Keyboards with programmable keys question ...
4,158 (0.77/day)
USA
System Name ASUS ROG Zephrus M15
Processor AMD Rhyzen 7 4800HS
Memory 16GB
Video Card(s) Geforce RTX 2060
Storage 1TB
I am looking for a new keyboard and want some programmable keys so I can use macros ... However, I am not sure the extent of how much you can actually program the keys, can you get like 30 keystrokes out of them and then repeat a set number/infinite?
Yes, I know software can do this, however it would be nice if I don't need to install another software and all of that. Especially since the keyboards I am looking at will come with their own software.
Right now the leader is: Corsair K100 RGB Optical
Anything else I should be looking at that would fit this need?
4,158 (0.77/day)
USA
Memory 16GB
Storage 1TB
guess this isnt a very popular thought lol ...
18,585 (2.71/day)
System Name AlderLake
The Americas still laying on their bed probably....
sneekypeet
Retired Super Moderator
29,473 (4.36/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
As long as there is a macro record button on the keyboard, they should do what you require.
9,340 (5.52/day)
Louisiana
Keyboard G710+x3
Yeah I haven't looked into keyboard features to much G & M keys are a mystery :eek:
Nothing obvious on Logitech about setting up micros and have not noticed a record key as mentioned above
On the other hand my mouse redragon 901 makes it pretty easy to setup custom function key combos which I do use quite a few of them.
sneekypeet
29,473 (4.36/day)
System Name EVA-01
Like this:
1,077 (0.36/day)
System Name Main System
Processor i9-10940x
Motherboard MSI X299 Xpower Gaming AC
Cooling Noctua NH-D15S + Second Fan
Memory G.Skill 64GB @3200MHz XMP
Video Card(s) ASUS Strix RTX 3090 24GB
Storage 2TB Samsung 970 EVO Plus; 2TB Corsair Force MP600; 2TB Samsung PM981a
Display(s) Dell U4320Q; LG 43MU79-B
Case Corsair A540
Audio Device(s) Creative Lab SoundBlaster ZX-R
Power Supply EVGA G2 1300
Mouse Logitech MK550
Keyboard Corsair K95 Platinum XT Brown Switches
Benchmark Scores Cinebench R20 - 6910; FireStrike Ultra - 13241; TimeSpy Extreme - 10067; Port Royal - 13855
I have the Corsair k95 brown switch. it has 6 G buttons and a macro record feature in its software that can do what you want. Great keyboard for me.
4,158 (0.77/day)
USA
Memory 16GB
Storage 1TB
I dont see one ...
yep, cant find anything on their site and dont want to go through all the youtube reviews to see if they discuss it ...
yep, what keyboard is that?
Is that the Icue software or whatever its called? So, I can record keystrokes ... but can only be ran once on the push and not setup to run multiple times?
sneekypeet
29,473 (4.36/day)
System Name EVA-01
It's an older Cooler Master just for reference.
8,187 (2.19/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
Several Logitech keyboards and mice have had the ability to make macros, for years, its current software is G-Hub. I just bought a Razer Basilisk and their software looks likes a macro for any key. Even Windows has the ability to turn a keyboard key into a macro, tho it is somewhat more complicated than using third party software.
I was planning on getting a K100 soon because Log9itech has a horrible problem with double striking keys, and some keys loosing one of rgb colors, and than there is double clicking the left mouse button on some mice. So, yea my next purchase will likely will be a Corsair cuz I am used to using G-keys.
1,077 (0.36/day)
Processor i9-10940x
Case Corsair A540
Yes it is iCue. I am not sure if I understand your question - do you mean you have to hit one of the G keys to activate a pre-recorded macro? If that is the question, yes you have to press the G key to run the macro. Check out this video and see if it will help you -
41,521 (6.58/day)
In CDT it was 6:22 you wrote this, it is a Saturday so most people sleep in
sneekypeet
29,473 (4.36/day)
System Name EVA-01
Most software macros offer a "spam" option. You just tell it once, or repeat until the key is released.
4,158 (0.77/day)
USA
Memory 16GB
Storage 1TB
good to know that there are some issues there ... will stay away. interesting looking mouse though
will check out and see if iCue does ...
yes, but also like once I push G1, run 5 times ... type of thing. I watched the video and saw how iCue mostly works ... it might work for what I need, if I cant get it to repeat, then I just might have a really long recording lol
3,770 (0.75/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
I've got a Corsair K95 RGB and never even install the software, hate software crap. I do use macros when I play D3 for example and in that case I use a Logitech Gamine Software. It integrates with most of my games well, actually works and w/o all the Corsair bloat crap.
1,077 (0.36/day)
Processor i9-10940x
Case Corsair A540
Oh I see what you mean. I went into my iCue software for macro and there is an option to repeat the action -
5,523 (1.03/day)
Gougeland (NZ)
System Name Cumquat 2021
Yup that's what I use it has upto 15 different macro memories or you can just go with the default setups which are quite comprehensive
8,187 (2.19/day)
SE Michigan
System Name Dumbass
Logitech offers 3 options, those two and toggle on/off.
I always wondered if LGS was usable on other brands in that way. TY
4,158 (0.77/day)
USA
Memory 16GB
Storage 1TB
ahhhh I will have to look into that software too, thanks for that
oh ok, yep that is what I was looking for. They did not touch on the advance section. thanks!
1,077 (0.36/day)
Processor i9-10940x
Case Corsair A540
I have had no problem with iCue so far. It works really well for me. If you have a solid system you shouldn’t have any issue.
43 (0.02/day)
EU
Processor Ryzen 1700 @3.8
Motherboard Asus Crosshair 6 Hero
Cooling Corsair H100i v1
Memory 16GB G.Skill F4-3200C14-8GFX
Video Card(s) Asus R9 380 4GB
Storage Samsung 840EVO 250GB, Crucial MX500 500GB, 2xWD Black 2T
Display(s) Benq 24" 144Hz 1080p
Case Antec P280
Power Supply Corsair AXi 860
Mouse Logitech G402
Keyboard Logitech G110
Software Win10 Pro
If the bundled software isn´t enough, there is always Autohotkey (https://www.autohotkey.com/); goto other downloads for no install zip file
Not very user friendly as Logitech/Corsair/... are but macro from simple repeats to programming automation, custom keystrokes, mapping to any key, mouse button, joystick, pad.
You make your script and save to .ahk files, either make windows choose how to open them or install and it should be setup.
After that it sits next to the clock in taskbar and awaits for the keystrokes for macro activation.
This is was it looks like, macro for a spin-attack when pressing mouse back button in Warframe. ( v = crouch, e = melee attack)
Code:
; comment Warframe spin attack, remember to change keybind v to hold crouch
*XButton1::                 ; on Mouse Back Button
    SendInput {v down}        ; hold v
    Sleep 20                ; wait 20ms, while still holding v
    SendInput {e}            ; press e, once
    Sleep 20                ; wait 20ms, still holding v
    SendInput {v Up}        ; release v
return
3,770 (0.75/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
Yea LGS works pretty well with the non-Logi keyboards. I use a G600 mouse so have plenty of macros to assign. It's great for different builds so you can end up with a lot of profiles. And you can also export the macro profiles (local\logi...\profiles) so one doesn't have to rebuild them on an OS refresh.
