Intel 11 gen not stable with Long Duration Power Limit set to 125watt
1,981 (0.43/day)
Denmark
Processor Ryzen 5 7600
Motherboard Asrock B650 PG LIgtning
Cooling arctic freezer 36
Memory 2 x Team Group T-Create Expert DDR5-6000 - 32GB - CL30 (64gb)
Video Card(s) ASUS Dual GeForce RTX 4070 EVO
Storage 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives
Display(s) LG 32GP850, IIyama G2470HSU-B1
Case Corsair 5000D airflow tg
Audio Device(s) Yamaha R-N800A Syatem audio signature 5
Power Supply Corsair RM850X White
Mouse Asus Rog Gladius III Wireless Aimpoint
Keyboard Corsair K70 RGB TKL Champion
Software Windows 11 64 bit, Free Avira Security
I have an i5 11400f and a Nzxt N7 Z590 motherboard with latest bios and 32gb 4000mhz cl 18 ram
In this video it is suggested to raise the Base Frequecy Boost from 65 watts to 125 watts for a higher cb r23 score, I also do that even though I don't have Base Frequecy Boost but raise the tdp, Long Duration Power Limit from 65 to 125 watts
What then happens when I stress test is that I get around 3,900 mhz in aida64 with everything activated, instead of stock 65 watts where it runs around 3,100 mhz and in other tests 4,200 mhz with Long Duration Power Limit of 125 watts.
The problem is that something goes down during the aida64 test after max 2 min, which is the cpu (it doesn't freeze, not even bsod) the test stops and the aida64 turns completely red, back to 65 watts then the test is100% stable but for a lower score than It ca can be in cb r23, which I have just under 10000 in multicore (higher in the video) as it does not boost all the way up to 4,200mhz as the bus speed is not quite 100.
How can I get it to run completely stable with tdp, Long Duration Power Limit of 125 watts?
142 (0.18/day)
Processor AMD Ryzen 2700X
Motherboard MSI X470 Gaming Pro Carbon
Cooling NH-D15 SE-AM4
Memory 4x Kingston 8GB DDR4-2666
Video Card(s) 2x EVGA GTX 960
Storage Kingston SA400 480GB, LSI 9260-8I RAID[2x WD4005 4TB, 3x Kingston SA400 480GB]
Display(s) Scepter P30, Samsung T22B350
Case Phanteks Enthoo Pro
Power Supply Seasonic Prime Titanium 650w
Mouse Logitech MX Master 3
Keyboard Corsair K60 RGB Pro RGP01110
If your goal is strictly 125 watts, better luck at the silicon lottery. Otherwise lower your expectations.
1,981 (0.43/day)
Denmark
I do have more stable cpu now and getting close to 10000 in cb r23
1,457 (0.34/day)
Australia
OP, I don't know about OC non K rocket lake chips, only have experience with K version. But I suggest you get very familiar with the depths of your bios because from the video you linked too, that guy is using an Asrock board & according to your signature, your not. You'll just have to find out if the NZXT board your using has the same cpu options as that Asrock board shown in the bios, keep in mind thought that mobo vendors don't all agree on the same terminology for menu items in bios. So you'll have to navigate around in the NZXT board's bios to find out what they are called - if in fact that board has the same cpu bios options as the NZXT board your using.
142 (0.18/day)
I took a look through the digital manual for this motherboard and literally the only mention of the BIOS is in regards to the Clear CMOS button, so good luck!
1,981 (0.43/day)
Denmark
A N7 Z590 mb as i have, is made by Asrock, retail price back in the day is 280 dollars, i got it for $147 or €134, i think it's a good deal, all it doesn't have is biso flash, but it has a clear cmos on the i/o panel, 10 usb port on the i/o panel,power resett button,wifi 6e and bt + 7 fan headers with easy adjustments with nzxt cam (very easy to use)
1,981 (0.43/day)
Denmark
Tested my cpu and it's got fpu and cache failour in aida64
Passed intel Diagnostic Tool
How can i fix it ?
