I'm trying to help someone out by saying Corsair ram doesn't play nice with Ryzen
1,784 (1.00/day)
Over the Hill UK
System Name AMDWeapon
Case Montech 903 MAX AIR
VR HMD -
Software Windows 11 Pro 24H2
Trying to help someone on LTT forums and some guy is asking for proof that what I'm saying is true. Help me out people!
3,127 (2.35/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
I'm typing this on a machine powered by a Ryzen 5 3700X CPU with Corsair Vengeance DDR4 RAM (my daily driver, not the gaming system in my System Specs).
Seems to be fine.
1,784 (1.00/day)
Over the Hill UK
VR HMD -
My system is Ryzen with corsair at 3800mt. What I'm saying is I've seen people state that corsair ram isn't always good with Ryzen on this forum. Or is it just Corsair lpx?
9,340 (5.13/day)
Louisiana
Keyboard G710+x3
You're more likely to have issues mixing memory with corsair than other brands
Example you buy one kit 2x8/ 2x16gb/.. and later you buy another kit same as the existing one same frequency and timings/ cas latency/ 3200c16 but they don't work together they bsod or no post at all :eek:
Corsair changes parts way to much for the cheapest they can find sort of bait and switch like a lot of manufactures have been doing like adata/..
So when you get different parts on seemingly same products they are more likely to fail to work together on corsair
Only way to know what you got with corsair is a VER# on the side of each stick of memory
If the VER# doesn't match you're not going to be very happy trying to use them on a single system.
Always buy a quad kit if you want best results and if you have to use two kits for 4x16gb/... do it at the same time not later.
You're more likely to get two kits with the same VER#
freeagent
9,717 (4.15/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Not really any problems to speak of if you follow the QVL lists of MBs.
Many people think the QVL is a joke, and don’t pay any attention to it because maybe they know better? With my rig I checked the QVL at G.Skill and Asus.. I really have not had any problems. I have had frustration boxes before and this one is a walk in the park..
1,784 (1.00/day)
Over the Hill UK
VR HMD -
Thank you Mr @ThrashZone for clarifying that for me.
9,340 (5.13/day)
Louisiana
Keyboard G710+x3
No problem
I'm using some corsair dominator 2666c15 4x4gb atm just for kicks really on my x99 system
Had a lot of issues with them to from years ago
3 rma replacements later issues still happened one stick always fell off the map lol
Turns out it work okay if I don't use sata port 1 & 2 at the same time only 1 or only 2 with 3-8 can be used together :kookoo:
Interesting thing is if I use trident-z 3200c14 4x8gb kit no issue at all but b-die rules :cool:
So corsair can be a real pita easiest is to pass on them and go g-skill.
But on x99 3200c16 4x8gb kit wont even post
So not all g-skill is great as it's really b-die that is great !
11,880 (2.18/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
For generation one of RYZEN, Corsair Lpx memory was not compatible and difficult but not impossible to setup, they wouldn't automatically set up and work with Xmp profiles for example but Corsair released AMD specific versions later that were fine, this wasn't just Lpx but Lpx got called out more than most since it's cheap and people bought it.
No worries now just get RYZEN compatible rated versions though mostly it's not a issue.
9,340 (5.13/day)
Louisiana
Keyboard G710+x3
Indeed another perk for b-die is it works on amd or intel systems so insist on it over branding
B-Die Finder
1,784 (1.00/day)
Over the Hill UK
VR HMD -
I was unaware that there was Ryzen specific ram when I built my system, I just got 32gb and plugged it in and wahey, it worked!
How do I find out what chips are on my ram?
Didn't see the B Die finder, durrr.
9,340 (5.13/day)
Louisiana
Keyboard G710+x3
7,671 (1.77/day)
I have two sets of single RAM sticks, 4x 16GB 3200MHz working fine on a zen+ chip while 4x 32GB (same speed but higher latency) sticks doing good with zen3 so I say it's fine!
1,784 (1.00/day)
Over the Hill UK
VR HMD -
Is this any good then?
43,547 (6.77/day)
Corsair has been putting Ryzen Badges on their page for certain ram, its a hit and miss, but yes true corsair has become a pita that I generally overlook them like i do kingston
1,784 (1.00/day)
Over the Hill UK
VR HMD -
I have two sets of single RAM sticks, 4x 16GB 3200MHz working fins on a zen+ chip while 4x 32GB (same speed but higher latency) sticks working fine with zen3 so I say it's fine!
When I read something, I take it as the absolute truth. My brain is not B Die... :D
7,671 (1.77/day)
AMD has improved memory compatibility a fair bit with their AGESA updates, this should work just fine but XMP or higher speeds will vary depending on the CPU, memory chips & motherboard. I will add though that mixing & matching memory generally doesn't work that well, I bought all the sticks real cheap from the same brand & roughly all have similar manufacturing dates.
9,340 (5.13/day)
Louisiana
Keyboard G710+x3
Frick
Fishfaced Nincompoop
19,820 (2.86/day)
north
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
Historically QVL's have been maybe not a joke, but almost (for consumer space). Certainly nothing to bother with anyway. I know I haven't, and general RAM incompability problems have not really been a thing at all. Not until first gen Ryzen anyway.
9,340 (5.13/day)
Louisiana
Keyboard G710+x3
Mother board qvl's are a sad joke
Memory manufacture qvl's are well worth looking at :cool:
1,784 (1.00/day)
Over the Hill UK
VR HMD -
I've just seen XMP enhancer! Oooh, can I play?
I'm going to have to look that Memory manufacture one up as I'm getting a different mobo soonish.
11,880 (2.18/day)
Manchester uk
VR HMD Oculus rift
Some patriot viper kits are bdie and run well, they're memory compatibility is solid as are there wares IMHO.
9,340 (5.13/day)
Louisiana
Keyboard G710+x3
Worst about team group or patriot are they don't seems to add temperature sensors to the dimms :/
1,784 (1.00/day)
Over the Hill UK
VR HMD -
I'll be sticking with this corsair as long as I can. I can't do any more spending when I want a monitor, GPU, CPU and cooler, motherboard. If I said ram to the Mrs I'd get castrated.
9,340 (5.13/day)
Louisiana
Keyboard G710+x3
Micron is better than hynix in ddr4 so yeah keep it should be fine on another board.
