i9 13980HX successful undervolt
Orwennes
12 (0.03/day)
Core -90mV
P cache@4GHz -20mV
E cache -90mV
@Orwennes
Post some ThrottleStop screenshots so everyone can see your settings.
Did you set mV Boost? Most people can undervolt the P Cache a lot more if you set mV Boost to at least 150.
Nice! What laptop is this?
That looks like a 4.9GHz all core score, which would entail PL1/PL2 of around 185W I'm guessing. Sadly too many laptop brands have locked the PL to a lower value.
Though for gaming anything above 4.2GHz all core won't yield noticeable difference, and for rendering/decompression the limiting factor will ultimately be good sustained cooling.
MSI Vector 16 HX with 220W PL1/2 and 330W PL4
What are the FID multipliers and the actual PKG power consumption (both found in the main screen of Throttlestop) during Cinebench though?
The FID peaks at 52, gradually decreases after a few seconds due to overheating, and ends up at around 48 by the end of the benchmark.The PKG power peaks at 220W, gradually decreases after a few seconds due to overheating, and ends up at around 200W by the end of the benchmark.
