Intel 45nm Yorkfield Does 4653MHz on Air
11,119 (1.62/day)
System Name Apple Bite
Processor Intel I5
Motherboard Apple
Memory 40gb of DDR 4 2700
Video Card(s) ATI Radeon 500
Storage Fusion Drive 1 TB
Display(s) 27 Inch IMac late 2017
And I said as much above, point is that they wont match Intels 45nm Quads and duellies (supposidly nowhere near? not sure there) but if you are saying you cannot compare the 2 because they are not like for like, well your right but they are the 2 most upto date chips from each provider, it's not Intels fault that AMD are a year behind them, by the time our beloved AMD get 45nm on the consumers shelves Intel with prob have like 10nm :eek: either that or I will be too old to see the keyboard never mind type on it :D
Na
kwchang007
3,962 (0.60/day)
Severn, MD, USA.
Processor C2D T7200@2 ghz vcore: .9875
Motherboard generic laptop board
Cooling fan control and antec notebook cooler
Memory 2 GBs@ 533 mhz ddr2
Video Card(s) x1400 mobile, overclocked: 526mhz core/ 882mhz ddr
Storage 120 GB@ 5400 rpm fujitsu
Display(s) 15.4" 1440x900
Audio Device(s) integrated
Software vista 32 bit home premium
Well it'll depend on overclocks really. Penryn will defiantly beat the first round of K10s that come out if they decide to clock them up to around ~3.2-3.4. That's if K10 can ramp up to 3ghz. If AMD gets 3.5 out of a K10....then we'll have to see Penryn's climb up to ~3.7-3.9. So in essence, yeah Intel can win, but if AMD can pump out those clock rates, we're going to see the thermal ratings and power requirements of a stock CPU from Intel go up (at least on the high end).
However, I don't believe AMD will get those kind of speeds out of their chips on 65 nm.....monolithic quad cores actually have a tougher time getting higher clock rates than multi-die on single package because on the multi-die you can pick to good dual cores, whereas on the monolithic quad cores....your stuck with quad cores to pick from.
pt
not a suicide-bomber
8,956 (1.29/day)
Portugal
Processor AMD Turion 64 X2 Mobile TL-60 (Trinidad)
Motherboard ASUS F3Ka (ATI RS690M)
Cooling stock
Memory Nanya 2x1GB ddr2 667@5-5-5-15-2T
Video Card(s) ATI Mobility Radeon HD2600 512MB DDR2@ 580mhz/486mhz
Storage 160GB on laptop+250GB external
Display(s) ASUS 15.4
Case Asus Laptop F3Ka chassis
Audio Device(s) on-board
Power Supply 1:30minutes battery
Software "genui xp", 'cause i hated vista
Fan boy for AMD, starting to lean towards *Intel
same here :(
still i'm a total amd fanatic when it comes to gfx card
Deleted member 24505
I dont think power ratings matter if you oc,the power rating of cpu's is rated at its stock speed.Who gives a tosh what power their oc'd chip is using.If you was that bothered you would'nt oc.
723 (0.10/day)
Scotland
Processor AMD 5800X3D
Cooling Fractal Design Celsius S24
Memory 2x16gb Crucial e-die 3000MHZ
Video Card(s) MSI 3070 Trio
Display(s) Lenovo G27Q-20
Case Phantec P400
Audio Device(s) GSP370
Power Supply EVGA G3 750W
Mouse Corsair Harpoon Pro
VR HMD Rift
Agrees, when you OC you not only punch up the power usage of the cpu but the ram and motherboard too!
And I don't know why poeple bang on about which are the best overclockers, I worry which is the most consistent overclockers. No point if 1 person out of a 1000 breaks the 3ghz barrier on an AMD if none of his mates can, I prefer a cpu were my mates can trust my advice. :)
Tatty_Two
Gone Fishing
25,969 (3.72/day)
Worcestershire, UK
Software Win 11 Home x64
Agreed, but history suggests...the lower the fabrication process, couple with the lower stock VCore requirments (mhz for Mhz) that they will overclock considerably better than chips of a higher process requiring more power.
