i7-7700 non-K is not hitting 4.2GHz
272 (0.07/day)
CPU: i7-7700
Motherboard: asrock h270m-itx/ac
The CPU is not hitting 4.2GHz while playing heavy games, it runs at 4.0GHz, why?.
I didn't touch the BIOS...
Help?.
2,972 (0.57/day)
System Name Old Fart / Young Dude
Processor 2500K / 6600K
Motherboard ASRock P67Extreme4 / Gigabyte GA-Z170-HD3 DDR3
Cooling CM Hyper TX3 / CM Hyper 212 EVO
Memory 16 GB Kingston HyperX / 16 GB G.Skill Ripjaws X
Video Card(s) Gigabyte GTX 1050 Ti / INNO3D RTX 2060
Storage SSD, some WD and lots of Samsungs
Display(s) BenQ GW2470 / LG UHD 43" TV
Case Cooler Master CM690 II Advanced / Thermaltake Core v31
Audio Device(s) Asus Xonar D1/Denon PMA500AE/Wharfedale D 10.1/ FiiO D03K/ JBL LSR 305
Power Supply Corsair TX650 / Corsair TX650M
Mouse Steelseries Rival 100 / Rival 110
Keyboard Sidewinder/ Steelseries Apex 150
Software Windows 10 / Windows 10 Pro
4.2 is maximum single core frequency at which the processor is capable of operating using Intel® Turbo Boost Technology. On all four cores you will have a max of 4GHz
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (1.98/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Mouse cheap
Keyboard under going restoration
In "power options" try High performance
2,972 (0.57/day)
I don't see any reason why it shouldn't turbo to advertised values. If you right click in cpuz on core speed it will show you in real time the speed on all 4 cores. Or you can download hwinfo which I find good.
r9
3,300 (0.55/day)
System Name Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck
Processor i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t
Memory 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5
Video Card(s) RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs
Storage 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme
Display(s) 50" 4k TV | Dell 27" |22" |3.3"|7"
VR HMD Samsung Odyssey+ | Oculus Quest 2
Software Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro
I ran CineBench Single Core and the CPU doesn't pass 4.0GHz
what is wrong?.
I have Turbo Boost enabled in BIOS, I checked that...
Cinebench is multicore bench, it not gonna boost to 4.2GHz.
Try CPUz single core bench test.
18,584 (2.67/day)
System Name AlderLake
Run the CPU-Z benchmark.
3,034 (0.83/day)
Intel turbo boost needs certain things to be with in spec before it boost to its max. First of all max TDP must not be exceeded and a given temperature as well.
Your cores gets above 70 C and one at 78 C and that is high i my opinion.
In your screenshot even then you run single core bench there are load on more than one core/thread and that will not give you that 4.2 GHz boost clock. Only one core even maybe one thread before you will se the max boost.
try cpu-z benchmark or a stress test program like Prime95 and set to stress only one core and one thread.
3,505 (0.61/day)
80c shouldn't an issue. That's still 20c from Tfunction.
I've had i7-4770 run in low 90cs for years no problem.
272 (0.07/day)
I did it, I ran single core benchmark and the results are the same, 4.0GHz always
3,505 (0.61/day)
Well, I don't see a huge deal here but if you dislike what you are seeing, return the chip.
peche
Thermaltake fanboy
6,709 (1.80/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
get HWinfo, run sensors only... then ...Run valleybench which is free and decent for some tests....
then let us know....
Regards,
8,253 (1.18/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
the tempts on all four cores being about the same suggest to me that all four cores are working not just one.. if only one core was working hard the temps on the other three would be much lower..
what i am saying is you may think you are just running one core but you are running all four.. hence the cpu speed being only 4 gig
trog
43,051 (6.72/day)
Update your bios
5,731 (1.07/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
Can you set the multiplier in the bios to 42? and afaik 4.2ghz is the max boost on a single core, not all so you likely wont see it in games that are multithreaded, strange it doesn't boost up to that on a single core when stressed though
7,316 (1.03/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
Most H270 chipset boards u can't control the multiplier on plus it's a non "K" sku cpu.
5,731 (1.07/day)
West Midlands. UK.
I know it's non "K" but you can still run the highest multiplier on all cores on all non-K chips... that is of course if the motherboard allows it in this case it seems it doesn't which kinda sucks...
5,731 (1.07/day)
West Midlands. UK.
Don't normally double post so apologies, first newegg review states this:
P state values are incorrect for 7600k turbo boost. It would top out at 4.0 ghz instead of the CPUs 4.2 ghz stock value. I emailed ASRock technical support about this issue and got this response:
Try set up below BIOS setting in OC Tweaker > CPU configuration.
1. Long Duration Power Limit: 4095
2. Long Duration Maintained: 128
3. Short Duration Power Limit: 4095
4. CPU core current limit: 255.5
Test with Prime95 to load CPU 100%.
Check with CPU-Z for multiplier.
Seems to be a board issue not the processor, to the OP I would look into the suggestion from Asrock see if that addresses your issue, ok this is a different chip and an "K" one but I think this is the same issue as the OP is describing on his 7700, worth a look into.
272 (0.07/day)
Regards,
trog
Update your bios
Guys.
My CPU is a non-K model and my motherboard is a H model, I can not overclock the CPU.
The BIOS is updated.
Turbo boost is enabled.
I ran CineBench Single Core and the CPU doesn't pass 4.0GHz, sadly.
I will try the steps in the BIOS to see if the CPU can get up to 4.2GHz.
I had an ASUS H270 ATX motherboard last week and the CPU was working perfectly. This seems to be a motherboard issue or BIOS issue.
5,731 (1.07/day)
West Midlands. UK.
Guys.
My CPU is a non-K model....., I can not overclock the CPU.
As I said doesn't make a difference, if you had the option to change multi in the bios you could set all 4 cores to 42 and in effect overclock it... however as has been pointed out that's not an option on your board so it's kind of a moot point anyway.
it's describing the same scenario/issue you have so I'm guessing that would be your best bet, it might have however been fixed with a bios update are you running the latest bios for the board? EDIT: sorry missed the bit you said it has the latest bios, my bad!! let me know how you get on with those steps then :toast:
272 (0.07/day)
I tried and nothing happened.
The CPU kept 4.0GHz no matter what.
and yeah I'm running the latest bios update.
5,731 (1.07/day)
West Midlands. UK.
Maybe raise a support ticket with ASrock, definitely seems to be a board issue, and if you can't "fix" it, it's not really the worst problem in the world as you're only missing out on that 200mhz on a single core load :oops:
14,179 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
trog
^^^^This.
All four cores are working, not just one.
Even your Cinebench run shows you using 4 cores, not one as you think.
This appears to be user error.
Can you boot in to the BIOS and set just one core to run?
Ruru
S.T.A.R.S.
13,149 (2.98/day)
Jyväskylä, Finland
Processor AMD Ryzen 7 5800X / Intel Core i7-8600K
Audio Device(s) Sony WH-CN720N / TV speakers
VR HMD Oculus Rift CV1
I know my HTPC is a damn lot older, but I didn't have any problems with H61/2500K putting all cores at max multiplier.
And I'd try SuperPI since if something is a single core benchmark, that's one of those.
272 (0.07/day)
^^^^This.
Guys.
I tried my CPU with an Asus Z270 ATX motherboard and the CPU is hitting 4.2GHz perfectly.
It seems that my ASrock motherboard is having difficulties even having the latest BIOS update.
I opened a support ticket with ASRock.
