Intel Core i9-12900K 36% Faster Than Stock in Maximum Turbo Power Mode
15,478 (6.78/day)
Midlands, UK
Cooling be quiet! Dark Rock 4
Case Kolink Citadel Mesh
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
Yes, you're correct.
AMD run hotter on some chips because they have the higher heat density - 80mm2 vs 200mm2+
I mean... that alone explains a lot, heat wise.
On top of that, they measure temps different. Intel likes to report a more averaged temp, while AMD reports the peak temp - and far more often.
So if both chips measured 60C with a spike to 70C for 5ms, the intel wouldnt report that spike (Zen2 and 3 report every 1ms.... waaaaaaaay more often than intel - i cant find much, but estimates seem to be between 15ms and 30ms)
Yet, forums are loud of people claiming how cool new Ryzens run (even though they don't) while reviews can't get over Intel's power consumption figures, effectively spreading misbelief that Intel CPUs run hot. The internet is a weird place. :kookoo:
In context of the 12900K, just because it eats a lot of power when unlocked, we can't be sure that it'll also run hot - though the new 10 nm process (and increased density) suggest that it might. We'll see.
Mussels
Freshwater Moderator
58,412 (7.79/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
It's because people cant tell the difference between
A. Intel CPU's produce a lot of heat
B. Intel CPU's run hot
Reality is more like:
1. Intel requires big heatsinks/coolers
2. AMD requires heatsinks with good contact/baseplates
15,478 (6.78/day)
Midlands, UK
Even that's not true. ;)
I'm running my i7-11700 with a tiny be quiet! Shadow Rock LP at 75 °C max in Cinebench R23 all-core with a 125 W PL1. The R5 3600 couldn't keep this temperature at stock (88 W) with the same cooler.
In my experience it would be more like:
1. Intel requires tweaking to deliver performance that suits your cooling (unless it's a 65 W part kept at stock),
2. AMD requires good contact with the cooler and good case airflow, or a lowered power target.
1,836 (0.49/day)
System Name Legion
Processor i7-12700KF
Case Montech Air X
Power Supply Corsair CX750M
Mouse Logitech MX Anywhere 25
Keyboard Logitech MX Keys
Software Lots
And 12600K at 115W.
For reference a 5800X gets about 15k multi CB 23 and about 6.1K multi CB 20
i.e. 5800X is slower and will draw more power than the 115W of the 12600K :
Deleted member 215115
As someone who much prefers traditional CPU coolers over AIO's, you have to ask if there is any current tower cooler out there that can cope with a 12900K at full power..The (supposedly) best of the best, the Noctua DH15 has a TDP limit of 250w, so at 241w, its going to be right on the edge of thermal throttling territory, in 100% CPU load productivity work like rendering and encoding, at least Gaming will be no problem, I suppose, as that never pushes any CPU to all core 100% load for anything other than brief periods for stuff like shader compilation.
The D15 can't cool 241W. No way. The 250W rating is a joke. Even some AIOs would struggle with that.
1,836 (0.49/day)
System Name Legion
Case Montech Air X
Software Lots
Oh boy, it's even better than what was shown previously - the insufferable redsters are in for a world of hurt, this is gonna be good! :cool:
Ominous.. :laugh:
"Intel Core i9-12900K and i5-12600K lead ominous Alder Lake assault on UserBenchmark's charts as highest Ryzen chip languishes in 17th position"
15,478 (6.78/day)
Midlands, UK
And 12600K at 115W.
If this is true, and then AMD launches Zen 3+ with 3D cache, there will be some sweet competition happening! :cool: Unless both Intel and AMD jump on the chip shortage bandwagon to artificially inflate prices (I mean, the 12900K appears to be expensive enough already, but still).
Mussels
58,412 (7.79/day)
Oystralia
Your 11700 is a 65W chip, and the most power efficient intel in recent years. It's literally the one example.
Meanwhile, a 3600 or 5600x runs on the wraith stealth
Why does such a tiny ass cooler work so well for them? The mounting screws, higher pressure helps them a lot (and i dont get why the bigger stock coolers dont use them, too)
And 12600K at 115W.
Edited: I see how it shows 115W, but it also shows PL1 and PL2 at 202W
I dont quite trust that it's not running close to either of those
1,836 (0.49/day)
System Name Legion
Case Montech Air X
Software Lots
I don't think he would be able to keep max package 56C during the run if it were over 200W. Just because PL1 and PL2 are set to 202W doesn't mean that it used that, and this is "just" a 12600K with the max frequency limits intact. See next image.
Same guy, 12700K, 158W and 67C. My AIO will keep my 10850K below that temp at 158W. This score smashes the 5900X, and draws less power too.
So there is a pattern developing..
Mussels
58,412 (7.79/day)
Oystralia
I hope its true.
We just have a long history of intel leaks being faked before reviews.
