- Dec 25, 2020
- 7,458 (4.97/day)
- São Paulo, Brazil
System Name | "Icy Resurrection" |
Processor | 13th Gen Intel Core i9-13900KS |
Motherboard | ASUS ROG Maximus Z790 Apex Encore |
Cooling | Noctua NH-D15S upgraded with 2x NF-F12 iPPC-3000 fans and Honeywell PTM7950 TIM |
Memory | 32 GB G.SKILL Trident Z5 RGB F5-6800J3445G16GX2-TZ5RK @ 7600 MT/s 36-44-44-52-96 1.4V |
Video Card(s) | NVIDIA RTX A2000 |
Storage | 500 GB WD Black SN750 SE NVMe SSD + 4 TB WD Red Plus WD40EFPX HDD |
Display(s) | 55-inch LG G3 OLED |
Case | Pichau Mancer CV500 White Edition |
Power Supply | EVGA 1300 G2 1.3kW 80+ Gold |
Mouse | Microsoft Classic IntelliMouse (2017) |
Keyboard | IBM Model M type 1391405 |
Software | Windows 10 Pro 22H2 |
Benchmark Scores | I pulled a Qiqi~ |
stock it won't boost as high as it can because of the power limit
Unlocking the power limit is going to reduce your processor's operating frequency because cooling is inadequate. And read W1zzard's review that you linked: he says everything.
1. Processor is not overclockable
2. BCLK limit is 102.9 MHz and this comes with a slew of problems of its own (frankly not worth it)
3. Power limit can be raised but it will not exceed turbo defined values, and cooling requirements will increase
We've told you this, if you insist, then there is no point in continuing this conversation any further. If you want more performance, you will have to purchase a i7-11700K or i9-11900K processor. Otherwise, just enjoy what you have, man. No point being obsessed over it, it's a locked Core i5 and it does its job the way it has to.
Mind you, the power limit mechanics apply even to unlocked CPUs, I own a i9-13900KS personally, and even this CPU (if not particularly so, because it's the absolute fastest and most aggressive clocking of all Intel CPUs) is subject to it, if I raise its power limit beyond what my cooling can handle, it will throttle and average clocks will be reduced to a point where I am actually losing performance. With my 360mm AIO liquid cooling, the sweet spot that prevents thermal throttling turns out to be precisely the 288W/no time limit setting that my motherboard offers.
