Is my HDD about to die ?
140 (0.40/day)
System Name SYSTEM
Processor RYZEN 7 5700X
Motherboard TUF B550M GAMING PLUS
Cooling AG620 CPU COOLER
Memory 16GB RAM DUAL CHANNEL 3200MHZ STOCK
Video Card(s) RTX 4070 GIGABYTE 12GB WINDFORCE
Storage 1TB HDD 256GB SSD
Display(s) LG ULTRAGEAR 144HZ
Case AIGO DARK FLASH
Audio Device(s) MOTHERBOARD AUDIO
Power Supply XPG ADATA PYLON 650W
Mouse REDRAGON COBRA M711 V2
Software WINDOWS 11
Hello
I just took some time to notice and at first i thought it was psu coil whine but checking carefully i´ve noticed that my hdd is making a constant buzzing noise
I´ve checked crystal disk info and hdd sentinel and they both say the HDD is ok
Could it be some mounting issue for it to cause this constant buzzing ? it is not that loud ( have to be very close on it to hear )
But i´m not sure if i could hear this before
Is it possible for hdds to coil whine ? but i´m sure it is like a buzzing sound and i´m sure it is coming from the HDD
Thanks
3,402 (1.64/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
When they say its ok do you mean you checked the raw values or just looked at their main status?
Please post a screenshot of crystal disk info for the drive.
41,536 (6.59/day)
Hello
Thanks
Check to see if Hitachi DFT will run on it, otherwise isolate it out of the case and run it.
3,110 (1.64/day)
Memory Micron DDR4-5600 ECC Unbuffered Memory (2 sticks, 64GB, MTC20C2085S1EC56BD1) + JONSBO NF-1
Power Supply Corsair RM750x
Mouse Logitech M575
Hello
Thanks
Backup data now while you still can.
140 (0.40/day)
System Name SYSTEM
Software WINDOWS 11
Will post the pictures hold on
i took out the hdd case and it is properly screwed and the backplate looks fine , wondering if i´m missing something
Frick
Fishfaced Nincompoop
19,301 (2.84/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
What model is the hard drive? How old is it? Some drives are just loud.
3,110 (1.64/day)
Mouse Logitech M575
3,402 (1.64/day)
UK, Midlands
System Name Main PC
Processor 13700k
Generally speaking weird noises are not a good sign, so backup if the data has any value to you, I am about to go bed so may miss the crystal disk info screenshot, but someone else will probably look at it anyway when you post it.
898 (0.61/day)
System Name ASUS TUF F15
Processor Intel Core i7-11800H
Motherboard ASUS FX506HC
Cooling Laptop built-in cooling lol
Memory 24 GB @ 3200
Video Card(s) Intel UHD & Nvidia RTX 3050 Mobile
Storage Adata XPG SX8200 Pro 512 GB & WD Blue SN520 128 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH 2.1-channel
Power Supply ASUS 180W PSU
Mouse Logitech G604
Keyboard SteelSeries Apex 7 TKL
Software Windows 10 Enterprise 21H2 LTSC
They are all DECENTLY SILENT when new, unless it's SAS server 10K+ RPM HDD.
Aging, they start to be more loud.
Yes, some "WD Green" type HDD is a little more quieter, but, even this will crackle when it has worked for like ~6-7K hours.
840 (1.39/day)
Belgium
System Name Prometheus
Processor AMD Ryzen 9 7900X3D
Motherboard ASUS ROG Crosshair X670E Extreme
Cooling AIO Cooler Master MasterLiquid 360
Memory 32GB DDR5
Video Card(s) Gigabyte GeForce RTX 3060 OC Edition 12GB
Storage Samsung 970PRO 2TB, Samsung 990PRO 4TB, WD SN850X 2TB, Samsung 980PRO 2TB. WD GOLD HDD 8TB
Display(s) Corsair XENEON 32UHD144 32" 4K UHD gaming monitor
Case Cooler Master HAF
Audio Device(s) Creative Sound Blaster AE7 + Logitech Z-5500 500W 5.1.