2,235 (0.43/day)
System Name Ultima
Processor AMD Ryzen 7 5800X
Video Card(s) Palit GeForce RTX 4070 12GB Dual
Storage WD Black SN850X 2TB Gen4, Samsung 970 Evo Plus 500GB , 1TB Crucial MX500 SSD sata,
Display(s) ASUS TUF VG249Q3A 24" 1080p 165-180Hz VRR
Case DarkFlash DLM21 Mesh
Power Supply Corsair RM650
Mouse Rog Strix Impact 3 Wireless | Wacom Intuos CTH-480
Keyboard A4Tech B314 Keyboard
15,478 (6.78/day)
Midlands, UK
It's not that. When I had the 3600, the Wraith Stealth didn't work out for me at all. That's why I bought the Shadow Rock LP, which basically kept it at the top of its operational temperature range, but nothing more... at stock! Which means a power limit of 88 W. I'm using the same cooler with the 11700 with the power limit cranked up to 125 W (way above stock), and it keeps it at 75 °C max. That's 37 Watts more than the 3600 ate, and it runs cooler with the same cooling setup. It's the same temperature my R3 3100 runs at with the Wraith Stealth (of course the Shadow Rock LP is better, but still) eating around 50-55 Watts. Heat density is a big factor in how hot a chip runs - even bigger than its power consumption in my experience.
1,836 (0.49/day)
System Name Legion
Case Montech Air X
Software Lots
Gen 10 doesn't need there to be a big temperature difference between the chip and the heat spreader to x-fer a lot of heat. Ryzen does. It's a materials engineering thing, there is a value called a heat transfer coefficient which when multiplied by the temp difference gives you a heat flux value aka thermal power transferred per unit area. The thermal power transfer per unit area on a Gen 10 is better than Gen 9 and any Zen. It's like having a factory delid.
Mussels
58,412 (7.79/day)
Oystralia
Nice, and yea it draws less power than my 5800X
We also have to be aware HWinfo may not fully support the chips yet, or there more be more than one source of power to read.
Is there a second power package for the E cores just off screen, too?
15,478 (6.78/day)
Midlands, UK
If that's the case, then this is something that AMD still has to learn. It's also one more reason not to jump to conclusions on how hot the 12900K is going to run based purely on its peak power consumption.
2,235 (0.43/day)
System Name Ultima
2,022 (1.32/day)
Alaska USA
354 (0.11/day)
Indonesia
System Name Nero Mini
Processor AMD Ryzen 7 5800X 4.7GHz-4.9GHz
Motherboard Gigabyte X570i Aorus Pro Wifi
Cooling Noctua NH-D15S+3x Noctua IPPC 3K
Memory Team Dark 3800MHz CL16 2x16GB 55ns
Video Card(s) Palit RTX 2060 Super JS Shunt Mod 2130MHz/1925MHz + 2x Noctua 120mm IPPC 3K
Storage Adata XPG Gammix S50 1TB
Display(s) LG 27UD68W
Case Lian-Li TU-150
AMD is anything but comfortable at the top... I must say, they have been doing some very respectable IPC gains over the years. From what I see, they aren't asleep at the wheel either.
In terms of innovating? No they definitely are still going hard at it. But in terms of pricing? Yes they are. Look at the 5600X. Its a 6-core still at $300 in 2021.
180 (0.10/day)
Thanks for one of the few really on-point comments here beside all the "but it runs hot" or "but my cooler runs better on intel now then on amd?" comments from people who don't understand heat-dissipation, heat or energy transportation through materials, heat-gaps and bridges or aerodynamics (but saw xyz proven in a vid somewhere or a leak-picture which HAS TO BE true).
I mean I get it. Everyone wants to see comparisons between absolute equal systems - but that'll never happen. Even with the same cooler, the same PSU, the same GPU, the exact same case-fan-speeds and room-temperature you'll not get a 100% comparison. Why? The same cooler performs differently on any cpu. No matter if you're talkin 8th/9th/12th gen Intel or Intel vs AMD. They are designed for a specific purpose for a specific cpu or a "will fit all" scenario not taking into account where/how the heat-areas are and the general requirements to get the heat from zone a/b/c away but a general "just slap it on" mentality.
That's like saying "the big air intake-compressor solutions of the 80s just flatly screwed ontop of the v8's are better than custom injector/turbocharged designes with single-valve configurations because they fit more engines than those stupid ultra-specific designs that work only for one engine and only one generation of that engine even though the next engine has the same dimentions and the valves/cylinders at the same place!!!".
