Ideas for SSD Power Consumption Testing
4,004 (0.60/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
Interesting thread.
just curious on the background for this? More for laptops and battery conservation?
I would suggest power consumption when watching a movie that’s on the drive.
Other than that I would suggest max power usage as in what causes max power usage and how many watts is it……and when would a heat sink and or forced cooling be recommended at X amount of watts.
cheers
349 (0.35/day)
System Name HP EliteBook 725 G3
Processor AMD PRO A10-8700B (1.8 GHz CMT dual module with 3.2 GHz boost)
Motherboard HP proprietary
Cooling pretty good
Memory 8 GB SK Hynix DDR3 SODIMM
Video Card(s) Radeon R6 (Carrizo/GCNv3)
Storage internal Kioxia XG6 1 TB NVMe SSD (aftermarket)
Display(s) HP P22h G4 21.5" 1080p (& 768p internal LCD)
Case HP proprietary metal case
Audio Device(s) built-in Conexant CX20724 HDA chipset -> Roland RH-200S
Power Supply HP-branded AC adapter
Mouse Steelseries Rival 310
Keyboard Cherry G84-5200
Software Alma Linux 9.1
Benchmark Scores Broadcom BCM94356 11ac M.2 WiFi card (aftermarket)
Active idle consumption (ASPM disabled) please. Some NVMe SSDs use considerably more idle than even (still spinning) idle 2.5" laptop HDDs if ASPM/L1.2 is not working. And NVMe power management can be an issue, especially on Linux, I think, so it is nice if the worst case scenario is taken into account. With SATA SSDs slumber/DevSlp not working is much less of a problem due to active idle draw being a lot less.
W1zzard
Administrator
28,345 (3.73/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Yeah I’ll have „idle desktop“ which is aspm off, because that is the default setting in all (most?) bioses, and „idle mobile“ with it enabled
3,876 (1.74/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Indeed, my DC P4600 uses more at idle than the spindle I took out when I put in (was only a wd green though). So idle measurements would be greatly appreciated.
3,911 (2.57/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
This would probably take too much of your time to include in your regular SSD test set but maybe you can do it with some SSDs:
On a drive that's (mostly) full, delete all files at once. Observe what's going on with the power consumption afterwards. Deleting should trigger the erasing of data blocks on the SSD, an operation that potentially takes a lot of time and consumes a lot of power, even if the controller is idle or nearly idle.
Mussels
Freshwater Moderator
58,412 (7.83/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
That's not how SSD's work, they get marked as free space but don't get erased, specifically to avoid wear and tear as you described it
All that would do is mark the files as safe to be deleted, and have the files marked as junk - ready to be erased as the space is needed
TRIM and active garbage collection would work the way you described if a small amount of data was written to every cell, filling none of them
3,911 (2.57/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
If a SSD is, like, 90% full then most blocks are mostly or completely full. What happens if you delete all files? The OS sends trim commands for all sectors, save some filesystem metadata. The SSD processes them, determines that most blocks now contain zero user data and marks them as "to be erased". That should happen immediately, unless the controller is unable to process a giant amount of trim commands in real time.
The rest is up to the garbage collection. I'd expect GC to begin its job shortly after that (seconds? minutes?) if the drive is idle, making it ready for further writing. Erasing while writing is avoided if possible because it drags down the performance by a lot.
bug
14,157 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
It would be nice if you could measure the energy needed to finish each of the real-world benchmarks.
Mussels
58,412 (7.83/day)
Oystralia
They'd get marked as empty and nothing would be done.
What you're talking about only happens as the equivalent to defragmenting, allowing files to be compacted into less flash modules
You'd need to delete 90% of the files, somehow spreading the deleted files perfectly between all the modules
A complete erase, a quick format - just treats them all as empty and writes nothing
342 (0.15/day)
Hungary
Processor i5-9600K
Motherboard ASUS Prime Z390-A
Cooling Cooler Master Hyper 212 Black Edition PWM
Memory G.Skill DDR4 RipjawsV 3200MHz 16GB kit
Video Card(s) Asus RTX2060 ROG STRIX GAMING
Display(s) Samsung Odyssey G7 27"
Case Cooler Master MasterCase H500
Power Supply SUPER FLOWER Leadex Gold 650W
Mouse BenQ Zowie FK1+-B
Keyboard Cherry KC 1000
Software Win 10
Just received my Quarch for SSD power consumption measurements (https://quarch.com/products/hd-programmable-power-module/)
Any ideas, requests, suggestions what power-related tests I should add to my SSD reviews? Gimme a wish list, let me know what you'd love to see, don't worry if it can be done
Idle consumption and... prolonged mp3 playback? I always wanted to know how much power I'm using with my daily dose of 10-14 hours of mp3 playback:)
W1zzard
Administrator
28,345 (3.73/day)
Memory 48 GB
Less than 100 mb per hour for mp3, not sure if this will even be 1% over idle per hour
Chris_Ramseyer
Phison Rep
481 (0.08/day)
For the most part, the only time people truly care about power consumption from an SSD is in a notebook environment. When I was a reviewer I worked out a deal with Lenovo to get four identical notebooks (Y700-17) with average battery life (for the time). That way I could test MobileMark on up to 4 systems at a time. That took care of when I had every capacity size available and didn't slow my reviews too much. You will want to get a battery sponsor because the batteries would loose too much capacity after 10 or so runs where it drains all the way down.