Power Supply Corsair AX850 Titanium.
Mouse Logitech MX Master 3
Keyboard Corsair K95 RGB
Software W10-11 Enterprise- Linux Mint 22.0 Cinnamon Edition.
Without more information we can not say much about it. Did it always make this sound, or just recently. If SMART table is good it should be okay to go. HDD always make some noise, even when not used and are standby. So probably everything is good to go. Only when you hear constant clicking noise and platter speed stopping or going up and down you should worry. This mostly also reflects damage in SMART table.
Can you post screenshot of smart table for us here?
Frick
19,301 (2.84/day)
Piteå
My Toshiba P300 isn't something you'll want in a cheap case on a desktop next to you...
As for the OP it's an old WD Blue (WD10EZEX), so it might be on its way out. Keep backups and make plans for replacement.
He did but the posts went poof as the servers crashed. Th SMART data looked fine at a glance, but it's an old WD Blue with like 12k hours on it, and 1200 starts I think it was. Not a lot, but no drive last forever.
Hello
Oh I missed this before, it might also just be that you notice the noise now. I thought it was like a new noise. Those old Blues aren't that loud but you can definitely hear them when they're running.
840 (1.39/day)
Belgium
Memory 32GB DDR5
Even SSD does not last forever yes that's for sure. But if the SMART Table shows everything okay i should not worry so much about it. To be sure you could keep a spare one handy just in case...
Surely if it before never did make this sound. For the price of a good HDD nowadays it doesn't cost you a kidney. :)
I have a WD GOLD Enterprise Helium filled HDD here, it also make some noise when not using it, but it's normal. They are definitely more quiet thanks to the Helium filling, but you still can hear them working.
140 (0.40/day)
System Name SYSTEM
Software WINDOWS 11
hey guys will upload the pictures when i get home
the site crashed yesterday and it deleted my messages
will upload soon
but can i trust the crystal disk info status 100%? i´m not sure if my hdd is ok due to the high noise
both my drives show ok in crystal disk info and hdd sentinel
Frick
19,301 (2.84/day)
Piteå
will upload soon
Is the noise new?
140 (0.40/day)
System Name SYSTEM
Software WINDOWS 11
Is the noise new?
i think so
i´m at a loss right now , don´t know if i should trust crystal / hdd sentinel despite the high noise coming from it
i remember loading elden ring it took like 2-3 minutes whereas it was faster before
should i run the western digital diagnostic tool maybe ?
21,303 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
i think so
With HDDs, best policy is: if you think something is wrong,something most likely is and its backup time EITHER WAY if you value the data. It doesn't matter what the other tools say.
140 (0.40/day)
System Name SYSTEM
Software WINDOWS 11
could my psu cause it maybe ? it is not damaged in any way as well
thanks
3,402 (1.64/day)
UK, Midlands
System Name Main PC
Processor 13700k
will upload soon
I know it may sound a nuisance, but again cant answer without seeing the raw data.
Generally speaking I dont really trust a generic status reported by an app, I always look at the raw SMART data which is why I asked for it. However the raw data is still not an absolute, sometimes drives will fail when all stats are perfect, and likewise a drive could continue to function if there is some warnings. However if the raw stats do post something wrong I will very likely advise you to backup and retire the drive, but as others have said, if you unsure, start those backups right away.
21,303 (3.40/day)
System Name Pioneer
I looked at the raw stats before they were lost in the crash. They looked good. That said a new noise would make me uncomfortable.
41,536 (6.59/day)
This is why I suggest the above tools in my previous post, give them a shot and see if they find faults with your drive, DFT 4.16 is older than WinDFT 0.95.
140 (0.40/day)
System Name SYSTEM
Software WINDOWS 11
sorry for taking long
here are the pictures
840 (1.39/day)
Belgium
Memory 32GB DDR5
As said before, nothing to worry about. They are like Sentinel says 100 percent healthy! :)
