- Jun 7, 2024
- 36 (1.71/day)
System Name | [ JUNE_2024 ] |
Processor | LGA1700 Intel i5-12600K / 3.7Ghz / 10 cores |
Motherboard | Asus Prime Z790M+ D4 |
Cooling | Abysm Snow 4 Duo120mm |
Memory | Kingston Fury RGB 2x 16Gb DDR4-3600 Mhz |
Video Card(s) | 2017 Nvidia GTX 1660 Super OC 6Gb ( upgrading 2024 - RTX 4060 Ti ) |
Storage | M2 Corsair MP600 Core XT 1Tb |
Display(s) | Hisense 32" TV @ 1080 / 60Hz |
Case | Cooler Master Q 300 L |
Audio Device(s) | Corsair HS35 Green / SteelSeries Apex 3 TKL / Razer Deathadder Essential |
Power Supply | Seasonic Focus 80 Gold+ 550W |
excuse my curiosity into Radeon... after posting an Nvidia tread im back at my gpu shopping list because my budget was all wrong...back then ive mentioned 600$ instead of 550 Euros and now my budget is down to 400 Euros (430$) because im keeping 100 Euros on the side to upgrade psu to 750W or even 850W (depending on connectors needed for the selected psu in this tread), so lets begin:
i have an intel cpu i5-12600k on a mobo Z790 limited to ddr4 Ram and i found on sale a gpu RX 6750 XT 12Gb for under 400 Euros (performance chart, the model above this radeon, is the rtx 4060 ti 16Gb which cost 550 Euros)... im looking for a minimum of 12 Vram up to 16Gb because buying cheaper Nvidias are limited to 8Gb (3060 and 4060 series) and i dont want to waste another 500 Euros in 5 years since games will only get more demanding.
QUESTION: this RX is a bargain so i ask, "whats the catch" with radeon cheap prices... what do i look for, as compatibility with my setup?
heres a pic of the minimum gpu requirements for my games in YELLOW and also the expensive nvidia in RED compared to the cheap radeon in GREEN... its more than 100 Euros difference which can buy me a new psu!
thank you for your insight.
PS: i dont do live streams, i dont photo edit nor draw vectorial 3D architecture of sort - i just need gpu to surf the net, watch Netflix and play on Steam while listening to Spotify.
