ID-Cooling FROZN A620 PRO SE
ARF
4,670 (2.55/day)
Ex-usa | slava the trolls
Yeah but I got the AK 620 Digital just for the looks and fancy display, not performance.
Why don't you buy a PC case with a display?
See Hyte Y70 https://hyte.com/store/y70?v=305
The cooler and potentially its mediocre performance could be the most annoying thing.
I will do the opposite. Not quite happy with the Arctic Freezer 34 eSports DUO (4 direct-touch heat pipes, but a Ryzen with chiplets), will be replaced by TLR PS 120 EVO with 7 anti-gravity modern heat pipes, and a solid base to make sure all of the heat pipes would take some load... :shadedshu:
crazyeyesreaper
Not a Moderator
9,819 (1.69/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
Direct Touch heatpipes are better again in theory but only when the heat they are soaking up is adequate. If 1 heatpipe sits on the Cores that 1 heatpipe can only absorb so much heat. While the IHS helps smooth that heat transfer out the problem is only 1 heatpipe is relatively speaking getting that heat. But using a well machined base the heat transfer to the heatpipes is more uniform and spreads that heat more effectively to the fins. Also getting an HDT base machined well is far more difficult there are typically voids and issues all one needs to do is look at Corsair cooler from a few years ago.
Also HDT design on bigger coolers can as the Corsair demonstrated cause compatibility issues with various motherboards where a heatpipe actually sits on a capacitor causing uneven pressure and heat transfer. The fact is a proper based that fully enclosing the heatpipes does a better job distributing heat to said numerous heatpipes. It also gives enough extra clearance to avoid conflicts.
This is why HDT is typically used on smaller and less expensive coolers it does a good job but as you go bigger and scale up it becomes a liability.
8,665 (3.99/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
You said what I said in clearer English.
This is why I don't write reviews!
409 (0.23/day)
System Name Old friend
Processor 3550 Ivy Bridge x 39.0 Multiplier
Memory 2x8GB 2400 RipjawsX
Video Card(s) 1070 Gaming X
Storage BX100 500GB
Display(s) 27" QHD VA Curved @120Hz
Power Supply Platinum 650W
Mouse Light² 200
Keyboard G610 Red
23,120 (6.10/day)
Can you recommend good fans? Some with more interesting shapes, and higher airflow?
Im a simple guy. The majority of fans are fine. BeQuiet, Fractal, Noctua, Phanteks all make great fans. People overcomplicate PC DIY way too much ;)
409 (0.23/day)
Storage BX100 500GB
Mouse Light² 200
Keyboard G610 Red
The same.
ARF
4,670 (2.55/day)
Have they invented a silent PC without fan stop?
Only the bequiet noise dampened cases are very quiet, but the fans themselves are quite pitiful, to be nice with them.
2,746 (6.34/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
@ARF
If it moves, be it a fan-blade or bearing - it makes noise. If the air moves through something with any kind of decent speed - it makes noise. This is simple reality of physics. The only reasonably achievable way of making a silent PC is without fans at all like those projects that essentially use an entire case as a heatsink for components. Or, I guess, submerging your hardware in mineral oil akin to what Linus did once. Both avenues have obvious drawbacks.
Now, this is me taking “silent” literally. For all intents and purposes a modern case with decent fans set up to a quiet curve will already be very good on the noise front. Especially if one is willing to compromise on compute power by going for lower wattage/thermal output components. But reasonably trying to build a LITERALLY silent PC with, say, an i9 and a 4090 is a fool’s errand by itself since you WILL need to cool it somehow. I guess one can side-step the issue completely by moving the PC itself to another room and making a hole in the wall for cables.
ARF
4,670 (2.55/day)
I disagree. You can walk silently, without any noise. This means that not the movement itself produces noise, but some of its characteristics - be it the speed, friction, resistance, or something else.
I.e., you can attach a 140 mm fan running at 300 RPM to a heatsink, and the system will be virtually silent.