  • 2023-05-13 11_23_27-Intel® Processor Diagnostic Tool 64Bit 4.1.7.39.W.MP.png
89 (0.05/day)
tried some undervolt and maybe lower to a more reasonable 80w limit? you should get same performance as 125w at lower power/temp
18,584 (2.67/day)
System Name AlderLake
Buy a Intel K CPU if you want to mess with power limits and more.
1,981 (0.43/day)
Denmark
No it just don't boost as high as it can if tdp, watt limit is to low
No thanks there almost no power difference between an i5 k cpu and my 11400f, i can play mess around with power limit on a 11400f
11400kf is a 65 watt cpiu a 11600k (f) is a 125 wat cpu
18,584 (2.67/day)
And it's overclockable , unlocked multipliers, and you can configure to run max boost speed on all cores, holds better resale value, imo just the better option.;)
1,981 (0.43/day)
Denmark
it's a hot chip, i won't be able to cool it if it has to run 4.9ghz on all cores
142 (0.18/day)
Wait, so you want to boost your current CPU to 125 watts long duration, but you cannot cool a 125 watt CPU. Are you sereals?
23,122 (6.10/day)
It does not have the same options, NZXT afaik is ECS and they've got some pretty peculiar BIOS stuff going on.
I believe W1zz reviewed one, I know for a fact there are some good insights to be found in reviews on NZXT boards. They cán OC, but its... wonky as fk
1,981 (0.43/day)
Denmark
There can be a diffrence btween what a 125 watt cpu uses and what a cpu of 125 watt you set it to uses of power
PL1 power limit is set to 150 watt, get power limit using stock setting, using fpu,cache, gpu,hardive(s),memory and cpu my temps go crazy in aidia64, no fpu,cache temps are normal
18,584 (2.67/day)
Just leave it all at 65 Watts then, especially if you can't cool your CPU properly...
As I said, if you want more from your CPU, just buy a K CPU and a better cooler then...
1,981 (0.43/day)
Denmark
it won't boost to 4.2 ghz if i leave it stock, i get PL if i leave it stock
i have already oc'ed my cpu
7,456 (4.97/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
I don't understand your obsession with "125 W" and extracting every last bit of your CPU. You bought a low-cost CPU and you're not even taking a low-cost experience home, so what's the deal? Your CPU isn't overclocked, that's just the all-core boost target frequency - and isn't that enough? Like others said: if you want more, you have to buy an unlocked processor. You're never going to have this 11400F running at 4.9 GHz because you don't have enough multiplier leeway to do so. Forget about it.
ps. your AIDA64 version is ancient, update it
1,981 (0.43/day)
Denmark
what do most people do with a k cpu ?
They oc it to get most out it
What do i do ?
I oc to get most out of it
it's up to 20% more in multicore https://www.techpowerup.com/review/intel-core-i5-11400f/22.html
(i don't have my cpu at 125 watt and i do also enable xmp to get more power over stock speed which in my case is 2133 or 2666mhz)
7,456 (4.97/day)
São Paulo, Brazil
What do i do ?
You don't do it because you can't, this processor is not overclockable, all you're doing is running around changing settings and getting placebo. If anything, its automatic settings are going to beat anything that you could possibly do by forcing manual clocks across all cores. Again, because you think raising wattage would suddenly make it a faster CPU? That's not how it works, it's quite the opposite, especially on a locked non-K CPU. Lowest the wattage and heat, the more headroom it will have to perform better. You're heading in the wrong direction and wondering why you can't extract more out of it, truly a head scratcher that one.
18,584 (2.67/day)
1,981 (0.43/day)
Denmark
stock it won't boost as high as it can because of the power limit
Stock it doesn't get to 4.0 ghz on all threads,max is 8 or 9 threads, optimized it goes to 4.2 ghz on all 12 threads when it needs to,because it's not limit by the power limit
18,584 (2.67/day)
Edit: It will, but because it's just in a blink and one core, so you might not notice it.
Otherwise the CPU is thermal throttling and you need a better cooler.
5,263 (0.87/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [MSI MAG B550 TOMAHAWK]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Crucial Pro 3200MHz (32GBx2)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Fanmusic TRUTHEAR IEM, HyperX Duocast]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
This thread is a great example of someone who knows just enough about overclocking to think they know what they're doing.
