Is render test not enough today?
LuchoU
6 (0.01/day)
RTX 4070 Ti
Asus B650E-F
When I trigger a benchmark in 3DMark or Heaven, it changes to PCIe x16 4.0, but the render test is only going from x16 1.1 up to x16 2.0 from idle.
ir_cow
4,138 (0.71/day)
USA
It is enough. This just shows your card is running at 16x PCIe 2.0
LuchoU
6 (0.01/day)
I'm not sure what´s the point with that render test then, I thought the idea was to put the card in the highest power state to verify the max PCIe speeds the card is able to work.
When using Heaven benchmark I'm able to reach max PCIe speed.
Anyway, I will leave this here and look into other tools to verify max PCIe speeds.
Have a good day.
ir_cow
4,138 (0.71/day)
USA
That's a bit odd. That tests has always been accurate every time I used it.
1,267 (2.20/day)
System Name KLM
Motherboard B-650E-E Strix
Video Card(s) 4070-ti PNY
Storage 512+512+1+2+2+2+2+6+500+256+4+4+4
Case 4000D Airflow
Power Supply Shift 1000
Mouse 502 Hero
Keyboard K68
Software EMDB
Benchmark Scores 0>1000
560.70 driver version, strange behaving on my (4070ti) monitor OLED 240hz 1440p, if DSR ON it looses signal (need sleep wake or DSR OFF btw) at game start/quit or ingame switch res, i also read about EDID in this driver thing :
290 (3.02/day)
System Name Kuro
Processor AMD Ryzen 7 7800X3D@65W
Motherboard MSI MAG B650 Tomahawk WiFi
Memory Corsair DDR5 6000C30 2x48GB (Hynix M)@6000 30-36-36-48 1.36V
Video Card(s) PNY XLR8 RTX 4070 Ti SUPER 16G@200W
Storage Crucial T500 2TB + WD Blue 8TB
Case Lian Li LANCOOL 216
Audio Device(s) Sound Blaster AE-7
Power Supply MSI MPG A850G
Software Ubuntu 24.04 LTS + Windows 10 Home Build 19045
Benchmark Scores 17761 C23 Multi@65W
You might want a separate thread?
Have a good day.
Strange. Changes with power management code come to mind. I think the render test had more or less looked the same since it existed, maybe 10 years ago now?
1,267 (2.20/day)
System Name KLM
Case 4000D Airflow
Mouse 502 Hero
Keyboard K68
Software EMDB
Strange. Changes with power management codes come to mind. I think the render test had more or less looked the same since it existed, maybe 10 years ago now?
No i looked at the driver version you have... perhaps try with 537.58.
W1zzard
Administrator
27,455 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Correct. First time I hear about it not going to max PCIe though.
The render test is pretty light indeed by today's standards and as part of a big UI rewrite I will look into more demanding workloads
LuchoU
6 (0.01/day)
Yeah, maybe it's a thing with the last Nvidia driver, I'm not sure as I haven't tested with an older driver. I don't remember seeing this behavior with my old B550 mobo, but I still believe the render test load is too light for today standards, my GPU doesn't even ramp up the fans.
Thank you for looking into this in a future GPU-Z release.