You also didn't say anything about the heat pipes, thermo-electric element of Peltier, and AirJet. Does any of these produce so high amounts of noise?
14,241 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
2,746 (6.34/day)
You can’t, actually. Below hearing threshold is not silent. And the actual noise produced will depend on a myriad of factors. Pointless comparison anyway.
I thought we are also attempting actually cooling things along the way? And virtually silent and fully silent are not equal terms. Do pick a lane. I did say already that modern PCs, even relatively high power ones, can be made very quiet.
Did you just pick random cool terms out of the hat? Heat-pipes are useless on their own for most applications (there’s a reason we pair them with fin stacks), TEC is stupidly inefficient and AirJet is suitable for low power applications only, from what I’ve seen. If “silent or no” is your only yardstick - iPads are computers and are actually fully silent. There. So are some MacBooks and ultra-LP laptops. So by this logic, the answer to your question of
is yes, they did. With obvious compromises made, of course. You can use the same compromises to build a fully passive and thus silent desktop PC too, I am fairly sure. Won’t be a particularly powerful one, though. The higher you go in power consumption (which goes hand in hand with performance) - the higher the thermal load, and as such - the harder it is to passively/silently cool the components. Unless there are some sci-fi advancements made in a near future there’s no reason to think this would change.
23,120 (6.10/day)
Fractal Define is fantastic in noise dampening too. Especially if you run it without HDDs altogether like I do currently.
If you want a silent PC run it passively :) There is always a noise otherwise, which will eventually make itself heard anyway. Its just a matter of how/ when your ears pick up on it much like posters above are saying. This is my experience too; my PC is more audible at night, when the noises outside have died down. Can barely hear it during the day.
230 (0.44/day)
Motherboard ASUS Prime X670E-Pro WIFI
Cooling Noctua NH-D15S
Memory Kingston FURY Beast 2x16GB 6000MHz CL36
Video Card(s) Gainward RTX 2070 Super
Storage Samsung 990 Pro 2TB, Samsung 990 Pro 4TB, Samsung 970 EVO Plus 2TB, Lexar NM790 4TB
Case Fractal Design Meshify 2
Power Supply Corsair HX1000i ATX 3.1
Imagine buying a worse NH-D15 for three times this money. Or five times, if you get the new one.
For that you can place your own god tier fans on this one three times over as well.
Yeah, noctua is only good if you want long time support. I wish we had good budget coolers like this ID-Cooling or Thermalright back than.
I have a Macho somewhere that needs AM5 kit and fan clips for Standard 140mm fans and an Alpenföhn Olymp that needs fan clips for Standard 140mm fans too.
I got fed up with buying coolers every few years so I just went ahead and bought the D15S four years ago, Noctua sent me fan clips for free since the ones supplied with the cooler are made for 120mm spacing holes.
8,665 (3.99/day)
Case Veddha T2
Mouse MX Anywhere 2
I don't see this on the official ID Cooling EUR Amazon store page yet, which is ID Cooling's highest-profile, first-party sales channel, and where most of their stuff appears first.
They're also selling the smaller, inferior A610 for €35 on their official page, which makes me think that this $29.99 price is BS. If the manufacturer isn't selling at their MSRP, how do they expect their MSRPs to actually mean anything? This just stinks of a manufacturer making an unreasonably low MSRP to get more favourable reviews, with no intent to actually sell it at that price.
Don't get me wrong, I like ID cooling's stuff and I've bought a lot of it in the past but their prices shot up and that means they're vastly inferior to Thermalright in most of Europe now, and the tiny A610 for €35 ID-cooling's own page, which competes with sub-€20 Thermalright offerings like the Burst Assassin 120 means that the EUR price of this A620 Pro is likely €50 at the very least.
At €50 it's no competition for a €36 Peerless Assassin, end of discussion.
If we see this in Europe at the €35 price point that usually matches a $29 MSRP, then that's great - but all past and present evidence right from the manufacturer's own channels goes against that, so you'll have to forgive my cynicism - it's empirically justified.