Every cooler manufacturer decides which brand to focus on the most and accepts that with this he'll not have a 100% perfect solution for the other brand - but one that is "working". Also they want to cover as many generations as possible which prevents them from fine-tuning the heat-dissipation to certain areas (especially as the heatspreaders on top of the cpu are also not always 100% even and you'd need to lap those too, to get the best surface contact out of your combination of cooler/CPU --- or, in the best case of course delid and have a direct-contact). But also - no one could pay for a design like that (which takes care of different heat-zones and requirements and specific preasure-fit to certain areas of the die with even a 99% perfect fit).
But we'll always hear "but my cooler (which was designed with gen xyz of intel/amd in mind) works better on this cpu with this TPD than with THIS one with a different layout! This means this generation is better/worse!
The only thing we should take from those comparisons is how well they do with which load and how much energy is needed for it - and, if you want: cooler xyz works well with this generation (or better/worse than with intel/amd in comparison) and you're good if you have that one (but doesn't automatically mean that any cooling solution rated at xyzTDP will be bad for this chip or the chip in general doesn't work with any cooling solution below this TDP or whatever. Just - this one rated for this doesn't do as well with chip X while he did great with chip Y).
15,478 (6.78/day)
Midlands, UK
I can only add a few things:
1. The average user (or even the average PC enthusiast) doesn't care about physics. They just want a CPU that works in their system.
2. The vast majority of people love drawing general conclusions out of their own specific experiences. They don't have the perspective to see further, which is not necessarily a bad thing, just a fact.
3. Speaking of perspective, the average user doesn't have the money (or willingness) to try various different systems just to see how they work, so their only source of information is the online reviews. Unfortunately, journalism in general is trending towards emotional influencing and away from factual presentations. You'll sooner hear a youtuber say "oh Jesus Christ's mother, is this chip hot" or "AMD is super efficient" than discuss how you'd have to set up your power limits with different levels of cooling and airflow. Our average user has no choice but to give credit to these (often false, or at least one-sided) comments about specific use cases that are far from what he/she needs the CPU for to begin with.
I was lucky enough to have tried several different Zen 2 and 3 chips before I settled with my Core i7-11700 as the brain in my main rig for the next few years. The 5950X is a beast and I had no problem cooling it with a 240 mm AIO in a mid tower case. I just wanted to save some money and desktop space by going SFF (once again after the last couple years). In that situation, even a 3600 didn't work - hence the 11700, which I'm absolutely happy with. I also have a 3100 which I'm also happy with in my HTPC - being the coolest and least hungry modern AMD CPU. These are all excellent CPUs, but you need to know what you want to use them for, and in what kind of system with what kind of cooling setup. It also doesn't hurt to know your options in terms of power limit configurations and expected performance. Unfortunately, the media isn't filled with such information (unlike catchy titles and results taken from extreme scenarios).
In general, I don't think it's only the user's fault that they're misinformed. The media plays a huge role. Personally, I think it's awesome to see so such distinct, but very capable architectures from Intel and AMD. :)
818 (0.58/day)
System Name Red Devil
Processor AMD 9950X3D- Granite Ridge - GNR-B0
Motherboard MSI MPG Carbon WIFI (MS-7E49)
Cooling NZXT Kraken Z73 360mm; 14 x Corsair QL 120mm RGB Case Fans
Memory G.SKill Trident Z Neo 5 64GB DDR5-6000 CL26
Video Card(s) Asus Astral 5080 OC Edition 112 ROPs (lol)
Storage 1 x Crucial Gen 5 T705 2GB; 1 x WD Black SN850X 4TB; 1 x Samsung SSD 870EVO 2TB
Display(s) 1 x MSI MPG 321URX QD-OLED 4K; 2 x Asus VG27AQL1A
Case Corsair Obsidian 1000D
Audio Device(s) Raz3r Nommo V2 Pro ; Steel Series Arctis Nova Pro X Wireless (XBox Version)
Power Supply HX1500i Digital ATX - 1500w - 80 Plus Titanium
Mouse Razer Basilisk V3
Keyboard Razer Huntsman V2 - Optical Gaming Keyboard
They will slash prices eventually. MLD brought up a point from a business perspective, that AMD might hold off on slashing prices until after the holidays. Because AMD could be questioning Intel's supply. AMD has the stock in place for the holidays. We shall see who wins this chess game this quarter.
3,918 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Electricity is cheap... intel wants the performance crown
4 months of my electric bill buys a 12900k. We have a electricity crisis in our part of the world right now.
180 (0.10/day)
Totally agree with this - and those two sentences summarize the two biggest issues and why there is so much "revolt" / "emotional distress" in forums (besides the dunning-kruger effect ^^). One of the reasons I really love TPU as wizzard and the team are far away from this behavior and besides doing extremely detailed reviews keep it very neutral and "unbiased" (yes, some "leaked-postings" are the opposite of that, but I'm exclusively talking about the testing and how much work goes into trying to keep it balanced :) )
Electricity and heating go crazy right now in every part of the world, but this is insane ôO .... I mean - you're not joking?
