Inno3D Readies First ''Non-Reference'' GeForce GTX 470 Graphics Card
idx
98 (0.02/day)
afw
646 (0.11/day)
System Name StealthX
Processor Intel i7 2700k
Motherboard Asus SABERTOOTH z77
Cooling Prolimatech Genesis
Memory CORSAIR Vengeance 8GB DDR3
Video Card(s) ASUS GTX 960 2GB black edition
Storage CORSAIR FORCE GT 120GB SSD + Samsung Spinpoint F3 (1TB + 2 x 500GB)
Display(s) Acer G235H 23" (1920 x 1080)
Case Silverstone Raven RV02
Audio Device(s) OB
Power Supply Seasonic x650 GOLD
afw
646 (0.11/day)
Audio Device(s) OB
at least Fermi runs on 72C° its not that bad , dont you remember the ATI radeon hd4870x2 , it was running on 105 C° and what the ATI said about it is "its normal for gpu to run at this temp" . non of the ati fans comment on this ... loooooooooool some ppl are really sick .
4870x2 is a dual GPU card ... how can you compare it with a single GPU card
:laugh: Anyway I've never seen 4870x2 cards go above 90C on reviews (with a decent casing) ... i know they are loud and the core nearer to the fan has really low temps ..... the other core reaches around 90C ... 105C is just over exaggerating facts ... :nutkick:
I'm no fanboy ... but you are certainly acting like one ... :laugh: ... FERMI doesnt run @ 72C ... the average load temp in all the reviews i've read is about 95C ... lmao ... :laugh:
Just check the temps of 4870x2 here--->
http://www.guru3d.com/article/radeon-hd-4870-x2-review-crossfire/6
http://www.hardwarecanucks.com/foru...deon-hd-4870-x2-2gb-video-card-review-21.html
http://www.techpowerup.com/reviews/Sapphire/HD_4870_X2/27.html
http://www.madshrimps.be/?action=getarticle&number=14&artpage=3665&articID=864
cdawall
where the hell are my stars
27,683 (4.10/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
at least Fermi runs on 72C° its not that bad , dont you remember ATI radeon hd4870x2 , it was running on 105 C° and what ATI said about it is "its normal for gpu to run at this temp" . non of the ati fans comment on this ... loooooooooool some ppl are really sick .
i have a 4870X2 and it runs nowhere that hot overclocked on the stock cooler? thanks for your input though NV FTW woot
STEvil
21 (0.00/day)
I made quite a few posts on the issue on XS. Also found out that some tools such as AMD GPU Clock Tool were causing the fan profiles to set the fan to minimum speed after a period of time if the tool was installed at all.
At stock my 4870X2 hits about 80c on the hottest core on a hot day before the fan kicks into high speed... usually near 60-70% of maximum speed after temps stabilize depending on room ambients with the hot GPU temps stabilizing near 65-75c depending on room ambients.
