- Oct 17, 2012
- 9,781 (2.19/day)
- Massachusetts
System Name | Americas cure is the death of Social Justice & Political Correctness |
Processor | i7-11700K |
Motherboard | Asrock Z590 Extreme wifi 6E |
Cooling | Noctua NH-U12A |
Memory | 32GB Corsair RGB fancy boi 5000 |
Video Card(s) | RTX 3090 Reference |
Storage | Samsung 970 Evo 1Tb + Samsung 970 Evo 500Gb |
Display(s) | Dell - 27" LED QHD G-SYNC x2 |
Case | Fractal Design Meshify-C |
Audio Device(s) | on board |
Power Supply | Seasonic Focus+ Gold 1000 Watt |
Mouse | Logitech G502 spectrum |
Keyboard | AZIO MGK-1 RGB (Kaith Blue) |
Software | Win 10 Professional 64 bit |
Benchmark Scores | the MLGeesiest |
the Card you linked Should fit, it wont populate a Full length PCI slot, but if You look @ Your linked card, and look at the image i have linked below , You will see a separation in the PCI slot , that will match up with the notch cut out in the Connector portion of the Card you are looking to buy.
you'll just match up the notch's , and install it toward the Back end of the PC case, as if it had a full length connector.
if it Looks like what is in this pic tho, there are different buses and wont work togather, so you'll need a PCI usb add in card instead
I was under the impression You had another PCI-e slot, until reading all of Your last post. sorry
