Interesting Problem 7700x + Aorus X670E PRO X = system freezes/lags RMA?
160 (0.04/day)
System Name 2022 PC / 2020 PC
Processor Ryzen7 7700X / Ryzen7 5800X
Motherboard GIGABYTE X670E AORUS PRO X
Cooling Rog Ryujinn II ARGB / Capellix H100i
Memory F5-6000J3636F16GX2-TZ5NR X2 / Trident z Royal 3200Mhz Cl14
Video Card(s) Zotac AMP Triniti RTX 4090 /EVGA FTW3 ULTRA 3080
Storage Kingston 2TB Fury Renegade / Aorus PCIE4 1TB
Display(s) S95B / S95C
Case anidees AI Crystal PC / Infiniti 2
Power Supply Thermaltake Toughpower GF 3 1000W / TT Toughpower GF1 ARGB 850w
Mouse Razer Basilisk V3
Keyboard Asus Animate ii/ Corsair KG100
Software windows 11 X2
I have an interesting problem! MY Mobo (ROG X670E EXTREME) was destroyed and the shop gave me credit to get a new one. It was 40 days before the release of the X870E and i didn't want to wait so i got the X670E GIGABYTE PRO X!
after I got the machine from the shop with all updates i had an unpleasant surprise! the machine after booting up there was an image like this
View attachment anyone-know-whats-wrong-with-my-monitor-v0-pcy7ktnzp40b1.webp
***THIS IS NOT THE ACTUAL PICTURE BUT CLOSE TO WHAT I GET********
-i reseted the PC and i logged into windows normally
-next day i turned on the PC and while i go the windows LOGIN screen normaly the system appeared frozen. i put the log in credentials and with huge lag i logged into my PC but it was unresponsive. I unplugged the HDMI cable and the problem was solved.
this happens once per day more or less. If the HDMI plug/unplug doesn't work i just reset my PC!
I have tried this with 2 Graphic cards: RTX 4090 and RTX 4080 in HDMI 2.1 4k 144hz and the result is the same!
IS it a MOBO issue? IS it a memory issue?
what's going on?
I do not want to change MOBO again so i thought to ask you here the forum you are amazing people and always with the best suggestions!
489 (0.13/day)
Is this the same PSU from the previous motherbard? How did that one get destroyed?
Frick
Fishfaced Nincompoop
19,597 (2.86/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Yeah how did the previous board die?
Also, can you take a picture of your own crash instead? Does the sound freeze as well?
160 (0.04/day)
Here is a video of the problem! it is not a crash!
video!
It is same PSU! it has been checked for power issues!
The previous one died from a power surge but PSU is ok!
489 (0.13/day)
I would try a different hdmi cable, if that doesn't work you might want to try another PSU. I also would double check the PCIE power connector to the gpu, make sure nothing got hot. I assume you have tried updating drivers etc?
160 (0.04/day)
there is nothing wrong with HDMI cable!
301 (2.81/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
Your previous motherboard died from a power surge? I would be very suspect of the power supply, and in fact, would test each part individually. How do you know the hdmi cable is good? very quick and easy to try a new one.
489 (0.13/day)
Personally I have never heard of a motherboard blowing up because of a power surge unless the PSU failed too. Don't even see how it's possible unless it has no protection features. Trash the psu.
78 (0.21/day)
System Name Home workhorse-gaming
Processor Intel 13600KF @ 5400/4300
Motherboard Asus ROG Strix Z790A Gaming WiFi
Cooling Arctic Freezer 2 rev.7 360mm
Memory 2x16 Kingston Fury Renegade Silver RGB DDR6400@XMP settings - 32-39-39-80
Video Card(s) Palit GamePro 3080Ti with Alphacool Eiswolf 2 360 mm
Storage NVME, WD 550 Blue 1 TB (gen.3), Samsung 980 1 TB (gen.3), Kingston KC3000 2 TB (gen.4)
Display(s) Samsung Odyssey G5 LS27AG500NUXEN (IPS, flat), @120Hz, 10 bit color (165Hz@8 bit)
Case Corsair 5000D Airflow, 4xArctic Bionix P120
Audio Device(s) Creative Sound BlasterX AE5 Plus, Creative P580 boxes, Sennheiser HD569
Power Supply Seasonic Focus GX 850W Gold
Mouse Razer Basilisk V3 Chroma
Keyboard Asus TUF Gaming K3
VR HMD none
Software W11 pro
Benchmark Scores https://hwbot.org/xtu2/analyze/5404795?recalculate=true
I'm willing to bet that there IS something wrong either with the cable or the TV settings (that's not a PC monitor, that's a TV and HDMI is ****). The way it behaves points out to the cable (yeah, yeah, I saw the post yelling that is nothing wrong with it) . Lower the bandwidth in the first place (go Chroma 4:2:2 for example and see what's happening and cut the sound over HDMI). Good luck.
42,346 (6.65/day)
Possible the gpu was damaged too