This thread just pinged in my notifications and I thought I'd check to see if my cynicism over the $29.99 MSRP and European availability was justfied.
For once, I'm glad to be wrong. This thing is on sale in the UK for £29.99 and €39.99 in Germany. It's not quite as good as the US deal in mainland Europe but pricetracker shows it was selling in France for €34.99 last month too.
24 (0.04/day)
Argentina
Processor Ryzen 5 5600 PBO 4.6GHz
Motherboard Asrock B550 Phantom Gaming 4
Cooling CoolerMaster Hyper 212 Turbo
Memory 32GB Patriot Viper Steel DDR4 3600MHz
Video Card(s) Gigabyte RTX3090 Gaming OC
Storage Patriot Viper VPN110 500GB + XPG Gammix S11 Pro 1TB
Display(s) LG 27GP850-B
Case Lancool II Mesh Performance
Audio Device(s) ASUS Xonar DX 7.1 + Edifier R1600T
Power Supply Corsair RM750x
Mouse Logitech G403 Hero Gaming
Keyboard Patriot Viper V765
Sorry for reviving this, Im getting this cooler and a while ago I got 2x Sickleflow120 for my CM212, should I replace the A620's stock fans with the Sickleflows? Would that be an improvement? (I like the ARGB on the Sickleflows too). They deliver 62CFM vs 58 from the stock fans, at the same noise level.
For the record, this cooler costs $60 in Argentina while a Peerless Assassin costs $190 haha pretty unbeatable. The only other option for a cheap double tower cooler is the CM Hyper 620s also for $60.
8,665 (3.99/day)
Case Veddha T2
Mouse MX Anywhere 2
62CFM vs 58 from the stock fans is irrelevant, since fan CFM ratings and noise levels are tested without obstuction as "unfiltered, unobstructed case fans" which is an unrealistic scenario.
IMO, just try them yourself and see which ones work better for you. There are precious few reviews of the Sickleflow 120s, and the pretty vague consensus is that they're reasonable jack-of-all-trades fans. The ID cooling ones are also pretty mediocre, so I doubt there's a huge difference between them.
Honestly, if the CPU cooler isn't the loudest thing in your case, and you want ARGBLEDs, then just fit the Sickleflows. Do you really care if it's 3dBA louder when the graphics card fans are the dominant noise from your PC under load?
:O
In the EU, it's the other way around. The ID-Cooling stuff is twice the price of the equivalent Thermalright one. When the regional variance is this wild, just get whatever makes the most sense bro.
1,981 (0.43/day)
Denmark
Processor Ryzen 5 7600
Motherboard Asrock B650 PG LIgtning
Cooling arctic freezer 36
Memory 2 x Team Group T-Create Expert DDR5-6000 - 32GB - CL30 (64gb)
Video Card(s) ASUS Dual GeForce RTX 4070 EVO
Storage 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives
Display(s) LG 32GP850, IIyama G2470HSU-B1
Case Corsair 5000D airflow tg
Audio Device(s) Yamaha R-N800A Syatem audio signature 5
Power Supply Corsair RM850X White
Mouse Asus Rog Gladius III Wireless Aimpoint
Keyboard Corsair K70 RGB TKL Champion
Software Windows 11 64 bit, Free Avira Security
Arctic freezer 36 is cheaper cools more than okay + it has an intel Retention bracket
1,631 (0.74/day)
London, UK
Software ❶ Win 11 ❷ 10 ❸ 10
Absolutely! Arctic had a great sale not long ago (or is it still on-going) - I grabbed a Freezer 36 for just £14 and a couple of Arctic III AIOs for a steal. Another single tower solid option is the Thermalright Burst Assassin with 6 heat pipes for around £20. That said, dual-tower coolers like the ID A620 Pro and Thermalright PA/PS offer better thermal headroom for those who need/desire it. For my main rigs, all currently running AIOs, I’d opt for a dual-tower air cooler if I switched back. The added thermal headroom allows for greater flexibility with fan curves to achieve whisper quiet adjustments