In my experience with the Quarch, 4-corner and idle power consumption wins don't always equal the best notebook battery life. Garbage collection, when it happens, and how long it takes plays a massive role. Some companies will use a GC method where the drive will run cleanup right after data writes and others will handle the cleanup later and let the queue build up before cleaning the flash.
Mussels
58,412 (7.83/day)
Oystralia
As one method to test power draw, use a USB NVME enclosure and a device that lets you measure the USB power draw
You'd get figures fast and accurately, assuming theres no key NVME power saving features that get disabled on USB
I've got this cheap USB 3.1 Gen 2 enclosure (10Gb/s)
And a quick search on amazon brought up pass-through measurment devices that aren't meant to impact speeds
Would allow external testing and possibly multiple at once, speeding things up?
The only flaw would be that at least with this model enclosure many NVME drives cant hit their maximum speeds - so you cant do true load testing for max power draw, but idle and constant loads are certainly doable
W1zzard
Administrator
28,345 (3.73/day)
Memory 48 GB
190 (0.03/day)
Peterborough, UK
System Name IONE
Processor AMD Ryzen 9 5900X
Motherboard ASUS STRIX B550-A Gaming
Cooling Noctua NH-U12S SE-AM4
Memory 128GB (4x32GB) Corsair DDR4 Vengeance LPX Black, PC4-25600 (3200), CMK128GX4M4E3200C16
Video Card(s) PNY GeForce RTX 3080 12GB
Storage Samsung 980 1TB NVMe (system), Lexar NM790 4TB NVMe (temp), 16x Seagate IronWolf 10TB RAID6
Display(s) Dell UP3017
Case Lian-Li PC-777B
Audio Device(s) Focal Alpha 65 Evo
Power Supply Corsair AX1200
Mouse Logitech M510
Keyboard Keychron Q10, brass plate, Kailh Box Summer switches and PBT Cherry keycaps
Software Xubuntu 24.04
Benchmark Scores N/A
Total energy to get a bencmark/copy job completed. A faster drive I would expect to use more power but for a shorter duration than a slower drive.
I don't know if it is possible to set the read speed artificially, if so it would be interesting to see how power is or isn't linked to read and write speed. Say how much power is needed to sustain 100MB/s read for example?
3,911 (2.57/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
Copy data over gigabit ethernet, done.
But the OS, or any app, may read the data from SSD in many short bursts or few long bursts. That may affect the average consumption greatly, and the user has no control over that.
Mussels
58,412 (7.83/day)
Oystralia
/doubt ;)
that's the problem
I have the Quarch ready to go, tests figured out, just need to find time to retest 30 drives
3am "cant sleep" thoughts are not always good ideas
qubit
Overclocked quantum bit
17,865 (2.84/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
You could do occasional long term tests on what it takes to kill an SSD, like Anandtech did a few years ago. I think it was them, anyway.
1,249 (0.20/day)
Hampton Roads
Processor Xeon x5650
Motherboard SABERTOOTH X58
Cooling Fans
Memory 24 GB Kingston HyperX 1600
Video Card(s) GTX 1060 3GB
Storage small ssd
Display(s) Dell 2001F, BenQ short throw
Case Lian Li
Power Supply X750
Software Mint 19.3, Win 10
Benchmark Scores not so fast...
/doubt ;)
that's the problem
Too bad I did not see this earlier....
Efficiency, as in, heat to watts comparison. Does the temp rise linearly with power consumption.
3,471 (1.70/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Just throwing out some ideas.
Power consumption vs. Temperature of the drive
Power consumption vs. When SLC cache has been exhausted
Power consumption vs. Multiple I/O operations happening at the same time
