Is there a pci card with both Wifi and Usb?
16 (0.01/day)
NSW, Australia
Processor i5-4460 3.2ghz
Motherboard Gigabyte H81M-S2PH
Cooling Corsair 120mm Static Pressure Fans, Stock CPU Cooler
Memory 1x8GB stick at 1333mhz
Video Card(s) Nvidia 750 Ti 2GB
Storage 256gb sandisk ssd (boot), 1 Unbranded 1TB HDD 5400rpm, 1 Barracuda 3TB 7200RPM HDD
Display(s) Samsung S24D300
Case Deepcool Tesseract
Power Supply Unbranded
Mouse Razer Deathadder Chroma 2015 10000dpi
Keyboard Razer Blackwidow Clicky X 2016
Software Windows 10 Home 64x
Benchmark Scores 525 Cinebench score
I'd love to have answered this with my own research but whenever I Google it, it comes up with "usb WiFi vs pci WiFi" . What I'm asking is, is there a Pci card with both WiFi and Usb (3.0 Preferably) or why isn't it possible. As my motherboard has only 1 PCI slot left and I don't really want to change it any time soon.
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (1.98/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Power Supply Corsair
Mouse cheap
Keyboard under going restoration
Have you considered a pci usb card and a wifi dongle?
16 (0.01/day)
NSW, Australia
I already have a wifi dongle and it is kind of annoying, I'm looking into buying a pci usb card and would love to have both usb and wifi on the same card as it is a mini itx build and is meant to be portable.
CAPSLOCKSTUCK
8,578 (1.98/day)
llaregguB...WALES
Mouse cheap
these are 7 quid and dont dangle like a dongle does
16 (0.01/day)
NSW, Australia
I
I realise there are small dongles... thank you for pointing it out, I want to know if there is or isn't an internal card that can do both. I'm not really asking for a solution for my problem. Rather an answer to the original question.
12,327 (2.25/day)
Oregon
Keyboard EVGA / Logitech K400
I've never seen one
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
I can't in many years of involvement in computer hardware ever recall seeing such a device. That certainly doesn't mean it doesn't exist but Ill hazard a guess and say it would be either very hard to find or nonexistent.
I don't know if you're limited on your PCI slots but you have several options to tackle this issue.
The most direct would be buying PCI wireless card as well as a PCI USB port card
Or buying a PCI wireless adapter and a 5.25 inch USB bay adapter. Which would install in the front of your PC like a DVD drive.
If you are indeed short on PCI lanes remember that these cards tend to only use X4 slots so you only need the little one and a half inch PCI slots and not the full ones. Conversely, you can also install the X4 PCI plugs into either an X84X 16 available slot it doesn't matter that the plug is only a couple inches in the slot is three or four it'll just utilize what it needs
Personally I recommend the 5.25 inch bay for USB it still installs in the PCI Lane it just internally routes to the front PC case I don't like the rear ones cause they're a pain in the ass to access
16 (0.01/day)
NSW, Australia
It would seem sensible as wifi can only reach no more than a 1/5 of usb 3 standards, I'll do some more searching, thanks :D
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
Remember that if you went with a 5.25 inch USB bay it'll still install in the PCI lane but It'llroute internally through your case and run out the front which is far easier than reaching around to the back of a PC to get to USB plugs. Good luck
16 (0.01/day)
NSW, Australia
Remember that if you went with a 5.25 inch USB bay it'll still install in the PCI lane but I'll route internally through your case and run out the front which is far easier than reaching around to the back of a PC to get to USB plugs. Good luck
There are 5.25 inch bays that use PCI interface?! My MB as it is quite a basic one doesn't have any 3.0 headers and only 1 2.0 header, if there was a pci extension that could route to the front of my case that'd be incredible.