Mussels
Freshwater Moderator
58,412 (7.85/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
You certainly cannot compare current amd overclocking and bet the new chips will overclock like they do!!!! They are just the first batch and will overclock much better as they evolve flounder boy!!!!!!! They were ment to compete with the current intel chips newer ones are on they way.
really? usually the first batches OC much better, venice anyone?
And no, AMD arent competing with intel for speed. they're going the power efficient/cheap route now, since they know they cant compete in speed for a while.
Why is that are you a fan boy. I know I am and thats not what I read. I read the AMD chips match the Intel chips very well. Even as a fanboy I can see thru all my own crap to get to the truth. Fab boy for AMD, starting to lean towards *Intel
clock for clock, they match intel. But they cant OC for crap, so the odds on legit chips going very high is low. if intel can do 4.5Ghz on air with a york, how can AMD beat it when they cant reach 3.5GHz with hand picked chips on water?
43,620 (6.42/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Clock for clock, Barcelona is better in server apps, normal people stuff (ex gaming) has yet to be seen, but anandtech thinks Intel is going to remain in the lead there. But remember that Nehlam is coming in a year with CSI (or w/e it is now) and integrated memory controller...this is just trying to get Core 2 a little faster.
Yeah, Intel's first try at a memory controller (on die). Btw, Phenoms have dual 64-bit memory controllers. AMD Proc + AMD Mobo + Crossfire X = FTW!!!
EvilMerlin
2 (0.00/day)
Processor Intel Q6700
Motherboard Intel BOXD975XBX2KR
Cooling Intel Standard fan
Memory 4GB Corsair XMS2 (PC2 6400)
Video Card(s) EVGA 640-P2-N827-AR GeForce 8800GTS 640MB
Storage 2x Seagate Barracuda ST3750640AS (750GB)
Display(s) Dell Ultrasharp 2007WFP
Case LanLi busted ol' case
Power Supply Rosewill RX750
Software Windows Vista Ultimate x64
Sharikou?
EvilMerlin
2 (0.00/day)
Clock for clock doesn't really matter. Intel has the ability to clock nearly as high as it wants to currently. AMD doesn't. Until AMD is able to clock as fast as Intel, its a one pony show.
kwchang007
3,962 (0.60/day)
Severn, MD, USA.
Exactly. :toast:
Wile E
Power User
24,318 (3.62/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
What about Windsors? 1st run OCed worth a crap, rarely getting to 3GHz. The later revisions have been to 3 and beyond on a much more steady basis. We even have ones that stock at 3 and above.
11,119 (1.62/day)
Processor Intel I5
Motherboard Apple
Max bench clock.
Well I was gonna wait but the current chip are very good and cheap so I got a Q6600 after all and here is my result to compare to a yorkfield. It is still a very good chip.
2,996 (0.45/day)
System Name COLOSSUS-MK4
Processor E8400 @4.4 GHz - FSB @550 MHZ
Motherboard Asus P5K Premium (Black Pearl)
Cooling Xigmatek HDT-S1283
Memory 2x1GB Geil BlckDrgn 800 @1158 5-5-5-18
Video Card(s) 8800GT 512MB @740/1782/2080
Storage Hitachi T7K250 250GB & 7200.10 Seagate 250GB
Display(s) Gateway FPD1975W 19" Widescreen
Case Antec 1200
Audio Device(s) Xi-FI Xtreme Audio
Power Supply CoolerMaster IGreen 500W
Software XP Home SP3
Benchmark Scores SuperPi: 10.563 Sciencemark: 2563.14
Tatty_Two
Gone Fishing
25,969 (3.72/day)
Worcestershire, UK
Because the power rating at stock dictates the power rating when you overclock! The lower the stock, the less it takes to get to 4Gig.....generally. Ohhhh and LMAO@thoseVolts :)
11,119 (1.62/day)
Processor Intel I5
Motherboard Apple
Tatty_Two
Gone Fishing
25,969 (3.72/day)
Worcestershire, UK
Was just seeing it max max and now you have it. It will bench at 4.50ghz at 1.55v FYI
I hope you mean 4.05Gig rather than 4,500Mhz???? :D
