intel 1700 with high speed ram,memory
1,990 (0.43/day)
Denmark
Processor Ryzen 5 7600
Motherboard Asrock z690 pg riptide
Cooling arctic freezer 36
Memory 32 gb g skill ageis 3200mhz cl 16
Video Card(s) ASUS Dual GeForce RTX 4070 EVO
Storage 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives
Display(s) LG 32GP850, IIyama G2470HSU-B1
Case Corsair 5000D airflow tg
Audio Device(s) Yamaha R-N800A System audio signature 5
Power Supply Corsair RM850X White
Mouse Asus Rog Gladius III Wireless Aimpoint
Keyboard Corsair K70 RGB TKL Champion
Software Windows 11 64 bit, Free Avira Security
Mabye im a little borred but i wanna do a little experience or just try it
intel cpu 12400f,13100f,13400f,14100f,14400f +mb + high speed ram, something around 7000 mhz cl 34, something fast
On a low budget mb, what is the best option for making it work, i wanna try it, use it everyday
I have pleanty i can sell so it won't cost me anything.
I have heard 14 gen should be good at running with high speed ram
You could say i wanna try fast ram because some say lows in games will be higher but also to eliminate slow ram as bottleneck
163 (0.17/day)
At what resolution are you playing?
Which GPU are you going to use?
The answers will determine where the natural bottleneck will be.
1,990 (0.43/day)
Denmark
1,922 (4.14/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) 1080P 144hz
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
None of those will run "high speed". 6400mt/s at best.
Locked system agent is the issue.
12400F is the only cpu from your list that will BCLK overclock also. And would need an appropriate board to do so.
1,990 (0.43/day)
Denmark
im not gonna oc the cpu it's the ram
1,990 (0.43/day)
Denmark
I bought something but i bought the wrong mb ddr 4 support :banghead:(ASRock Z690 PG Riptide) not from the cheapest place since i wanted to buy it today, just forgot to look if that mb had support for ddr 4 or ddr 5
pci e scalling is not that big from 5.0 to 4.0 x16 but it supports 5.0 x16 for a gpu (atm i don't need more than i have) and bios flashback
cpu i wanna try a 14 gen and a fairly cheap cpu to experience how it would be having a 4/8 cpu with fast ram, there is very few 12,13 and 14 gen cpus for sale (have tried a 12100f, i expect a 14100f have improvement over a 12100f not just higher mhz)
Seen video where ddr 5 is alot better than ddr 4 with a 12-14 gen intel so i don't think i would go that extreme an use ddr 4 again
1,990 (0.43/day)
Denmark
ir_cow
4,776 (0.79/day)
USA
Check out any of the memory reviews. I included the highest frequency DDR4 and arguably top tier DDR4 3600.
With a 4090 it does sit at the bottom of the charts, but remember it is a 4090. Increase the resolution and generally speaking, the GPU is the main bottleneck now.
1,990 (0.43/day)
Denmark
I don't know full hd and 4k and a 13900k, 3600mhz cl 14 is kind of pricey
1,436 (0.31/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Audio Device(s) Logitech Z906 5.1
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
i have cl36 memory that runs a 7000mhz only paid 115$ for 2x16gb kit.
1,990 (0.43/day)
Denmark
im thinking of ddr 4 since returning my ddr 4 motherboard takes a day and than another day for a new mb
I think it's okay to find fast 32g ddr 5 ram, ddr 4 is only 36000mhz cl 16 and the g skill ripjaws v 4000mhz cl 18 for 70-75 euros
G.Skill Ripjaws V Black DDR4 4400MHz CL 19 2x16GB is 90 euros
1,922 (4.14/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
None of those processors will go 4400 ddr4. That's way over purchase.
I would swap the board for a ddr5 and go that route. Keep the 12400F and you will see the performance gains fairly easily. Then you aim for 6000mt/s (3000mhz) with decent timings.
And if your Z series board OCs BCLK, all the better. I found the 12400F capable of 4.6ghz sustain just on the stock cooler. So totally worth it.
1,990 (0.43/day)
Denmark
Never metioned i bought a 12400f
a 14100, i wanted to have the slightly lower price and generation gain + low temps
12400f might be faster but also a little more expensive + z mb, my original plan was a z mb that support ddr 5 and they are expensive, from close to 200 euros and up (there isn't many used 12-14 gen cpus so to get a good or juster fast cpu requires me to wait for one to show up)
It does perform good against a 12400f and a i7 9700k/10700k
0.1% lows are here really good for the little i3
2025-02-20 02_23_45-i7 9700K vs i3 14100F - which is Better for Gaming_ - YouTube – Google Chr...png
1,922 (4.14/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
Well, you pay for the OC ability of 12th gen. Ddr4 or 5, doesn't matter. I maxed my 12400F at around 5.6ghz and it was pretty stable at 5ghz on a water loop.
But here is GeekBench 5 to example. They are about 100mhz difference clock speeds. If the 14100F had 2 more cores, the multi-core score would be close as well.
I have other screen shots to compare with cpu benchmarks. Concerning CPU, not GPU. You look like the search is on for a bottle neck. They are too similar to find it easily.
1,990 (0.43/day)
Denmark
I can always save the part i have bought and make a small pc out of it and go back to my current setup
would be fun spending a couple of days searching for a part to add to a pc or just wait for used k cpu, im surprised there ain't more used
12600k(f),13600k(f),14600k(f)13400f,14400f i would look for
F4-4400C18D-32GVK is in the qvl list i think it's cl 19 or 4000mhz cl 18
what memory would you recommend, 4400,4600mhz isn't to expensive and i think both can run at 4000mhz cl 18 if they can't run at native speed 4400 or 4600mhz
As I have written 12,13 and 14 gen used cpus are not that easy to find, im hoping for a 12700k for under 200 euros or a 12900k for 200 euros, a new 12900kf is just a little under 335 euros and was released in 2021