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
Some of them use the motherboards USB 3.0 header but you can also find them with a PCI riser card that installs into your x4r PCi lane
It would be either one like the picture below but there are also ones that have the PCI card directly mounted to the USB hub via a cable
Notice how the riser card provides the USB 3.0 plug that I'm assuming your motherboard lacks by default
16 (0.01/day)
NSW, Australia
huh, didn't know that kind of thing existed, I'll still try and find a combo card but if I could get a pci card with internal headers I could connect the three 3.0 ports I have that can't currently be connected
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
heres another option that isnt Exactly what you wanted, but it is a step in the rightdirection...*also note* some of the adapters also have a single USB3 plug build on the PCI board, and You could just plug a usb wifi adapter directly into it, and the Dongle would in effect be internal....worth a shot , o_O
keep in mind these options require a Sata power plug in many cases, or a Molex type, be certain your able to power these option if you decide they are worthy
@Ozoingo2
This is the closest thing i could find that fit your request, but i know its not WifI, but it is ethernet , ;)
16 (0.01/day)
NSW, Australia
I've found this card which might work nicely
I already have a Deepcool rock master fan controller installed with 2 usb passthroughs that could attach. Thank you for your help :D
(P.S. if you could give me a model number on the picture in the quote that would be greatly appreciated)
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
I've found this card which might work nicelyView attachment 82928
Which of the pictures do you need a model number for? I'll just link you to the product itself but I I've posted three pictures so just let me know which one and I will link it for you also now you're going to have a big old antenna that's way more obtrusive in a little USB dongle :)
16 (0.01/day)
NSW, Australia
I'd like the model number for this one, seems like it fits my use case the best and maybe I can put the dongle in internally. Only problem is I'm in Australia so it will be challenging to find a place to ship here :p thanks
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
16 (0.01/day)
NSW, Australia
13,413 (1.99/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Those are NOT PCI cards!!!!!
You need to make sure of what you need. There is a huge difference between PCI and PCIe (PCI Express) despite their similar names. PCI is an ancient technology and protocol yet many newer motherboards still support the PCI interface.
PCIe replaced AGP as the primary graphics interface then went on to replace most (but not all) PCI slots.
I suspect PCIe is what you really want but since you never specified which motherboard you have (we cannot assume it is the one in your System Specs since many users have more than one computer), this needs to be verified before spending your money.
16 (0.01/day)
NSW, Australia
The one in my system specs is correct as I am talking about my main system. Ok sorry, by my terminology I mean PCI = PCIe, PCIe = PCIex16 . I know I'm not amazing at this :p. sorry for any confusion with that :D
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
Don't worry about it just, make sure that you double check everything when you make the order so you don't buy something that won't be compatible with your PC.I knew what you were referring to
Anyway good luck with your upgrade I'm off to get my face cut open by a surgeon :cry: :(, i'm having a handsomeness reduction operation ;)
16 (0.01/day)
NSW, Australia
Thanks for your help, I'm gonna get some sleep since its 2am here :eek:
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
13,413 (1.99/day)
Nebraska, USA
Mouse Logitech M190
Except PCI does not equal PCIe but I am glad you understand that. Assuming can get us into trouble so I avoid that as much as possible. I suspected you really meant PCIe; I just wanted to make sure you were not confused.
Also, you said you only have one PCI [PCIe] slot left. Note it probably is not a PCIe x16. It more likely is a PCIe x1 as PCIe x16 is in the first (top) 1 slot on your board - typically used for graphics cards. The x16 means there are 16 lanes for data. x1 means one lane.
Your motherboard supports the PCIe 2.0 standard. The 2.0 standard supports (in theory) 500MB/s per lane. That's megabytes per second. So even if you only have a x1 PCIe slot left, it will be plenty fast to support your wifi connection as the maximum wifi bandwidth is 500Mb/s (megabits) with 802.11ac.
16 (0.01/day)
NSW, Australia
Quick Question to do with this, My 750ti covers the second slot down so I only have the bottom two available, which are Pci, not PCIe. Will this card still work on a regular PCI slot?
Product: https://www.amazon.com/dp/B00A20KIXW/?tag=tec06d-20
