW 80+ Gold |
Mouse | Microsoft Classic Intellimouse |
Keyboard | Generic PS/2 |
Software | Windows 11 IoT Enterprise LTSC 24H2 |
Benchmark Scores | I pulled a Qiqi~ |
System Name | DLSS / YOLO-PC |
Processor | i5-12400F / 10600KF |
Motherboard | Gigabyte B760M DS3H / Z490 Vision D |
Cooling | Laminar RM1 / Gammaxx 400 |
Memory | 32 GB DDR4-3200 / 16 GB DDR4-3333 |
Video Card(s) | RX 6700 XT / R9 380 2 GB |
Storage | A couple SSDs, m.2 NVMe included / 240 GB CX1 + 1 TB WD HDD |
Display(s) | Compit HA2704 / MSi G2712 |
Case | Matrexx 55 / Junkyard special |
Audio Device(s) | Want loud, use headphones. Want quiet, use satellites. |
Power Supply | Thermaltake 1000 W / Corsair CX650M / DQ550ST [backup] |
Mouse | Don't disturb, cheese eating in progress... |
Keyboard | Makes some noise. Probably onto something. |
VR HMD | I live in real reality and don't need a virtual one. |
Software | Windows 10 and 11 |
Yes.What did I do wrong?
Processor | Ryzen 7800X3D |
Motherboard | MSI MAG Mortar B650 (wifi) |
Cooling | be quiet! Dark Rock Pro 4 |
Memory | 32GB Kingston Fury |
Video Card(s) | Gainward RTX4070ti |
Storage | Seagate FireCuda 530 M.2 1TB / Samsumg 960 Pro M.2 512Gb |
Display(s) | LG 32" 165Hz 1440p GSYNC |
Case | Asus Prime AP201 |
Audio Device(s) | On Board |
Power Supply | be quiet! Pure POwer M12 850w Gold (ATX3.0) |
Software | W10 |
