- Oct 19, 2023
- 197 (0.91/day)
- CincinnatiOH!
In my testing, I've suspected that (because of things like resistance and heat production, captive air in a case, turbulence, etc.) when the ambient temperature changes, so will the results, but it won't be linear, and now I've proven this to such an extent that I have to find a solution, if one exists, to normalize test results. Sadly, I have a few challenges in this regard.
I anticipate that there are people who are going to make suggestions, ask questions or try to derail this thread, so the following is a disclosure to head things off. See the bottom for what I'm actually asking for.
Thank you!
- Mathematically, I'm no genius.
- Financially, I'm unable to throw money at this problem.
- Since there are a lot of smart people here, I thought I'd see if anyone can offer any useful help, i.e. formulas for temperatures of the CPU/iGPU (DTS and Enhanced from HWiNFO64), GPU, mobo and VRM, which are what I've been tracking of late for my AIO testing.
Thank you!
EDIT: Since the responses suggest that not everyone fully understands, which means I've not done my job in making everything clear, here's more. My apologies. I'm not asking for suggestions on the following information, merely trying to make things clear.- I am running tests not because I enjoy it or because I need to, but because I'm a reviewer-tester. At this time, I've completed testing the first AIO (TR Frozen Notte 360) for its final review.
- I always do an initial review based on published specs, and then at least one more review based on test results.
- I'm also currently engaged in running a series of tests to determine the best configuration for a 360 AIO. Temperature variance has revealed that there is a non-linear progression in the temperatures, especially the CPU. I would link to the info, but I'm afraid I'd be banned again for linking to my own work, even though it would help. Suffice it to say that you can find it on BC under the name RevGAM.
- I'm not having cooler problems.
- I cannot control the temperature in my apartment, especially outside the range of my window AC. The best I can do to heat things up is a space heater next to my PC, which is highly imprecise.
- I'm looking for formulas. Really.
- It's not a matter of whether ambient variance is abnormal or not, but on the impact it has on my testing. To cite one example, if my ambient is 24C, the DTS CPU core temp will be 9C higher at 28C ambient, not 4C higher. Please don't explain why this happens - I understand. See #5.
- My PC is in a bedroom, my thermostat is in the hallway. It's not relevant, however, since my heater isn't going to turn on when the apartment is warmer than 60F.
- Again, I do not have an effective way to always keep the temperature the same but, once things warm up enough, my window AC might be useful for that.
- I do not agree with the use of an open bench, nor do I agree with lab results. I want real-world results, not sterile results captured in devices and chambers that are the opposite of real-world. Very few (not none, but out of the billions that use a PC, it's about the same as none) people run their computer on an open bench.
- With that in mind, opening up the case is also not a good idea, since a lot of people don't open up their computer and blow a fan in there, nor do many feel comfortable doing something so "terrifying", plus anyone with pets or small children would be foolish to leave their PCs open.
- I run Prime 95 with Small FFTs for 1 hour, which I'm sure someone will say that it's more than long enough, so please don't. I do this to make sure that the rad is as heat-soaked as possible. To aid in this, I also watch a video and do some work at the same time. I then run Cinebench 2024 CPU Multi-Core while watching a video and, finally, I run Time Spy (with no other activities since it is sensitive). If I make a mistake, I redo all or part of the testing depending on what's wrong. Even with all this heating up, my rad STILL rapidly cools down the CPU because, within several seconds the CPU temps are already a few degrees above ambient. The Notte is powerful.
- I record the temperatures in my spreadsheet and use the same formula for each to display the delta T. This is extremely important because when trying to rank the various configs it is impossible to do so correctly if I don't use delta T. I also record other things, like clock speed, CPU/Thread usage, CB & TS scores & FPS, and total CPU usage (average and max). This sometimes alerts me to an anomaly in testing that otherwise wouldn't be evident from just temps.
- Again, I'm looking for formulas. Please.
