Koss Unveils its Next Generation of Porta Pro Wireless Headphones
That's an awesome response, if a bit contradictory. Thanks for biting. :D
There's a lot of of shit in 40k that contradicts itself as it's not made to make sense.
In the case of the astartes per the actual cannon lore they are not what you think. The Primarchs are minor chaos gods the emperor was granted power over during his trip to Moloch where he betrayed the deal. They were created with his DNA, and the DNA of a female perpetual. She figured out what was about to go down and helped the chaos gods steal them. So she is there gene mother, and is able to create female astartes at will as she still holds the original "gene seed" and back in the days of pewter models there were female, and as posted above, half human space marines.
This has gone back and forth but it was admitted that it was cheaper to make all male models and thus draw in the incels so they killed the past. Now it's coming back. It's sort of like the Squats, was a thing, wasn't for years, now they are back. Who cares?
In the case of the other factions the custodes were first nudists in KKK hoods and that died quick.
Essentially the 40k units are an incel dick suck and have nothing to do with the actual lore. The most powerful person in the imperium (bar the emperor) was a woman, tied for second is a woman who commanded the Sisters of Silence and the Grand Commander of the Custodes (a male). Both of which were capable of slaying primarchs. Both of which teamed up to burn Prospero and the Thousand Sons LEGION at that point into ash. They were so OP even the Space Wolves Primarch Leman Russ backed the fuck off.
In can see this is a subject you're very passionate about. :laugh:
I still use mine to this day... Original wired version, sounds MUCH BETTER than any BT crap.
Bought about 20 years ago, I only had to replace the pads that wear over time...
Still sounds excellent. And VERY comfortable.
Cable should always sound better than wirelesss but I use mine so many hours every day I tend to forget I have them on. That caused me so much pain I decided to go full wireless before something really serious happened. Accidents included:
  • Having the headphones ripped out of my head.
  • Having a laptop fly half way across the room.
  • Broken plugs.
  • Cutting cables with the casters of my chair.
If the Olympics had a wired heaphone breaking competition.... :cry:
